View unanswered posts | View active topics It is currently Tue Apr 24, 2018 2:15 pm
Reply to topic  [ 5 posts ]
 Mods
Post Mods
I thought I would post some pics of mods.lots of pics
File comment: new rack I fabbed up,yet to install.
all comments welcome good or bad...
File comment: 140/90 front and rear
File comment: homemade floorboards,powdercoated,
File comment: how it sits now ,with 1 1/8 inch bar adapters and carmichael mx bars
File comment: a section of angle for the mount,screwed in a few inches lower
File comment: cut out a section to lower the gauge pod
File comment: relocated the stock signal bulbs into the tailight
File comment: had to relace the flasher relay for the led blinkers
File comment: replaced blinkers,
ComposiMo,RaceConcept,ProTaper,KillerScooter,BTX,Two Bros Black Series, KOSO tails ,Standard Functions,PasswordJDM,GRP shocks,13/39 gears, 260mm Big Brake kit, RC Carbon Fiber wrapped BWS-X swingarm,Avon viper stryke 140 rear,130 front,LED blinkers,Yamaha JDM Headlight,Dr.pulley 10gm sliders,CustomDynamics LEDs,TomTom GPS...to be continued
viewtopic.php?t=14156
Sun Jun 13, 2010 3:30 pm
Post Re: Mods
Thanks for posting ...
That's one fine C3 ... very nice ...
Sun Jun 13, 2010 3:35 pm
Post Re: Mods
Great post. I miss my zuma only when it comes to finding inspiration for mods.
Please keep the posts coming. Interested if you've done any performance mods...
Curious in how your rear rack performs. I've wanted to get one but the Yamaha rack does not appeal to me either in price or Looks. If you create one for sale I would like to be first in line.
Furthermore, I started another topic about tire replacement. I've got the wifes approval for purchase just looking for some direction if you could be so kind as to answer.
Wed Jun 16, 2010 11:13 am
Post Re: Mods
Yo Daddy-O,I have not got the rack installed yet.It's taking a while to make sure I get everything lined up before I drill holes in the rear deck. The only performance mod so far is taking the metal screen off the back of the stock air filter,I also plan to remove the breather tube from the bottom of the air box. I have some different size variator rollers coming in the mail along with a side kickstand.I'll post some info when I have tested some of this stuff.
Wed Jun 16, 2010 3:48 pm
Post Re: Mods
I've just had a set of Polini "Performance Gears" installed in my C3.... They are higher, (3.1875:1 Vs the stock 3.58:1 gears.) My gps is showing 49.5 mph coming off of hills now. We're in the process of determining if a 2 Bro's Zuma125 "Juicebox" fuel controller," Useless above 125cc. Can be connected to my C3's injector + Ecu. If it works, I've got a K&N airfilter a buddy gave me and I'm going to spring for a jiangwayne exhaust system....With the mixture properly controlled, 50 mph may be possible with the gearing. We'll see! Gabe :patriot:
2007 Yamaha C3 Scooter 600 miles
2007 Yamaha C3 Scooter 14,000 miles
2010 Ural T Motorcycle - R/H shifter 7,000km
1980 Kawasaki KZ 250 ltd 3,500 miles
"You never need a loaded weapon, until you need one very badly!" SFC Hugh Lispcomb - Senior Drill Instructor - "Charlie, 4-2" Ft.Leonard Wood, Mo April 1974
Mon Jun 28, 2010 10:25 am
