Author |
Message |
dragstart
Joined: Sat Oct 11, 2008 5:01 pm Posts: 415 Location: Port Orange, Florida
 Faded plastic
My plastic panels have been sun faded and stained from spilling gas on them. What's everybody doing to restore them to some sort of acceptable appearance? And before you say bumper black...........that don't work anymore. Way beyond that.
Tue Aug 04, 2015 9:00 am |
ZUMIKE
Joined: Fri Jun 25, 2010 6:56 am Posts: 14281 Location: San Diego, CA
 Re: Faded plastic
I carry armor all wipes in my trunk for the rare occasion I spill gas so I can wipe it up fast because it instantly dries white
my bike lives inside a garage covered, is 5 years old and still decent black plastics I keep silicone spray on them, thats the only thing I use on my entire bike I dont even wash it
I would just drop the money on new black plastics, and then try to keep those as new as possible if your bike stays outside then buy a bike cover and find some product to treat your new plastics, so they will last much longer over time
all the stuff you could put on them to turn it back to black usually lasts a couple days, or hours depending on how bad it is because that dried out plastic just sucks in any grease or oil you put on it
2010 Zuma 155cc BWS X Digital Gauges<>Clear Smoke BWS 125 Turn Signal Covers<>Billet Bar Ends<>Front Brake Rotor 260mm<>Razor Cam Covers<>NCY Breather Assembly<>Polini EVO Clutch Bell<>Anodized Orange Dipstick<>RRGS Front and Rear Shocks<>Dual 5000K HID's 35w High/Low Beam<>Black Adjustable Brake levers<>Halo Led's<>TST 2 Stage Variator 9gL 10gS <>NCY Oil Cooler<>Yamaha Skid Plate<>NCY Contra Spring Bearing<>1000 Rpm RRGS Contra Spring<>Yoshimura Exhaust<>NCY Direct Ignition Coil<>Lightweight Cooling Fan<>Koso Cable Clamps<>High Lift Cam+Lightened Cam Sprocket<>Underseat Storage Bag<>Stage 6 (Koso) Clutch<>Accel Handlebars<>Koso Brake Light<>Lightweight Swingarm<>RRGS 4 Pot Caliper (PH80)<>Stainless Braided Brake Line<>Lightened F|ywheel<>OEM Headlight Screens<>Zubiku Wing<>Air Horn<>9 inch stretch<>Koso High Flow Filter/Cover<>RPM 10 Spoke Wheels<>Digital Camo Vinyl Wrap<>SEP Cvt Covers
Tue Aug 04, 2015 9:22 am |
HotSoup
 Re: Faded plastic
Holloway House floor shine
Tue Aug 04, 2015 1:27 pm |
zuma125nr
Joined: Sat Mar 01, 2014 2:18 pm Posts: 36 Location: Carlsbad, CA
scooters and mods: 13 zuma 125 - stock
 Re: Faded plastic
I've used a product called "forever black" on my car that dyes the plastic and actually lasted a good 2.5 or 3 years before i got some more of it. It works really well for plastics but i would think it might be hard to work with for a zuma floorboard with all the different contours/grooves it has... worth a shot - its just over $10 and stays pretty durable. Make sure to do multiple coats... i probably did 5-6 this last go around with my car and it turned out much more even than the time before where i probably did 3 coats. http://www.amazon.com/Forever-Black-Bum ... B000FOIJXQ From a car forum that i found it on that has a good before/after comparison http://www.toyota-4runner.org/3rd-gen-t ... -rack.html
_________________ Zuma 125 - mostly stock dual headlight, koso afterburner-like tail lights, smoked clear lenses on the front/rear turn signals, carver surf rack, milk crate, Simota air filter, green wrap on matte black panels, c3 mirrors
Tue Aug 04, 2015 5:17 pm |
willie634
scooters and mods: 2009 50cc
 Re: Faded plastic
_________________ 2009, 70cc Black Trophy TP, 15/50 Gears, Long Belt, Oversize Fan
Sun Feb 12, 2017 12:24 pm |
downriverzuma
 Re: Faded plastic
Sadly my 2009 Zuma 125 that I just bought used December 2016 was stored in a schools maintenance garage and was never covered once, needless to say that none of my black plastic was black anymore. Not a single "get black back" product worked on it. All just scams for $12 to $20... Who wants armor-all covering everything? The floor deck would feel like a sheet of ice! From what I could tell my bike was being used as a work horse and bags of salt were even being hauled with it at times. So on top of being severely faded, all of my inner black plastic was really scratched up. I opted to paint everything with satin black rustoleum spray paint. Some parts, like the headlight bezel surrounding the head lights for example required a coat of 2X primer before the satin black would properly lay down. I highly recommend the 2X rustoleum grey primer before painting anything plastic, all of my body panels were primed with 2X before I laid the paint and clear coat down. My black plastic looks great now and water just beads right off it at the wash. Notice the color difference on the bottom plastic since it has not been painted yet.
Fri Mar 31, 2017 10:59 am |
UneasyRider
Joined: Thu Nov 03, 2016 9:13 pm Posts: 44 Location: SoTex!
 Re: Faded plastic
Back to Black is supposed to be good too
_________________ 2014 ZUMA 125 / RC TST Kit / Air box mod
Fri Mar 31, 2017 5:54 pm |
bltrouble
 Re: Faded plastic
This stuff right here. I think they actually don't have the green can anymore but if you can find one, get it.
Sat May 13, 2017 5:01 pm |
dechralz
 Re: Faded plastic
Try using 303 protectant. It won't make the plastics really black but it offers UV protection.
Wed May 24, 2017 4:00 am |
Lamb K 55
 Re: Faded plastic
Cover those unsightly plastics with SHAG!!!
_________________ https://www.facebook.com/RCscooters http://www.rcscooters.com/
Wed May 24, 2017 6:44 am |
Joined: Tue Jul 06, 2010 11:06 pm Posts: 2496 Location: Taiwan & Hawaii
 Re: Faded plastic
i tried heat gun, it doesn't last, plus very easy to mess it up and melt the plastic.
some type of protectant or rejuvenator. some gets greasy or leaves a film. some you have to redo after washing it. really depends, so many products out there.
finally in the end i just rattle can it, better then new and doesn't wash off. i prefer satin flat black, gives it a deep look with a slight sheen.
_________________ RC Scooters Race Concept http://www.rcscooters.com HOEDAR ECU, GJMS, HOBAO, KOSO, PG, viewtopic.php?f=54&t=16410 <------ RC R&D
Wed Jan 03, 2018 3:49 am |
