View unanswered posts | View active topics It is currently Thu Apr 19, 2018 2:38 pm
Reply to topic  [ 68 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 100cc bws on a zuma how to anyone?
Post Re: 100cc bws on a zuma how to anyone?
if someone can find a couple bws engines i will go in on one for a group buy. im looking for one myself
Pro Scooter Parts Authorized Dealer
Polini / Malossi / NCY /Metrakit / POSH / Doppler / Leo Vince / Athena
Visit us today at http://www.proscooterparts.com
60+ mph club 70+ when i can show the proof :)
Mon Aug 10, 2009 7:01 am
Mon Aug 10, 2009 7:59 am
I think smelly can get a 135 cc version.
JAY
______________
2009 Zuma 125
June '09 SOTM
MY GALLERY
Mon Aug 10, 2009 9:44 am
my buddy took bws100 crank,jug and piston and cut his zuma 50 case to adapt to the crank. then he used a athena 70cc head on the 100 jug high compression it really rips same speed as a modded 70cc zuma but tons of torque with the longer stroke
Sun Nov 08, 2009 5:47 pm
The studs that hold the cylinder to the block are spaced differently on the BWS 100. The 100 cylinder will not fit the 50 case.
Sun Nov 08, 2009 5:56 pm
Hello specalk,
Well, It's been close to two years since you posted this and we haven't heard anything new of it. Did anything come of this engine swap, or did you simply spring for a 125 cc instead? I guess that would make more sense.
--rudge
2003 Yamaha Zuma • Malossi Sport cast iron 70cc big block kit • #84 Main Jet • #46 (Vino) Pilot Jet •
Bopper tires • Dual ZumaLight harness • JDM Tail Light • Doppler Oleopneumatic Shock • Tiny Tach •
6 gram Dr. Pulley Slider Rollers
http://www.zumaforums.net/Gallery/v/rudge/
http://tapastic.com/series/Kickstart
Fri Jul 02, 2010 2:47 pm
:munch:
Hya
Current Configuration:
3. NGK BR7HS
6. Malossi Delta Clutch
9. Malossi Up-Gears
13. Arreche 19mm Carburetor
14. Arreche Manual Choke
Fri Jul 02, 2010 4:24 pm
I´m from Panama (in Central America) here Yamaha sold the BWS100, but is no longer sold because of the new BWS125 4 stroke. but here you can find a lot of used scooters BWS100. In Colombia and Dominican Republic I know they are pretty famous, and can be found parts.
I have a 2009 BWS 100cc stock and runs very nice, top speed is 83km/h and 95km/h downhill.
hope this information helps...
Thu Oct 07, 2010 1:19 pm
i have all of the parts to install a european bws100 engine under my 02 zuma. i need to figure out which carb i want to use and assemble it all.
i has a: 2005 zx10r, 1999 r1 fighterer, 1990 cr500 project, 1995 mcgrath replika cr250 project, 1984 cr250 frame off resto project, 197? gt750 cafe project, 1986 atc200x (recently stolen), 2002 raptor 660r (bought it for girlfriend), 2002 zuma.
Sat Oct 09, 2010 3:44 pm
rudge wrote:
Hello specalk,
--rudge
I was unable to get my Hands on the Motor so I did a Fully Built 70cc LC Rocket. the 50 kitted is a better setup then the bws100. Someone Else will have to do this mod.
Sun Jan 02, 2011 10:56 am
Holy thread resurrection batman!
Don't you mean a stock bws100? ;)
2007 Yamaha YW100E BeeWee in blue (100cc o'grunt!) - 113 cc kit, LV ZX exhaust (derestricted), Aerox rims, Aerox front end (shocks, triple clamp, disc, Brembo caliper), custom rear shock, Koso clutch, Dr Pulley 5.5g sliders, beaver-tail delete, Billet bar riser, Renthal Ultra-low rise bars, Acewell Digi-Dash
2005 Yamaha YP250 Majesty in silver (The missus rides a bigger un than me!)
Sun Jan 02, 2011 12:13 pm
Sorry about the resurrection of this thread, but it's hard to tell how old these things actually are, going by the posted dates. Some of you guys really need to change your computer's clock. :)
There was another thread about a BWS 100 engine swap for a Zuma 50 here and Smellybumlove put down the information about the engine and prices ($1,300 at the time anyway).
viewtopic.php?f=3&t=6568&hilit=100+cc+engine+swap&start=45
There was another thread where Smelly said that Taiwan passed a law where it's illegal to swap engines between bikes, so whether that previous thread where he rebuilds a Yamaha 100cc engine and ships it over to you, may or may not be what he's able to do now.
viewtopic.php?f=3&t=4723&p=52164&hilit=100+cc+engine+swap#p52164
Everybody seems to be excited about engine swapping a 2-stroke BWS100 engine, but nobody has really written anything about actually doing it. How easy/difficult it was and what the results were.
You would think that it would be a lot easier to smuggle BWS100 engines over the Mexican boarder. Judging by the lack of posts and the amount of videos on YouTube (not really any) that this just isn't that good of an option for people.
--rudge
Tue Jan 18, 2011 4:46 pm
We never got the 50cc one down here so can't really help!
Mon Jan 24, 2011 3:29 am
not true because i just ported the stool out of my z50 cases to make the 100 crank and jug etc fit in.
i ran the 16mm 12mm pin crank
bws 100 jug and head
all i did was 4 hours of porting and install the longer head studs everything else fit right in
you gotta use the 16mm crank flywheel and varaitor thats all
and im running a airsol head from a 70 due to higher compression the stock head was domed way out and ran low compression.
2004 zuma "AKA TANK" 2t 70cc liquid cooled ;)
63mph flat ground gps confirmed
** SUMMER SALE Z50/125 FOOTRESTS 45.00 SHIPPED ** pm me for details
Zuma 50, Zuma 125 Highway pegs/Footrests, NEW LOOK/DESIGN 50.00 SHIPPED
Mon Mar 28, 2011 1:09 pm
i thought you were useing parts form a 100 cc atv not an actual bws 100 parts
Mon Mar 28, 2011 1:38 pm
