View unanswered posts | View active topics It is currently Thu Apr 25, 2019 7:08 pm
Reply to topic  [ 36 posts ]  Go to page 1, 2, 3  Next
 Air Cooling / Modification / STR-8 Fan
Post Air Cooling / Modification / STR-8 Fan
Increased cooling efficency and performance:
First off, It worked for me. It cost me some RPM & Top speed. It is a trade off. IMO a good one.
lower operating temperatures, should increase performance. I would also like to think it would increases engine life & reliability .
Before you start this. you should should read up on the subject. then ask your self, is it Snake Oil, Hooter Buff, WTM,(waste of time and money) You make the call. It worked for Me, here is How & What I did.
There are 2 design,s or methodology's I found, you can follow.
Design 1, Mod the existing air cooling shrouds & fan and fan housing. Add an Air Scoop.
Design 2, Utilize BWs-100's design, bigger housing & cylinder shroud and fan.
I preferred choice #1:
Mod the existing Housing, over the BWS-100 method. (I did not like the Cylinder Shroud / Fan Housing fit, of the BWS-100.
I used a STR-8 fan & air scoop
File comment: If installing a scoop, this outer lip needs to go.
File comment: Remove this raised lip on the inside of the cover
File comment: Flange removed & Grill thinned down. Air is gonna FLOW
File comment: I cut down the square block on the stock cylinder Shroud, Why block the air?
File comment: Fan mounted on idling motor. Angle grind off the, Rim & trim in small increments, test fitting cover {When trimming fan, limit idling or you will overheat your motor}
File comment: A comparison of the fan heights, extreme left is mine ground to a perfect fit for my housing.
File comment: Round over the fan blade outer corner - less whine
File comment: completed housing and scoop
File comment: Completed & installed, Hook up your CHT and enjoy the Ride.
Tue Jul 01, 2014 1:18 pm
Post Re: Air Cooling / Modification / STR-8 Fan
That was my issue - I don't want to give up RPM and top speed! To me those *are* performance. :)
By the way, just getting rid of the stock air scoop gained me about 15 degrees of cooling. (That's with the stock fan.)
Tue Jul 01, 2014 1:30 pm
Opening up the grill on the OE helps too.
Tue Jul 01, 2014 1:44 pm
I'm looking into doing this as well... what did you use to cut off the raised lip on the outside of the cover (where the scoop is)? Dremel?
2003 Zuma
(tuning)
Stage6 HPC 10mm crank
Malossi MHR Overrange (24.3g)
Malossi 107mm MHR Wing Bell
Malossi Yellow Contra Spring
Malossi Torsion Controller
RFY Shock
Stage 6 F1 Mirrors
Stage 6 14/42s
NGK BR9HS
Michelin Boppers
Trail Tech Vapor
LEDGlow Underglow Kit
Sat Sep 06, 2014 9:20 am
Did not cut it, used a 5" grinding disc 60 grit. Used for Autobody. Took it down in less than a minute.
Sat Sep 06, 2014 3:00 pm
I used a dremel, but it wasn't very easy going. Slower and is gonna take some effort to clean up. Did you screw the scoop into the shroud or use some sort of adhesive?
2003 Zuma
(tuning)
RFY Shock
Stage 6 F1 Mirrors
Stage 6 14/42s
NGK BR9HS
Michelin Boppers
Trail Tech Vapor
Tue Sep 09, 2014 5:57 pm
Sorry missed the reply:
I Riveted the Scoop on.
Sun Oct 26, 2014 1:58 pm
I hate to say it, but the STR-8 fan can blow me. :)
My temps are fine with the stock one, and I want all the performance I can get.
But the best tool to shave the STR-8 fan is a belt sander upside down.
Sun Oct 26, 2014 2:50 pm
That will cut it down. But it won't allow you round over the corner like a grinder & rotating fan. The whole procedure might take 15 minutes. Plus you need it on the motor to do your check fit. But if you don't have a grinder & you have a belt sander it would be the same operation. You just have to, Use some PPE & be careful, And helps too have some skill at this type of thing.
Sun Oct 26, 2014 4:05 pm
Can't help you there. :)
My issue is just that the fan uses too much power. I don't need that.
Sun Oct 26, 2014 6:20 pm
That is why you trim it down to the smallest version that cool's the cylinder. Particularly with Iron kits. The alloy kits shed heat through there better metallurgical property's. You are looking to increase flow across the fins. Increased pressure does you no good. You want to increase flow across the fin's.
If you run a larger cylinder. And burn more fuel, you will create added friction & added heat. A better fan, is no different than the larger Carburetor theory. The larger Carburetor is increasing the internal Flow, there by, increasing the cooling internally. The increased flow of a HP Fan & shrouding, help's on the outside. Unlike a larger Carburetor. A bigger fan takes more work to turn. So it is not a free ride. That is why, bigger is not really the object here. You tune the amount of fan, for your needs.
Sun Oct 26, 2014 7:15 pm
The problem is that it takes more work to move more air across the cylinder, and I was shocked at how much.
My engine doesn't get too hot, so I decided against using my STR-8 fan.
Mon Oct 27, 2014 12:15 pm
[quote="Nick Batzdorf"]The problem is that it takes more work to move more air across the cylinder, and I was shocked at how much.
You should feel the difference an inner rotor makes, if you think the fan makes a difference.
Mon Oct 27, 2014 1:40 pm
Hm. Well, I was warned to be wary of the the small stator/flywheel I was looking at due to quality issues, so I'm going to pass.
However, I may have my flywheel lightened one of these days. Inner rotors are too expensive for me.
Mon Oct 27, 2014 4:50 pm
U could just mount a electric fan on the fan cover and then have it on a switch to the ignition so when you turn your ignition on and fan comes on and then u will gain power and cooling efficiency
Thu Dec 11, 2014 11:20 am
