View unanswered posts | View active topics It is currently Fri Jan 18, 2019 9:41 pm
Reply to topic  [ 10 posts ]
 Stock Exhaust mod?
Post Stock Exhaust mod?
Sorry, I am new. I tried using the search tool but it completely throws out the word "exhaust." So idk if this has been asked before.
I just got a '98 zuma and was thinking of toying with the stock exhaust. Wth is with the 4 bolts in the rear end of the muffler? They don't seem to be doing much of anything. If I remove them nothing seems to move or come loose, even on the inside. Is this just part of assembly before it is welded?
I don't really know what to do with this setup. Would cutting out the stock rear bit, just to make a bigger hole, give me anything? Doesn't seem to be much I can do with this except gut the entire thing, which im assuming is too loud.
Suggestions?
Mon Apr 06, 2015 1:46 pm
Post Re: Stock Exhaust mod?
There he is!
Glad you found your way here, Side, welcome to the forum!
08 YW50X, T-Mod,* Top Performances 70cc Trophy kit, 05 needle one notch richer, Pirelli sl26, 84 main, 46 pilot, Malossi .30 reeds, Yellow Malossi torque spring with torsion controller, Dr Pulley sliders, Leo Vince ZXR
Mon Apr 06, 2015 3:09 pm
A two stroke exhaust is not a simple thing
Pulling those out at one time should have been able to pull the baffles out
But moding a stock pipe unless you read Jennings book and do the math you aren't going to gain anything other then noise
And when you read the book you will find out how hard making the math work is and realize it's not worth the hassel
Mon Apr 06, 2015 4:36 pm
Sorry but, honesty... I never been that optimistic of performance gains from modified OEM parts... I pretty sure that Yamaha engineers gave you the best for cost and performance the way they made it.
Mon Apr 06, 2015 5:00 pm
I would think Yamaha has to find a balance between economy, performance, and noise. The average person doesn't want a loud exhaust, so performance is sacrificed a bit.
I have looked into it a little and understand that an exhaust with an expansion chamber has to be pretty specifically tuned to work, but I also looked up a couple of videos and diagrams of stock exhaust. They seem to be basic mufflers with fiberglass, baffles and pipes. If this is the case, the stock pipes wouldn't seem to be tuned in anyway, the way expansion chambers are. This being the case, I can't imagine modifying the stock exhaust would be detrimental except at the point where back-pressure would be too low.
Does that make sense?
I've cut out of a couple of stock exhaust on motorcycles before, but they were always big enough that torque didn't seem to change. They just made a bit more noise and seemed to rev a teeny bit more freely.
Anyway, I just want to get it back to stock and running first. Maybe I will save up and get an aftermarket pipe, and then be free to experiment with the stock one. Even if I found a cheap stock pipe, I'd probably buy it to experiment with. I have a little stick welder, but I haven't used it in a reaaaally long time.
So nobody even thinks cutting the little end off and making a quarter or half dollar sized hole would be beneficial? If not, I will just leave it along for now.
Tue Apr 07, 2015 1:44 pm
It's not really that performance is sacrificed, it's that it's designed to be a touring pipe. And it's matched to the other stock components in the scooter.
The first thing you learn about modifying a Zuma is that every change requires re-balancing somewhere else. Let's pretend you actually can make the stock pipe rev higher. That means your power band has shifted higher, so you have to change your clutch springs and lighten the rollers in your variator. And if you increase the performance, you're stressing the reeds, which means you should replace them with carbon fiber ones that don't spew shards all over your engine if they break. If it's revving too high - unlikely with a rigged stock pipe - you might be stressing the stock crank too much, making the bike dangerous to ride.
There's a lot of experience with mods on this forum, so I'd suggest continuing to do what you're doing: ask before you go off half-cocked.
Jmkjr is one of the people here worth listening to, by the way. He's cautious :) but if he's saying you're unlikely to get more performance out of a hacked-up stock exhaust, there's a very good chance he's right.
Tue Apr 07, 2015 2:05 pm
So you cut up 2 stroke motorcycle pipes or 4 stroke motorcycle pipes
there is no fiberglass in the stock zuma 2 stroke pipes it's all baffles
The big bottle neck is in the header part of the pipe and the actual exhaust port
And again even with a stock or touring pipe changing them will effect the pulse and if not done right will hurt more then help
There have been several that have cut there pipes up and only one that claimed to have any success with a cut up stock pipe
Tue Apr 07, 2015 2:39 pm
That is why I was wondering about cutting out the stock pipe. If the stock pipe is just baffles, they aren't accomplishing anything that an expansion chamber would, and redirecting the air that much makes me wonder if the performance is stifled some and could be improved by opening it up a little bit.
Thu Apr 09, 2015 2:35 pm
You're just swirling around a big pot of poo.
If you want to improve the performance, get a better exhaust and do the upgrade properly.
That's my opinion.
Thu Apr 09, 2015 3:26 pm
Just let us know how it works out :q:
2008 Zuma 50
2012 Zuma 50 (sold)
2003 Derbi Red Bullet
Fri Apr 17, 2015 10:50 pm
Users browsing this forum: Google [Bot] and 0 guests
