View unanswered posts | View active topics It is currently Tue Dec 11, 2018 6:31 pm
Reply to topic  [ 17 posts ]  Go to page 1, 2  Next
 C3 "Bobber"
Post C3 "Bobber"
A buddy does custom mod work on high dollar boats, and motorcoaches. Recently, he tried his hand at cleaning up my scooter. Gabe :patriot:
2007 Yamaha C3 Scooter 600 miles
2007 Yamaha C3 Scooter 14,000 miles
2010 Ural T Motorcycle - R/H shifter 7,000km
1980 Kawasaki KZ 250 ltd 3,500 miles
"You never need a loaded weapon, until you need one very badly!" SFC Hugh Lispcomb - Senior Drill Instructor - "Charlie, 4-2" Ft.Leonard Wood, Mo April 1974
Mon Sep 06, 2010 8:10 pm
scooters and mods: 2005 zuma, 70cc kit, leo vince pipe, performance clutch, performance ignition coil, custom green paint, 4,000 plus miles
Post Re: C3 "Bobber"
Looks good!
2005 zuma custom green paint, 70cc kit, technagas 70 pipe, performance clutch, performance ignition coil, up gear, 21mm carb. , bopper tires, modified body, 4,000 mile's , "THE FASTEST *GREEN* ZUMA IN THE TWIN CITIES AREA"
Mon Sep 06, 2010 8:41 pm
Looks awesome!
How fast can you get a c3 to go these days?
Tue Sep 07, 2010 8:37 am
I'm about to find out.....I just installed an aftermarket intake/airfilter & exhaust. After lunch, we're going to program the fuel controller. www.dobeckperformance.com and see what my gps says.
Tue Sep 07, 2010 9:39 am
The stock exhaust weighs 12lbs, the airbox and filter 2lbs, the 2/3 of the rear fender that was chopped 1lb or so. The new exhaust weighs 1-1/2 lbs and the intake hose/airfilter/crankcase filter about 1lb. So, my scoot's at least 11 lbs lighter. :patriot:
Tue Sep 07, 2010 9:44 am
scooters and mods: 07 Yamaha C\3 and 08 Zuma
How fast is it. Mine would go 47. But now not sure. I would however like to find an aftermarket exhaust for it. Mine was stock till the muffler broke off. How much Better are those 4 GM sliders than stock weights
07 C\3 12,000 Miles 08 Zuma with 10,000 Miles
Thu Sep 09, 2010 11:44 am
See, i have an extra Zuma 125cc engine laying around. I really wanted to put it under a C-3!
What! yes, i said it..... :cheers:
Thu Sep 09, 2010 1:24 pm
I feel ya tilt I got a CN 250 cc & thinkin the same :2bong:
Sat Sep 11, 2010 5:01 pm
i need to do that to my scoot. mostly around the waist. oh wait, that's me. :doh:
getting the weight down is a good thing for any motorized transport. especially those with small engines.
a 250 replacing a 50cc engine would be a real monster. i'd like to see that.
Sat Sep 11, 2010 5:38 pm
Think "Big Ruckus!"
Wed Sep 15, 2010 11:35 am
The best I've seen up to now has been 43.8mph gps and 117mpg. I'm at 260lbs with helmet ,armored jacket + gloves.....
Wed Sep 15, 2010 11:39 am
urban assault wrote:
Looks good!
Thank you!
Wed Sep 15, 2010 11:40 am
I've got an '09 Z155 and my C3 has more room. A bigger engine would be sweet! You'd need a bigger fuel tank, and a way to stop it....
Wed Sep 15, 2010 11:43 am
I finally had time to have my airbox removed and a K&N high Performance airfilter installed.I often have my Dealer's excellent mechanic do things like this, as I've still got 18 months left on my extended warrenty....It keeps them in the loop... with all of the mods I've been doing! First thing I noticed is how sweet it sounds! There's much more power from takeoff to top speed.... Lost some top speed however. I kind of expected that, as we're guessing on what length of intake tube, will make best power, at what rpm. Midrange is stout, (Hills? What Hills?! :D ) but the power runs out at around 42 mph @ 7200 rpms. Next thing is to go to a local shop that has an exhaust analyzer, and dial in the fuel/air mixture with the fuel controller. Then, add length to the intake a half inch at a time, until top end speed maxes out. Where's a friend with access to a Dyno when you need one!? :) I'm about to need to replace the 120/90-10 rear tire, that's nearly as bald as I am! I think there's enough grunt to install a 130/90-10 tire in place of it, which is good for 2-3 more mph. I'll let you know how it progresses. Looks like I'm finally, about to be able to just ride it, and not be experimenting with it all of the time! lol! Gabe :patriot:
Thu Oct 07, 2010 9:47 pm
scooters and mods: Too many
lol cool
Mon Nov 08, 2010 6:31 am
Users browsing this forum: Google Adsense [Bot] and 3 guests
