View unanswered posts | View active topics It is currently Tue Apr 24, 2018 2:07 pm
Reply to topic  [ 5 posts ]
 Rear Rack and oil
Post Rear Rack and oil
I have 09 C3 YF50YS
What oil do you use ? The book said 10 w 30 or 10 w 40 is that same oil you buy for your car ?
Is it hard to instil rear rack ? I'm thinking of buying one.
Thank you
Ty
Mon Mar 15, 2010 2:10 pm
Post Re: Rear Rack and oil
Yes, same oil as you buy for your car. Make sure you use mineral oil (non-synthetic) for the first 600 miles or whatever the break-in period is for the C3. After that, you can use whatever.
The rear rack should be easy to install if you know how to use a screwdriver or a socket wrench. You'll probably need some basic tools. Otherwise, the stealership can do it (but it really is piss easy and tools are cheap!)
Go fishing now - Chance to win a $250 Bass Pro Shops Gift Card
Mon Mar 15, 2010 5:17 pm
Hey thank you for the reply. My C3 it has only 24 miles on it so far. The rear rack just pick it up from ebay for $70. Just want to make sure about the oil one of my friends said use 4 stroke engine oil.
Tue Mar 16, 2010 4:38 am
Agreed ... use recommended weight of 'regular' motor oil until break.in !!
It's OK to use 4-stroke oil but, not needed. You don't have a 'wet' clutch that would require it ...
After that ... you can use the full-synthetic, blended, or non-synthetic.
ordinal wrote:
Yes, same oil as you buy for your car. Make sure you use (non-synthetic) for the first 600 miles or whatever the break-in period is for the C3.
Some people I know use nothing but full-synthetic, 4-stroke motor oil for the whole scoot. Engine & tranny ... after break.in.
Tue Mar 16, 2010 5:03 am
When you get that said scoot to 6000 miles get your drive belt replaced cause thats when they think it should be replaced. I went 7,000 on my 07 . It now has 10,033 miles on it now.
07 C\3 12,000 Miles 08 Zuma with 10,000 Miles
Tue Mar 16, 2010 9:20 am
