View unanswered posts | View active topics It is currently Fri May 25, 2018 11:33 am
Reply to topic  [ 85 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Yamaha ZUMAFORUMS.net gear for sale.
Post Re: New Zf stickers are here!!! Now 5 dollars shipped per pa
what's up with the chrome ones?
Fri Apr 20, 2012 11:57 pm
Think ive ot the chrome ones figured out. Have to use blue masking tape for transfer tape. Nothing else will lift the lettering off the backing.
Tue Apr 24, 2012 4:36 pm
Woot, payment sent
Fri Apr 27, 2012 12:57 pm
Just sent payment for a set of black stickers
2012 Zuma 125, 2 Bros exhaust, Simota air filter, NCY direct ignition, Lightweight fan, Race rear torque drive, NCY contra spring bearing, TST 2 Stage Variator, 1500 Spring, DDM tuning HIDs, Killer Scooter highway pegs, Clear Smoke BWS 125 Turn Signal Covers, YAMAHA C3 mirrors, KOSO Afterburner Taillight. Race Concepts 155 big bore, high lift cam, light weight cam gear, matched fuel injector, ported and polished head with over sized valves
Thu May 03, 2012 7:22 am
Got it. Let me see if i have any made up, if not, my roll of black will be here tomorrow.
Edit: Going in the mail today.
Thu May 03, 2012 7:38 am
I should be getting a roll of orange in the next few days, I know somebody at one point was asking about orange vinyl.
Fri May 11, 2012 7:21 pm
:cheers:
BWs50
Thu Jun 07, 2012 11:06 pm
You moonlight as a F22 Raptor pilot? sweet helmet
Mon Nov 26, 2012 10:05 pm
I changed the first post, these are now available at my webshop, DubbyaDecals.com
http://www.dubbyadecals.com/searchresults.asp?cat=1843
Tue Nov 27, 2012 9:41 pm
Old post, saw colors on website , but is there a white reflective option?
05, front /rear fenders gone, bar end mirrors,Leo Vince ZX-R pipe, bopper tires 120's front/rear, decals removed
Sat Dec 08, 2012 11:52 am
I'm a tard, was looking at your join date not post date. :doh:
Sat Dec 08, 2012 11:54 am
BWs wrote:
:cheers:
What helmet is that ? Is it black chrome? Me like !
Sat Dec 08, 2012 11:57 am
Just put through payment for the yellow ones. If I decide to get more are the small ones still an option?
Ruima Race fan, TBR black series exhaust, custom intake w/ modified stock air box, Oil regeneration elimination, Race Torque Driver, NCY Spring bearing, Dr. Pulley clutch, KOSO clutch bell, TST Hyperbolic variator, 1000RPM contra spring, Daytona Japan Kevlar belt, blue LED gauge lights, NCY orange cam breather, flush mount signals, KOSO afterburner taillight, rear fender chop, BWS headlight conversion w/ custom projector and top light w/ LED panels( with Halos), RC155 w/ camshaft, cam gear, ported head with larger valves, aluminum/ nikasil cylinder, matched fuel injector, 13/39 gears, dolphin valve cover heat sinks, TNT braced low bars, GJMS orange brake levers, MOS orange ignition cover, MOS orange speedo cable holder, MOS orange oil dipstick, MOS rear grab handles, orange transmission bolt
High Speed-Low Drag
~CHRIS~
Thu Jan 03, 2013 12:39 pm
Sent. The smaller 7" ones are pretty much the only size im doing. Not much demand for the 12".
Fri Jan 04, 2013 11:26 am
In the Select Country drop down it does not display Canada. Only United States.
2005 Yamaha BW's Orange with Flames
Top Performance Trophy 70cc BBK
Stock Carb 46 Pilot 84 Main Needle Raised 1 notch
Leo Vince TT Exhaust
Carbon fiber reeds
Stock Airbox Snorkel Removed
Malossi Variator 7g weights
Malossi Delta Clutch, Yellow Contra, Yellow Springs, Pivot plates closest to pivot (Hardest setting), Winged Bell
Stage 6 14/42 Upgears
Orange Trail Tech Tach/Hourmeter
Vented Trans Case
Shaved tail
Rear Turn signals relocated to brake light assembly, flush mount front signals
Tun'R carbon fiber mirrors
Sat Feb 23, 2013 9:45 pm
