View unanswered posts | View active topics It is currently Sat Jun 23, 2018 11:03 am
Reply to topic  [ 8 posts ]
 which front hub to use one aftermarket rim?
Post which front hub to use one aftermarket rim?
Hi guys I've searched this topic and nothing came up... I recently purchased an aftermarket set of rims for my zuma 125 front is 12x4 rear is 12x7...I got the rear figured out converting to single shock...but searching for a front hub only hubs I can find is for the ruckus. Anyone have any idea everyone I'm emailing like rc scooters, makoa Scooter, and machined machines are saying it has to be custom made and I would still need adaptors for the rotor...can't I just use a ruckus hub and convert to a 3 bolt 220 mm rotor?
Sun Dec 06, 2015 5:55 pm
Post Re: which front hub to use one aftermarket rim?
I would assume any 12mm axle size hub could be made to fit
you just need to hope the rotor size will match up with the caliper
look for those $75 monkey hubs found everywhere and try to get a rotor the same size as whatever you use
you can space out the rotor to fit into the caliper after the wheel is centered
probably will loose the speedo pickup though
and some zumas need to read the wheel spinning in order to make the bike run normally
Sun Dec 06, 2015 6:50 pm
Was looking into an atr hub from steady garage...what is the factory size rotor? And I already took my cluster off and eliminated my speedo cable with no issues
Sun Dec 06, 2015 7:14 pm
I think its 240mm
Sun Dec 06, 2015 7:29 pm
Solved the problem...I used an Atr hub from a ruckus and a 220 mm 3 point rotor from a ruckus...have to space the caliper and and make a spacer but it work just fine...for the back if you are going fatty it has to have a 4 inch back spacing...most ppl say use a 3 inch but thats for the gy6 motors the zuma 125 use 4 ...
Wed Feb 10, 2016 6:46 am
Pics or it didn't happen.
Wed Feb 17, 2016 12:38 pm
Pics in my phone to big to post any help?
Thu Mar 03, 2016 8:07 pm
need to use photo hosting website
photobucket is one type, should have an app for your phone you can upload from the phone to that site
then take the link codes and paste into this website
most all websites will be this way to post images
Thu Mar 03, 2016 9:26 pm
