View unanswered posts | View active topics It is currently Sun Apr 22, 2018 12:49 pm
Reply to topic  [ 8 posts ]
 MAIN: Video - How to Clean Air Filter
Post MAIN: Video - How to Clean Air Filter
Supplies:
    Screw Driver
    Glass Bowl
    Mineral Spirit (Paint Thinner)
    2-Stroke Oil
    Protective Gloves
    Paper Towls
2005 Yamaha Zuma 50
58 mph (GPS)
0-40mph ?? Seconds
Malossi Sport 70cc BBK - Stage6 PRO Exhaust - Dellorto PHVA 17.5mm 92MJ, 34Idle, A12 Needle Up One Position, Snorkel Removed - Athena Primary Drive Gear - Nology Hotwire - Malossi Reed Cage - Malossi Multivar - Stage6 Rollers 30g - Malossi Delta Clutch - Malossi Wing Clutch Bell - Malossi Torsion Controller - Malossi Yellow Contra - Motoforce Racing R6 Rear Shock - Slipstreamer Windshield - Dual Headlight - Triple Brake light - EMGO Trunk - Ram-Mount for GPS
Mon Aug 09, 2010 5:33 am
Post Re: MAIN: Video - How to Clean Air Filter
you know i just like to spray it clean with starting fluid
Mon Aug 09, 2010 8:55 am
Hello prime1010,
Thank you so much for posting this here and on YouTube. It is greatly appreciated. From how you demonstrated this process, it looks like a pretty painless procedure, but maybe that's just the way you did it, looks easy.
One thing that your missing from your supplies list is some great tunes. ;-)
Thanks again.
--rudge
2003 Yamaha Zuma • Malossi Sport cast iron 70cc big block kit • #84 Main Jet • #46 (Vino) Pilot Jet •
Bopper tires • Dual ZumaLight harness • JDM Tail Light • Doppler Oleopneumatic Shock • Tiny Tach •
6 gram Dr. Pulley Slider Rollers
http://www.zumaforums.net/Gallery/v/rudge/
http://tapastic.com/series/Kickstart
Mon Aug 23, 2010 3:30 pm
Complete with Ghosts n Stuff!!!!
2009 Zuma 50
Stage6 Street 70cc BBK, Stage6 Street Exhaust, Dellorto PHVA 17.5mm, Malossi Reed Cage, Dual Headlight, JDM Tail
Sean
Thu Mar 24, 2011 12:39 pm
nice work, i use starting fluid also i guess both way is good . is this how u clean on air induction filter too and how often thankyou
Sat May 14, 2011 9:05 am
I know this thread is extremely old, but are there any mirrors? or an archive of all the tutorial videos? The linked is now marked as private.
Thu Dec 11, 2014 1:56 pm
Cannot access video. It says I have to sign in and I am. :( I need a video to show me how to clean my Zuma 50 air filter
Sat Jun 11, 2016 11:30 am
The video has been made private.
Pull the filter out and wash it with some soapy water, dry it out and put it back. No need to oil it either unless you want to.
2008 Zuma 50
2012 Zuma 50 (sold)
2003 Derbi Red Bullet
Sat Jun 11, 2016 6:36 pm
Users browsing this forum: Google Adsense [Bot] and 3 guests
