View unanswered posts | View active topics It is currently Fri Feb 15, 2019 2:49 pm
Reply to topic  [ 36 posts ]  Go to page 1, 2, 3  Next
 PREBUG OVERHAUL
Post PREBUG OVERHAUL
hello all, this is my prebug overhaul, any advice is appreciated, i plan on doing a bbk install since my cylinder recently seized, more info/pics to come.
Sun Aug 10, 2014 2:53 pm
Post Re: PREBUG OVERHAUL
this is how it looked before the tear down, i will get more pics up soon.
Sun Aug 10, 2014 3:01 pm
Clean scoot.
Let us know what you're plans are!
Sun Aug 10, 2014 10:11 pm
my plans since it seized last week are bbk, 17.5 carb, wrist pin, crank bearings and seals. i will post pics later on today, i got the engine off the frame yesterday. it really needs alot of cleaning up, my stock carb was leaking everywhere. when i got the scooter it looked like it had been sitting outside for years without being run, i got it running without spending much money and i spray painted the body white to clean it up a little. it ran pretty good for about 500 miles it has about 3000 on it. the engine always made this weird rattle noise at idle or when i let off the gas, i could never really figure out what it was.
Mon Aug 11, 2014 7:39 am
just pulled the cylinder off, lets just say it wasn't very pretty. looks like the little circle clip that holds the pin popped out. also upon further inspection i noticed the rod had alot of free play on the crank side, im not sure if that's normal or not.
Mon Aug 11, 2014 9:21 am
this is just a shot of what my garage looks like right now with the scooter apart
Mon Aug 11, 2014 9:31 am
Circlip failures seem to be the order of the day lately. It's important they be oriented correctly when installed.
Mon Aug 11, 2014 1:49 pm
could it have something to do with the rod having play on the crank? or is that normal for it to wobble around? :confused:
Mon Aug 11, 2014 3:21 pm
update! if anyone is actually following this post.... any ways i ordered a bunch of new stuff for the zuma. for precautionary reasons i ordered a new athena crank along with a polini cast iron 70cc cylinder kit, 17.5 dellorto carb and a malossi intake manifold, since my other variator flywheel got destroyed with the circle clip incident i ordered a polini flywheel and some new clutch springs. :cheers:
Thu Aug 14, 2014 11:37 pm
Yeah, following! Let us know exactly what you got and we can offer some advice!
Fri Aug 15, 2014 12:12 pm
everything i ordered is listed in the update, any advice is appreciated. :cheers:
Sat Aug 16, 2014 12:39 pm
just got my order in from drowsports
Fri Aug 22, 2014 6:53 pm
So it looks like you got a Polini Sport, Polini drive face, 17.5mm PHBG, and the Athena OE replacement crank?
Should be a reliable runner. Hope you know what you got yourself into with the crank, IMO it would've been good to spend a few more shekels for a HPC crank if you're going to the trouble of splitting the cases.
Do you have jets for the carb?
Fri Aug 22, 2014 10:47 pm
yah i have the jet polini sent, i would have liked to get the better crank but financially i couldnt do it, splitting the case shouldnt be to bad ive replaced clutches on cars i assume it will be some what the same amount of work maybe less, anyways im gonna start on it today. i already have the rear end on my bench with the cylinder off, im shooting to try and get the crank in today. i will take more pictures and update yall later on what i get done. :cheers:
Sat Aug 23, 2014 7:00 am
Excellent! It's not a bad crank by any means, it's just not HPC. But with a Polini Sport you won't notice. It'd only be if you get addicted and want to squeeze every ounce of performance out later down the road that you'd address that.
Any questions let us know!
Do you have a starting point with your jets you want to run by us?
Sat Aug 23, 2014 3:08 pm
