View unanswered posts | View active topics It is currently Mon Feb 19, 2018 7:10 am
Reply to topic  [ 31 posts ]  Go to page 1, 2, 3  Next
 Zuma 125 Top Speed
Zuma 125 Top Speed
Poll ended at Thu Jun 02, 2011 8:50 pm
50-60mph 32%  32%  [ 12 ]
60-70mph 55%  55%  [ 21 ]
70-80mph 11%  11%  [ 4 ]
80-85mph 3%  3%  [ 1 ]
85-Haulin burro! 0%  0%  [ 0 ]
Total votes : 38
 Zuma 125 Top Speed
Post Zuma 125 Top Speed
What is your top speed?
Wed May 18, 2011 8:50 pm
Post Re: Zuma 125 Top Speed
MAX 62GPS verified.. drafting or downhill but still had some left.
NORMAL RIDING 54GPS verified.. flat no wind, no grade
"I'm your Huckleberry..........."
1990 CW50TA Zuma II Black and Yellow *SOLD*
2009 YW125B Zuma 125 Mine is Black SOLD
2009 YW125Y Zuma 125 Hers is Yellow*SOLD*
Wed May 18, 2011 9:05 pm
Yeah I'm at about 55mph as well.
Wed May 18, 2011 9:09 pm
I can bounce off the RPM limiter at 62 (indicated) if conditions are perfect.
Stock motor with a pipe, 10.5 gm rollers, Simota filter, and an old skool Juice Box. :cheers:
Wed May 18, 2011 9:31 pm
I can hit 65 indicated flat ground no wind in a full tuck, 65+ with a tail wind, drafting, or downhill. Very happy with the TST vario and 10/12g weight combo. Still haven't hit the rev limiter with this set up but with stock vario I hit it at 62 like said above
09 Zuma 125, TST vario, FRC TD, Simota AF, BWS front with HID, RRGS brake levers, 12t gear
Thu May 19, 2011 12:57 am
got better top end until the state added extra mandates to what is mixed with the fuel. speed and mileage both dropped some after that.
Thu May 19, 2011 5:32 am
want good reading, go back years and look up here when the 125 was first coming out but no one had it yet, the estimates were in the 70's :eng101:
too bad no one was correct :(
im at 55gps or 60speedo been up to 70speedo downhill
Thu May 19, 2011 7:36 am
Rider weight, tire inflation, wind, and incline all play a role in the speed this little monster can kick out. Put a <150 rider on slightly over inflated tires going down a slight incline with a fair tail wind and a warm engine on a totally stock bike except for the hook I bet he could top 70.
Thu May 19, 2011 9:36 am
Honestly I don't really care about top end speed, I just love torque.
Thu May 19, 2011 9:45 am
My 155cc Zuma hit 70 MPH indicated. . .
with an after-market pipe,
32mm throttle body,
stock ECM,
final drive gears upgraded from 8.5:1 to 10.5:1,
and the typical clutch-bell-variator-sliders upgrade.
If I remember correctly top speed was about 52 MPH when she was bone stock and bran-new.
In short I was very pleased with the results of dumping $1500 worth of gadgetry to gain 18 MPH. It made the bike "drivable" in fast moving cage traffic.
Yamaha did an excellent job when building those little bikes. Image
-Ej-
Current stable: Suzuki DL1000K6, 2006 Harley Sportster Custom, two old mopeds and a pair of sneakers.
Thu May 19, 2011 10:26 am
Well you did create this post about "top speed".
Thu May 19, 2011 10:41 am
Yeah I know. it's just interesting to see what people have done to their scooters.
Thu May 19, 2011 10:48 am
I hit the RPM limiter at about 65ish mph -
But i can get to the rev limiter in under 10seconds - Torque is Mad Crazy -
Thu May 19, 2011 11:22 am
OK... Who voted for "Haulin burro?"
Thu May 19, 2011 11:26 am
The poll should have been done in increments of 5 mph instead of 10
Yamaha Zuma 125
Buell Blast
Adly Thunderbike 50
Thu May 19, 2011 1:54 pm
