View unanswered posts | View active topics It is currently Sun Feb 17, 2019 3:43 pm
 NEED HELP PLEASE! 2001 Zuma 50 Prebug tuning tips
Post NEED HELP PLEASE! 2001 Zuma 50 Prebug tuning tips
I have a 2001 zuma 50. my piston seized up in the cyinder so I decided to go ahead and bore it. Im putting a 70cc Athena kit in it. What are some tuning tips...such as gearing, air filter, carb, jetting ect. If yall can help it will be greatly appreciated!
[color=#FF0000]2001 Yamaha Zuma 50 Prebug 70cc Athena kit, tecnigas exhaust,17.5mm carb, Tun'R air filter, athena 14/42 gears, athena variator with 7g rollers, boss m203 speakers
Wed Dec 03, 2014 3:50 pm
Post Re: NEED HELP PLEASE! 2001 Zuma 50 Prebug tuning tips
Bump
Thu Dec 11, 2014 5:20 am
scooters and mods: 2005 BWS
Try posting in the prebug/vertical motor forum. You'll probably have better luck there. Or browse the builds section to see what others have done already.
2005 BWS "Garfield"
Thu Dec 11, 2014 10:29 am
First thing is to figure out why it siezed before you buy stuff
Secondly you will want at least a 17.5 mm carb the 12 mm oem carb is undersized
stick with the stock air box
Thu Dec 11, 2014 5:15 pm
Okay a 17.5mm carb, what about the jetting and gearing?
Sun Dec 21, 2014 8:49 am
