View unanswered posts | View active topics It is currently Wed May 23, 2018 3:04 pm
 YAMAHA ZUMA PREBUG TO BUGEYE SWAP
Post YAMAHA ZUMA PREBUG TO BUGEYE SWAP
Does anyone know if its possible to swap a 2008 zuma front end as in forks and brakes onto a pre 1999 zuma and if so what does it entail.
Wed Oct 28, 2015 10:46 am
Post Re: Prebug front end swap
I started to do this a few years ago and you would need the entire set up and a machine shop will have to trim down the bigeye triple tree for it to fit but you will not be able to use the original speedo as the plastics won't fit back on correctly due to the angle. Also the steering bumps will need to be cut off
Mon Dec 14, 2015 1:17 am
Post YAMAHA ZUMA PREBUG - with a bugeye 50 shock and tree on it
Sun May 20, 2018 2:41 pm
Post Re: YAMAHA ZUMA PREBUG TO BUGEYE SWAP
Why?
Mon May 21, 2018 6:58 pm
