View unanswered posts | View active topics It is currently Thu Apr 25, 2019 7:06 pm
Reply to topic  [ 14 posts ]
 Nology Hotwire install
scooters and mods: modded 05 zuma and 06 R6
Post Nology Hotwire install
I just installed this on my 05 zuma and was pretty happy with the results. Its not going to blow your mind with massive horsepower of course but I noticed a little more power and better throttle response. Its worth your hard earned or not hard earned dollar. As the story goes energy from your coil is accumulated in a capacitor built in to the nology wire.Once the electrodes reach the ionization point all the stored energy in the capacitor is discharged at once.Results are a 300 times more powerful spark.So after all that take the coil and spark plug unit off you scoot. Your going to need to take the lower plastic off.If you don't know were the coil is its at the other end of the spark plug dummy.Once thats off you need to cut the coil wire 2 inches off the coil.Don't be scared.Then you simple screw in the adapter until the wire snugs in its new home.Then cut the nology wire to desired length.You must leave at lease 2 inches after the capacitor.Thats in the thick part of the wire so 2 inches from the thick part.Nice.Now screw the nology wire in to the other end of the adapter.Just like you did with the wire on the coil.Oh crap don't forget to use the heat wrap that came with the wire.Alright now put it back together.Once the plastics back on and the coil is reinstalled you need to ground the braided wire.I grounded mine to the battery.I just cut a little slit in the battery firewall.See the pics if you don't understand.Youll get it.Now screw the adapter on the spark plug that came with the kit and hook up the wire to the plug.There you go your ready to rock.I also use a malossi cdi unit but you dont have to.Don't be cheap either get a new spark plug and a nice one your scoot deserves it. Hope this helps. Fly high stay low young brothas
viewtopic.php?f=50&t=5614&start=300
Wed Apr 08, 2009 10:32 pm
scooters and mods: 08 Zuma 50 with some mods
Post Re: Nology Hotwire install
Very nice write up. I have been wanting to do this for awhile, just not sure about results versus dollars. I think I have made up my mind.
Thu Apr 09, 2009 8:34 am
scooters and mods: Z50, leo v zx, athena 70cc sport kit, stage 6 variator kit, stage 6 racing drive, malossi x wide belt, integrated tailli
how much was it? and where did you get it from?
05 BWS
Athena 70cc sport kit
LV ZX
Stage 6 Variator Kit
Thu Apr 09, 2009 11:38 am
It was $44.95 from zumasrus. I think they are also known as calamari.They were really helpful and I recommend ordering from them.
Thu Apr 09, 2009 1:19 pm
As another bit of info I redid and cut the coil wire about 1 inches from the coil. I heard 2 inches from the coil and 2 inches from the capacitor.I left 2 from the capacitor but about only 1 inch from the coil.I think you just need to leave room for the heat wrap on the coil side and you'll be fine.And go!
Wed Apr 15, 2009 9:26 pm
Did you notice any performance increase?
'05 Zuma
Pirelli SL26
LV ZX (custom black)
Athena 70cc bbk
Polini Super9 Variator
Fri May 01, 2009 12:41 pm
I just did the same mod along with an adjustable needle from TC. I noticed easier start up and better throttle response.
Fri May 01, 2009 12:49 pm
scooters and mods: 2003 Zuma (5500 miles) with Dual Headlight Mod and Integrated Rear Turn Signals
No offense to anyone, but I think the "performance increase" is either the new plug or the good ol' placebo effect.
2003 Zuma
JDM taillights
Dual headlight mod
Michelin Bopper tires
Fri May 01, 2009 1:10 pm
scooters and mods: 08 Zuma, Corbin Seat, Throttle Mod, Dual Headlights, Michelin Boppers, LeoZX (on order)!
You can tape a 50 dollar bill to you front fairing and it "FEELS" faster too. :q:
Really though all that matter is you are happy with it.
And I do appreciate the GREAT write up and pics - Good job :toot:
2008 Zuma 70cc (TP Trophy BB) CF Reeds, #85 main, Corbin Seat, RRGS Shock, ZX pipe.
2008 Zuma 70cc (Athena BB) #84 main, ZX Chrome pipe. My awesome wife's ride.
Athena Vari, SL-26 shoes, C3 mirrors on both.
52-53 mph (GPS) top speed on both!
Fri May 01, 2009 1:56 pm
Ya I really did notice a increase.Like I said before Its not going to give you massive gains but I noticed I difference or ya you could tape 50 bucks to your fender.
Fri May 01, 2009 3:54 pm
scooters and mods: 08 zuma 50, stage6 sport mk2, athena variator, 17.5 dell carb, leo vince zx r, dr pulley sliders 6.5g • 6, athena 15/50
I need to get this wire. My scoot has several mods, its just missing the nology hotwire and the helical tall gears. Just ordered front and rear brakes and rear tire. Got ALL my parts from zumasrus or calamari. They actually answer the phone when you call... Old post I know but it something I need. Hopefully some other folks can discover this inexpensive tune
2008 Yamaha Zuma 50
Stage6 sport pro mk2
17.5 dellerto carb (athena)
Leo Vince zx-r pipe
Dr pulley sliders 6.5g • 6 = 39
Athena 15/50 gears(14/42's coming soon)
Nology hotwire
Dual headlight
T mod
NGK br9hs spark plug
Mon May 13, 2013 4:42 am
just installed the hotwire and it helps... seems like their is a tad bit of hp gain but that could just be strong spark. anyways, well worth the $44.95
2008 Yamaha Zuma 50
Leo Vince zx-r pipe
Nology hotwire
Dual headlight
T mod
Mon Jul 22, 2013 8:55 am
scooters and mods: currently building.....
Where's your sig line homeboy? I wanna see what your working with....hopefully you'll consider.
2005 Zuma-MKII Race, MKII 21MM PHBG 40/92, C16, 12mm Crank, B9HS/LBO5EP 5K Cap, Advanced Timing, +1 Ignition Coil, Premix 32:1, Derestricted Intake, VF3's, MHR OverRange Complete, 27 grams, MHR Delta Clutch, MHR Wing Bell, Red Contra, Blue Springs, Torsion Controller, 15/50 upgears (SOON 14/42), Oversize Fan, Snork removed, Start Block Off Plate, Throttle Cable and Single Pull Tube, Dual Headlight Mod, Integrated Rear Signals, Boppers, Tach/Temp Gauge, kickstand.
I GOT MACHETES AND SWORDS FOR ALL YOU FAGGOTS THAT ROAR....Image
Mon Jul 22, 2013 11:26 am
I notice no difference and I took mine off and sold it. I got the motor force coil and wire combo and that did make a big difference.
Tue Jun 16, 2015 3:37 am
