View unanswered posts | View active topics It is currently Sun May 26, 2019 8:34 am
Reply to topic  [ 13 posts ]
 Gy6
scooters and mods: 2013 zuma 50, 2 brothers exhaust, kevlar belt. feign no rev limiter, tachometer. Watchdog alarm system w/remote start
Post Gy6
Will a Gy6 fit on a zuma 2013? I'm thinking of buying one instead of spending the money for a bbk. Any suggestions?
Fri Oct 21, 2016 12:28 pm
Post Re: Gy6
bolt on, probably not
don't forget you will need to do something with the wiring, ecu, fuel pump
most likely make engine mount, and shock mount
cheaper to get a zuma 125 once you crunch the numbers and time
Fri Oct 21, 2016 2:03 pm
Post Re: Gy6
Im guessing its a bad idea, huh? Thanks for the advice. I think I'd rather get a bbk. Do you know of a good bbk for the 2013?
Sat Oct 22, 2016 9:04 am
Post Re: Gy6
Why are you wanting to put a gy6 engine in your scoot
Several I know in Indiana talk about how strict the laws are
I know there was a big rally a couple years back and on the info given out the made sure to make a point that scooters able to go over 25 or 30 had to be plated
Sat Oct 22, 2016 9:47 am
Post Re: Gy6
Some of the laws have changed, we are now allowed to go 35 mph. But no one actually goes the speed limit around here, theres like a 7-10 mile window that police gives everyone. I traveled easily 40-45 mph with no issues because I'm actually just keeping up with traffic. I was only wanting a new engine because I seized my engine on the zuma, and the mechanic was recommending a big bore kit. It is going to be right around the same price in investing in a bbk, so i assumed that maybe just buying a new engine would be cheaper. But after your message it may just be cheaper and easier for the bbk. Is there a bbkit for a 50 cc that you would recommend?
Sat Oct 22, 2016 4:59 pm
Post Re: Gy6
your big bores are really expensive
and don't forget you will need to also purchase a fuel controller
which are expensive too
thats a lot of money, and still won't really go that much faster
but should be a little better up hills
see if steady garage has any, or drow sports
they are reputable sellers
I would stay away from the ebay big bores unless its a reputable seller
or its your only way to get one
how did you seize your engine
Sat Oct 22, 2016 7:47 pm
Post Re: Gy6
I have no idea how it seized my mechanic said rpms were too high but I was only running about 6000 at 42 mph. There was 20000 miles on the bike though not sure if that had anything to do with it.
Sun Oct 23, 2016 10:35 am
Post Re: Gy6
Dude I told you on DM that your tach was way off...you were prob running 11,000+rpm all day
Mon Oct 24, 2016 1:33 pm
Post Re: Gy6
only way that could happen is if an unlimited cdi was being used
was that the case
if it was not used the bike has built in rev limiter to prevent that
Mon Oct 24, 2016 2:49 pm
Post Re: Gy6
was that the case
According to him he did have one..
"I haven't did the air filter yet.. But even with just the no rev limiter and exhaust , I'm running at 46 mph with only 5600 rpm."
My stock 2014 maxes out at 9100 at 40mph so he deff blew his ish up haha
Wed Oct 26, 2016 1:50 pm
Post Re: Gy6
ahh
unlimited cdi requires a tach
and of course set at the right setting to read correctly
and never exceed 10,000 rpm
and of course make sure its not running to lean when doing any intake or exhaust mods
Wed Oct 26, 2016 2:32 pm
scooters and mods: 2004 Zuma with gy6 engine, long case, and plenty of duct tap and zip ties
Post Re: Gy6
I recently swapped out my engine on my 2004 Zuma 50 with a GY6. Wasn't anything wrong with the Zuma's engine, I just needed more speed. Came across a Taotao VIP 150 that had bad body damage. So now I've got the engine, mount, transmission and back tire just sitting in my shop. Wanna buy it? Lol
Fri Feb 08, 2019 9:13 am
Post Re: Gy6
post pictures and asking prices in the for sale section if you are serious
43 mph still breakin in Michelin S1 90/90/10
2004 Zuma Malossi sport 70 cc breaking in with stock pipe then Technigas next r polini 107 mm clutch polini green springs polini 2008 zuma torque driver high speed variator 5.7 grams 82 main jet 46 pilot jet needle 1 clip rich stock athena1 4/42 gears 11 to 1 final ratio 50 mph
Wed Feb 13, 2019 9:10 pm
