View unanswered posts | View active topics It is currently Wed Mar 20, 2019 11:07 am
 buguy = coolguy
scooters and mods: *2002 yamaha vino classic*
Post buguy = coolguy
recently bought a part (Vino gears) from buguy. this dude is cool because he did me a solid. i was a little short in cash for the desired part posted for sale. i asked if i can send him a deposit and a few days later send him the remaining balance.. which he was cool with B) payment was smooth shipping had a delay but i was notified. so no negative points taken. all in all cool guy to buy parts from. this dude is cool in my book. i look forward to future transactions from buguy..
-mole
c-kell wrote:
''The Thrilla Of The Villa""
2002 Yamaha Vino Classic S
Engine mods:
Motoforce Evo crank Stage 6 Streetrace kit Dellorto 17.5 man choke
Polini carbon fiber reeds. Gianelli shot exhaust
CVT mods:
Polini Variator. Hebo Driveface. Malossi Winged Clutch Bell. Stage 6 clutch springs
Suspension:
RDR Nitrogen Filled Shock (rear)
Frame:
Home fabricated 6" stretch 2" lower
ZF member #14
Wed Jan 11, 2012 7:31 am
scooters and mods: 2009 Zuma 155
Post Re: buguy = coolguy
AGREE +1 for Buguy
Yoshimura TRC Carbon Fiber Exhaust,KOSO LED Tail Light,NYC Lightweight Fan,GJMS Speedo Cable Holder,Simota Hi-Flow Filter,NCY Direct Ignition,Magazi Led Signal Mirrors,Embedded LED Rear Signals,GJMS Fan Cover,GJMS Oil Cap,GJMS Rear Stabilizer Bar,GJMS GP-5RT,GJMS Forks,Frando HF2 Radial Caliper w/GJMS Mount,GJMS 260mm Rotor,Swageline SS Braided Line,GJMS Axle Pulleys,GJMS Ti-Coated Front Axle,Accel Bar,Accel Steering Stem,NYC Grips,NYC Throttle Control,GJMS Lever Set,RX1N/PGO Digital Guage,12t Majest Gears,CF Swing Arm,RC 155cc Kit w/2nd gen SRP Injector,High Lift Cam,Aluminium Nikasil Cylinder,Lighter Cam Gear,3D Billet Heat Sinks,3D Cam Breather,BMW e46 HID Projector,Prototype LED Front Signals,CF Parts,TST Varaitor 11g/12g Weights,Ariete Bridgeport Angled Valve Stems,Pirelli Diablo Tires,FRC Torque Drive,PG HD Clutch Bell,HD Clutch,1k Torque Spring,NCY Torque Spring Bearing,KS CNC Floor Board Plugs,Daytona +2mm Kevlar Belt
Mango Tango Build Thread: http://www.zumaforums.net/phpBB3/viewtopic.php?f=50&t=19102
Wed Jan 11, 2012 8:40 am
scooters and mods: '03 yellow Zuma with Malossi 70 cc, rejetted stock carb and stock exhaust.
+2. Good intelligent posts and always seems nice. He introduced me to this forum and I've learned tons since :toot:
Malossi 70cc, 82 main, 46 pilot and needle raised on stock carb, stock exhaust, air cleaner and clutch.
Wed Jan 11, 2012 10:23 am
Thanks guys! Unfortunately I sent another part at the same time as the gears to someone else, and the last I heard, it haden't made it. Looks like I may be rebuying a part that I mis ordered in the first place. Grrr!
Sat Jan 21, 2012 4:38 pm
