View unanswered posts | View active topics It is currently Thu Apr 25, 2019 7:07 pm
 how to bleed front brakes on 01-05 zuma
Post how to bleed front brakes on 01-05 zuma
OK I have had trouble bleeding my brakes finally today I got them working after like 4 months of trying I found out you gotta make sure the caliper piston is not pushed in all the way.Then take brake master cylinder cover off check fluid fill it up 9/10 of the way then get a dental syringe put a small hose on it that will fit over bleeder.Then loosen bleeder then pump brake lever a few times then just pull on syringe get fluid inside of it.Then push down on syringe and hold up right for you don't get any air in the lines.Slowly push the fluid from the syringe back in the caliper until it is nearly empty tighten bleeder take syringe off top off brake fluid.Put cover back on master cylinder. I had a bunch of trouble with mine so I thought I'd post this up.
Tue Dec 09, 2014 4:24 pm
scooters and mods: 1992 BW's 50 (4BX), Kymco DJ 50 (SA10AA[wifey's ride])
Post Re: how to bleed front brakes on 01-05 zuma
05zuma wrote:
OK I have had trouble bleeding my brakes finally today I got them working after like 4 months of trying I found out u gitta make sure the caliper piston is not pushed in all the way then take brake master cylinder cover off check fluid fill it up 9/10 of the way then get a dental syringe put a small hose on it that will fit over bleeder then loosen bleeder then pump brake lever a few times then just pull on syringe get fluid inside of it then push down on syringe and hold up right for u don't get any air in the lines and slowly push the fluid from the syringe back in the caliper until it is nearly empty tighten bleeder take syringe off top off brake fluid put cover back on master cylinder since I had a bunch of trouble with mine I thought I'd post this up
Thanks...but have mercy with older folks like me and take some care of a halfway correct spelling, okay? ;)
THE RAT: 1992 BW's 50 (4BX)
Maxtune racing vario, OEM racing clutch, Polini Evo Slider, Aerox gears, OEM 17.5 carb, Yasuni Z
YSS rear shock 300mm, 4VA cowl, Suzuki AY 50 windshield, all LED lights
...probably never going to be finished...
Tue Dec 09, 2014 10:37 pm
That's the longest sentence I've ever seen, and it doesn't even have a period at the end.
My second grade teacher would have scheduled an emergency meeting with my parents if I'd written something like that.
Wed Dec 10, 2014 12:38 am
As you can see im not much of a writer!
Wed Dec 10, 2014 8:14 am
Sorry, I can't help myself. I'm a magazine editor by trade.
Wed Dec 10, 2014 1:51 pm
Haha its OK I'll try and add some periods for ya.I fixed it
Wed Dec 10, 2014 3:35 pm
