View unanswered posts | View active topics It is currently Thu Apr 25, 2019 7:36 pm
Reply to topic  [ 12 posts ]
 YAMAHA ZUMA HEADGASKET QUESTION
scooters and mods: 2006 Yami BWS, Stage 6 Street Race 70cc,Malossi Multivar Variator
Post YAMAHA ZUMA HEADGASKET QUESTION
Does the raised circle around the piston hole go up or down.
Want to put the motor back together today but need to know this part.
Thx
2006 Yamaha BW
Stage 6 Street Race
Mallossi Multivar variator w/7gram rollers
Motoforce three shoe clutch
dual headlamp mod
C3 mirrors
rear amber turn signal lens mod
Michelin Reggae front
Kenda rear
Sun Sep 16, 2012 9:53 am
Post Re: Head gasket orientation
I have always, sprayed them with koperkote. Then put them in tits up.
Sun Sep 16, 2012 2:45 pm
Bubble side to the head
Sat Sep 29, 2012 3:16 pm
Would the same rule apply to the base gasket (my Trophy kit didn't come with instructions)?
The rib/bubble thing should face the same direction as the head gasket is facing?
Thanks, trying to figure some things out while waiting for more parts :cheers:
08 YW50X, T-Mod,* Top Performances 70cc Trophy kit, 05 needle one notch richer, Pirelli sl26, 84 main, 46 pilot, Malossi .30 reeds, Yellow Malossi torque spring with torsion controller, Dr Pulley sliders, Leo Vince ZXR
Sat Aug 10, 2013 10:17 am
Way I was told back in the day was, The part you are tightening down should compress the rib.
Sat Aug 10, 2013 10:42 am
Base gaskets dont have ridgesridges in them
Sat Aug 10, 2013 6:35 pm
Most of them don't, that's why I am having trouble figuring it out from the how to's.
Anyone remember which way they put this gasket in?
download/file.php?id=17597&mode=view
Sun Aug 11, 2013 5:12 am
Get yourself some flat metal base gaskets other wise it evfects your squish
Sun Aug 11, 2013 6:02 am
scooters and mods: 2009 50cc
I have leaking bottom gasket with new top performance black trophy kit. The kit came with a ridged bottom gasket and replacing with same one. I am guessing rib side on bottom gasket and ridge side fine on head gasket...?
http://scootertuning.ca/en/pistons-gaskets/62013-gasket-set-top-performances-trophy-tpr-70cc.html
Scoot-tuning.com recommended this stuff, Is non hardening.
https://www.scoot-tuning.com/TB-1184-GREY-LIQUID-GASKET-p/048-602.htm
2009, 70cc Black Trophy TP, 15/50 Gears, Long Belt, Oversize Fan
Tue Sep 26, 2017 8:07 pm
This was helpful, may have answered my questions... Going to order some Yamabond 4
http://performancecycle.com/three-bond-liquid-gasket-1184-yamabond/
"Threebond 3.5 oz. 1184 Liquid Gasket
Same as Hondabond 4. Yamabond 4, Kawasaki Case Sealant 4 and Suzuki 99000-31010.
High performance
O.E.M specified
Seals in 20 minutes
Designed for low and high temp applications
Resistant to oil, coolant, water, and gasoline
Gasket dressing
Semi-drying
Low viscosity
Performs well on uneven joints
O.E.M approved"
______________________________
Am going to speag silicone on gasket with finger and extra dabs on the crankcase where it joins togetger
Wed Sep 27, 2017 9:55 am
I was wondering who retightens the head bolts after break in or warming up?
I was concerned this may effect the silicone seal on bottom gasket...
Thanks
Sat Oct 07, 2017 1:43 pm
The bottom gasket can only be installed one direction. The bottom gasket ridge ends up facing downwards to crankcase. So I put head gasket ridge face down as well.
I used a heat gun on the head right after assembly, waited a few mins, and was able to tighten a bit more. Maybe that will be enough...
Sat Oct 07, 2017 2:50 pm
