View unanswered posts | View active topics It is currently Wed Feb 21, 2018 10:00 am
Reply to topic  [ 96 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7
 Speed versus RPM calculator
Post Re: Speed versus RPM calculator
Yeah I need one. I am just being cheap. I still need a temp gauge for the LC kit, but I know I want a tach too. But I dont want to spend $180 on the S6 do all and I havent seen a resonable alternative.
Wed Apr 27, 2011 5:50 pm
Bump for inquiring minds
Stage 6 race bore MKI-MKII wasn't available when I purchased the bore
Yasuni-R pipe
Stage 6 overrange kit-28 grams total on the rollers
Stage 6 overrange belt
OKO 28mm carb-144, 40 pilot
CT intake manifold
Stage 6 vforce reeds
Athena 14/42 gears-9.9:1 final gearing
Uni open filter
Stage 6 hpc crank-skf bearings
NGK wire-got it for free from the shop
br9hs plug
Starter (of course with the overrange trans) and oil pump removed
Some minor porting of the cases
2.5oz/gal on the premix 50:1
Stage 6 MKII racing clutch with the stock bell.
Wed Jun 20, 2012 8:28 pm
BUMP
2001 ZUMAII - Tires TBD
Motor #1(2008) R.I.P this listed configuration, for it breaths new life under the rule of a new King...ENJOY NICK B!!!: Athena Sport BBK, Ported case, Power 1 HPC crank, Yasuni City16 (fully derestricted), Stage 6/Mototassinari V-Force 3 reed cage, OKO 24mm flatslide carb, S6 R/T rear facing manifold, running pre-mix, S6 BIG filter,Malossi drive face, lightened flywheel, Lightened Athena vario - (22.5g), S6 R/T WingCooler Bell, NCY TD, Malossi Delta clutch 107mm- 8K engagement, Malossi red Contra w/Malossi Torsion Controller.
Motor #2(2005): To be built.....ported cast iron 48mm bore, 41.4mm stroker crank, Ported case..(the rest of the following I don't have 2 of each...this stuff is coming off the 2008 motor) Yasuni City16 (fully derestricted), Stage 6/Mototassinari V-Force 3 reed cage, OKO 21mm flatslide carb, S6 R/T rear facing manifold, running pre-mix, S6 BIG filter, lightened flywheel, Lightened Athena vario, S6 R/T WingCooler Bell, NCY TD, Malossi Delta clutch 107mm- 8K engagement, Malossi red Contra w/Malossi Torsion Controller, Athena 15/50's for 12:1 ratio
Tue Oct 02, 2012 4:25 pm
Funny, I just used this today lol.
Yasuni-R pipe
CT intake manifold
Uni open filter
br9hs plug
Tue Oct 02, 2012 7:58 pm
Nice Calculator! I got 50.8 MPH on the GPS turning 10,040 RPM and the calculator says 49.8 MPH so I'd say it's pretty damn accurate.
Thanks!
Adam
2008 Yamaha Zuma (10K Miles and Counting)
Athena Sport 70cc (Extreme Porting Job!) with Poloni Head (0.7mm squish) 4K+ Miles
Delorto 17.5mm Carb
Ported Stock intake manifold
VForce3 Reed Cage
Stock Airbox With Snorkel Removed
Leo Vince ZX Pipe
Stock Variator Dr Pulley 5.0 Gram Weights
Malossi MHR Wing Clutch Bell
Malossi Delta Clutch with Yellow Springs
Koso Tachometer
EBC Brakes Front and Rear
RFY (Cheapo Chinese) Adjustable Rear Shock (Works Great!)
Michelin Bopper Tires Front and Rear
87 Main Jet / 35 Idle Jet, W7 Needle 1 Notch Lean
GPS'd at 50.8 MPH @ 10,040 RPM
Tue Oct 23, 2012 2:45 pm
4.00 x 3.68 = 14.72 :cool:
Fri Jun 02, 2017 3:09 am
