View unanswered posts | View active topics It is currently Fri Feb 15, 2019 2:42 pm
Reply to topic  [ 12 posts ]
 17.5 dellorto parts needed. Suggestions
Post 17.5 dellorto parts needed. Suggestions
Scored a really clean dellorto 17.5 for my prebug from a zuma forum member. A few on here suggested to get a bigger carb than my 14mm.
I need to get a top cap, needle slide, and needle.
Where is the best place to order these and what should I be looking for?
Thanks,
Tommy
Sat Jan 31, 2015 4:26 pm
Post Re: 17.5 dellorto parts needed. Suggestions
Treatland.tv is great.
Sat Jan 31, 2015 4:36 pm
For some reason I can't seem to find those parts, just whole carbs. I probably am just sucking at the internet
Sat Jan 31, 2015 5:08 pm
They may not have the top. Try Dellortodirect.com - but ask them for better shipping than their website generates.
Sat Jan 31, 2015 9:06 pm
So I found options, what size needle and slide do I need? Will these top caps work?
out
https://www.treatland.tv/SearchResults. ... bg+top+cap
https://www.treatland.tv/SearchResults. ... phbg+slide
https://www.treatland.tv/SearchResults. ... hbg+needle
Sat Jan 31, 2015 9:18 pm
No idea what your build is. Gotta fill out sig line.
Generally you're looking at a W7 needle and a 40 slide to start.
Sat Jan 31, 2015 11:35 pm
And can't help with the top selection without more info. You got the DS/Racing PHBG?
Sat Jan 31, 2015 11:38 pm
With the 17.5 Dell I've always used an A12 needle. Have a look at my sig line for my prebug, it should get you close. But then again I have know idea what your set up is. Fill in your sig line!
Sun Feb 01, 2015 12:21 am
I'll sell you a needle kit for that carb
Sun Feb 01, 2015 6:06 am
Sorry guys, should have posted that originally.
89 prebug
70cc BBK
NCY 3shoe clutch, yellow springs
Stock contra spring
Arrow exhaust kit
Stock variator with new rollers going in from the exhaust kit.
Open air filter with plastic cover.
Old/ current carb. TK 14mm stock 05 zuma carb
New carb dellorto 17.5mm PHVA missing top, slide and needle
Sun Feb 01, 2015 6:27 am
Special K, I would be interested if you have the setup I would need.
Sun Feb 01, 2015 6:28 am
So he told me it was a PHGB, but it is actually a PHVA TS.
I can find needles on treats as well as top caps. Not sure if I need version 1 or 2 yet but will figure that out.
I cannot find a slide though for the PHVA TS. Any help with finding that? I can fun only for the ED version.
Sun Feb 01, 2015 7:33 am
