View unanswered posts | View active topics It is currently Sun Sep 23, 2018 9:23 pm
 engine spec,
Post engine spec,
hi fellas, can someone please clarify, i have looked over the engine spec for the 125cc zuma / bws and its saying 4v...
is this correct, it looks a lot like a 2v engine to me
Engine[edit]
The engine is a 123 cc 4-stroke SOHC 4-valve with 10:1 compression. The fuel injection system is similar to the ones installed on most Yamaha bikes, and uses a 24mm injector. The exhaust manifold comes equipped with an O2 sensor. The rated power output is close to 11 bhp (8.2 kW).[citation needed] After the break in period, the Zuma 125 can achieve a maximum speed of around 61 mph (98 km/h).[citation needed]
This same engine (minus the fuel injection) is also used in Yamaha's Cygnus-X scooter. There is currently an established aftermarket with numerous parts that allow the engine to be enlarged up to 287 cc.[citation needed] Depending on driving style and riding conditions, the Zuma 125's fuel economy is around 89 mpg-US
Sun Jun 05, 2016 12:57 am
Post Re: engine spec,
the head on a stock z125 / bws 125 engine is 4 valve. 2 intake 2 exhaust.
2011 BWS-125 - Michelin Power Pure SC (oem sizes) / GJMS Low Down Forks / GJMS GP2 40mm lowered rear shocks / GJMS 260mm Rotor with NCY Caliper Adaptor / TST Variator / HARDY low handlebars / KOSO Clutch Bell / KOSO clutch / Daytona Kevlar Belt / NCY bearing kit / 1000 RPM Contra Spring / Zubiku : Carbon CVT Cover + Airbox Cover + Short Rear Spoiler / Simota Air Filter / Dolphin CNC Drain Heatsink / KOSO Afterburner Tails / Smoked Signal Covers / Race Fan / GJMS CNC Speedo Cable holder / dual 15w CREE LED headlights with ecode clear headlight housings.
Tue Jun 07, 2016 10:54 pm
thanks threshold
Wed Jun 08, 2016 9:01 am
