View unanswered posts | View active topics It is currently Thu Apr 25, 2019 7:09 pm
Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3
 YAMAHA ZUMA BUGEYE THROTTLE MOD
Post Re: ENG: Tmangs throttle mod pictorial
Csappo wrote:
scottmanesis - by taking out that throttle stop as mentioned in one of the above posts, you have made your scooter very dangerous to ride. You need to replace your whole carb with a new working piece WITH a stock unit ASAP, for the safety of your self, anyone that rides it, and anyone driving on the streets around you.
For future reference to anyone reading this, IF you do not know what ANYTHING does, DO NOT touch it!!! Ask an expert before making NOVICE and *STUPID* decisions. (I don't mean to be harsh, but grinding off the throttle stop was just not a smart thing to do)
I think he is referring to completely removing the throttle stop, which I *think* can put you at risk for the throttle sticking at WOT. I had an old Datsun that I had put a Weber carb on, it didnt have a throttle stop set up, I was getting pissed off at it cause it wouldnt fire over, I mashed the gas (not running) and it stuck there until I smacked the carb. Someone said it could have been due to the fact that it was missing its throttle stop.
Mon Jul 21, 2008 9:27 pm
scooters and mods: 2 dead honda sprees need parts? and a throttle choped 08 zuma,
one of my old sprees had a sticky throttle cable id just use the kill switch to slow down. turn it back on when I want to go, bang pop vroom
I pledge allegiance to the Flag
of the United States of America,
and to the Republic for which it stands:
one Nation under God, indivisible,
With Liberty and Justice for all.
Tue Jul 22, 2008 10:19 am
scooters and mods: 2008 Yamaha Zuma, Red, race driven.
Well we're not talking about completely removing it. We're just grinding it down to the proper size.
Racer: 2008 Yamaha Zuma, basically stock.
Daily Driver: 1991 Ford Ranger Turbo 2.3 RWD 5-Speed
Pleasure/ Gas Sipper: 2009 Suzuki SFV650, stock (but not for long)
Tue Jul 22, 2008 11:16 am
scooters and mods: 2002 Zuma 50CC w/ Leo Vince Pipe & Athena Variator (weighted) & Clutch Springs
If you’re wondering what makes me qualified to pass judgment sir; maybe the fact that I have been working on cars for MORE THAN half my life, the fact that I am a CERTIFIED Technician with over 150 certifications from Ford, you know cars, not these little TOYS, and a degree from a reputable college would make me qualified...
He said he ground of the stop with the screw off, not the cam lobe.
Quote: "I just shaved the stop off and ground the cam much less than what I have seen here, it pulls as far as the throttle cable will let it without hitting anything."
Wed Jul 23, 2008 2:12 pm
scooters and mods: 2008 Zuma 50
hm.. can u guys post some pics of what you're talking about?
griding the cam stop lobe or throttle stop.. :confused:
nevermind.. i'm just a noob at modding, I need pics to know what ya'll talking bout..
2008 Murdered Out Zuma
My Zuma Gallery
T-modDual HeadlightsTriple Brake LightsFlawless' DIY Dash Mounted ClockC3 Mirrors
Wed Jul 23, 2008 2:25 pm
On the first page of this post there is a picture with a little black circle around the cam lobe. That is what you want to grind off...Look at the difference from the 08 and the one that is from the 05.
Wed Jul 23, 2008 3:01 pm
or you can leave everything intact and take the plastic off and use a dremel to grind it down
Wed Nov 17, 2010 5:27 am
Thanks for the great write-up. I did this about 3 weeks ago and this is how the bike should have come. I did mine with the cam still attached. I also ended up knocking off the vacuum hose when I put the bucket back on. I got the "I told you so" look from her.
Stage 6 race bore MKI-MKII wasn't available when I purchased the bore
Yasuni-R pipe
Stage 6 overrange kit-28 grams total on the rollers
Stage 6 overrange belt
OKO 28mm carb-144, 40 pilot
CT intake manifold
Stage 6 vforce reeds
Athena 14/42 gears-9.9:1 final gearing
Uni open filter
Stage 6 hpc crank-skf bearings
NGK wire-got it for free from the shop
br9hs plug
Starter (of course with the overrange trans) and oil pump removed
Some minor porting of the cases
2.5oz/gal on the premix 50:1
Stage 6 MKII racing clutch with the stock bell.
Mon Apr 18, 2011 5:09 pm
I have an 05 50cc...
I am confused and a Scoot newbie...
Is this mod for the 2005 or is this for the 2008 to run like the 2005???
I am a big guy on a small scooter and would like to make some small changes to hot rod around with!!!
Thanks and sorry for the confusion
Sat Jul 02, 2011 9:14 am
this is for the 08 to 11 2 stroke 50 cc zuma with oem carb
Sat Jul 02, 2011 9:40 am
cool. thanks
Sun Jul 03, 2011 7:26 am
