View unanswered posts | View active topics It is currently Fri Jan 18, 2019 9:39 pm
Reply to topic  [ 8 posts ]
 HPC crank ?'s
scooters and mods: 2003 Kymco Bet&Win 250; MRP 300cc kit FAST!!! *NEW* 2001 Yamaha ZUMA, mods to come!!!!
Post HPC crank ?'s
I'm wondering if a full circle crank noticeably decrease lower end torque? Most of the sites say the power band gets moved up, and a slight loss of acceleration. I'm building a torque monster, with a max rpm of maybe 11000 pegged downhill. Will i even benefit gettin a HPC crank (with 70cc of course)? I don't want to go with a full circle and loose that off the line punch. I've decided to go with the polini corsa 70cc which should be happy around 10,000 with my LV zx, i don't want to end up moving the powerband much higher than that. I plan on getting either a reinforced or hpc and new seals /bearings and porting the case either way so if its worthwhile i would throw down extra cash on the hpc.
2001 "Yamaha" Zuma PreBug. MXS Race .55 squish, Polini Evo crank and evo bearings, Malossi Overrange 5.5g rollers, Stage 6 MKII Clutch, malossi 14/42 primary Polini 14/41 secondary 8.9:1, MXS Hyperhace exhaust, Stage 6 intake, VForce 3 reeds, Stage 6 VHST 26mm flat slide (125mj/35sj/50 slide/d44 needle), Malossi MHR inner rotor 28° advance, Nolgy Hotwire, Mallosi RS3 shock.
Sat Nov 22, 2014 12:55 am
Post Re: HPC crank ?'s
Im in the midst of building a CW50 bottom end, Im dropping a Doppler endurance crank and all the parts from my 1990 jog on the CW, but Im going to redo the CVT.
1990 Yamaha Jog CG50-CW50 swap
1992 Yamaha Jog CY50-stock
2000 Honda Elite SR50-72cc Corsa, Arrow, OKO24, Polini vari, 8.4:1
PocketChangeScooterClub
1995 Suzuki Intruder VS800
2014 Yamaha FZ-09
Fri Mar 27, 2015 10:03 am
HPC/full circle - as it was explained to me - just means there's extra material there to fill in the extra volume when you put in a 70cc (larger) piston. That increases the compression, so I would think it would increase torque.
"The Stage6 HPC (high primary compression) crankshaft is a full-circle crankshaft, and as such increases primary compression"
Fri Mar 27, 2015 12:39 pm
http://www.mopedarmy.com/wiki/Crank
Fri Mar 27, 2015 12:46 pm
scooters and mods: Tp 70cc,next r,vforce 3 reed block,s6 variator,stock carb 86 mj,vee rubber 119c tires,med contra,stiff clutch springs
Your not going to lose any bottom end punch with a HPC crank. Spend the extra cash and do it right the first time. Who knows 6 months down the line you may want a screamer, and all you'll have to do is buy a real pipe. JK
Good luck with the build :cheers:
Fri Mar 27, 2015 2:16 pm
lol I hope i get some extra torque out of my set up with a stuffer crank in place... Thats the reason why I bought it in the first place as of opposed to a stock replacement.
2014 Yamaha FZ-09
Fri Mar 27, 2015 9:26 pm
And you didn't even know that wasn't why you bought it, that the real reason was so you wouldn't break it with high revs.
Fri Mar 27, 2015 11:09 pm
Oh. i see. :eng101:
2014 Yamaha FZ-09
Sat Mar 28, 2015 10:41 am
Users browsing this forum: Google [Bot] and 1 guest
