View unanswered posts | View active topics It is currently Tue Sep 17, 2019 12:51 pm
Reply to topic  [ 83 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 OveRReV's trackday
Post Re: OveRReV's trackday
Crap! So thats what I have to look forward to??!! Let us know if you find something that lasts longer than the VL12....thats what I have too and will be going over a 5mm spacer.
Mon Dec 19, 2011 9:44 am
in my experience the original Moto Tassinari VF3 reedvalves will outperform & outlast any reedvalve on the market but they cost $150, they come with a free t-shirt though. LOL
well you don't need to change reeds if you don't ride it like i do most of the time but it should be good to check the reeds every 500kms just to see how the reeds hold up, here's a pic of my poor VL12, it was very good while it lasted.
apart from the viton rubber coating swelling & chunking out the reed tips were totally disintegrated at the corners exposing the ports of the reedcage, when this happens it's time to replace the reeds, this was a brand new VL12 with only less than 500kms of track use, the higher your setup revs the quicker the reeds disintegrate, 14K+ revs is just too much even for CF reeds to handle except for the MT VF3.
Overrev Tuning
Yamaha Aerox R
MHR Team 6T 70cc (max tuned) + MHR Team Crank + SKF 6204 TN9 C3 bearings + Malossi VL12 reedvalves + Yasuni C21 exhaust pipe + Keihin PWK28 carb + PVL digital inner rotor ignition + Polini Evo SS9 vario kit + Bando belt + Polini 128mm rear pulley + Malossi red vario spring + Malossi Torsion Controller + MHR black clutchsprings + Delta clutch + Wing bell+ Polini 15/42 gear kit + Malossi RS24 rear damper + Bridgestone Racing Battlax tires + Aprilia rally 12" wheels
my "humble" trackday toy, 90+mph.
Mon Dec 19, 2011 5:54 pm
dookie! Since im going to be working the cases over to match the reeds.....I just as well get the VF3 now I guess.
Mon Dec 19, 2011 6:27 pm
Very good to know. With my R1400 exhaust, I should be right around/just below 14k rpm. Where do you get the vf3 from? The only vf3 that I see on the websites is the S6.
Stage 6 race bore MKI-MKII wasn't available when I purchased the bore
Yasuni-R pipe
Stage 6 overrange kit-28 grams total on the rollers
Stage 6 overrange belt
OKO 28mm carb-144, 40 pilot
CT intake manifold
Stage 6 vforce reeds
Athena 14/42 gears-9.9:1 final gearing
Uni open filter
Stage 6 hpc crank-skf bearings
NGK wire-got it for free from the shop
br9hs plug
Starter (of course with the overrange trans) and oil pump removed
Some minor porting of the cases
2.5oz/gal on the premix 50:1
Stage 6 MKII racing clutch with the stock bell.
Mon Dec 19, 2011 10:03 pm
Moto Tassinari, you can buy them directly but it costs a bit more but it comes with a free shirt so be sure to demand it when you place an order.
anyway updating this thread with new videos, here's the first one with our friend on his Piaggio Zip SP with a full Polini Evo2 setup.
i'm coaching him on track riding skills & proper body positioning on his scooter, this is his first session but we encountered a problem which turned out to be very serious (cracked crankcase) which ended his day after the 2nd session, i let him ride my scooter though because i'm such a nice guy. ;)
Overrev Tuning
Yamaha Aerox R
Thu Dec 22, 2011 4:48 am
Overrev Tuning
Yamaha Aerox R
Thu Dec 22, 2011 5:40 pm
scooters and mods: 2008 ZUMA YW50
what kinda rpms are you pulling on the straight in session 3 mr. rev sir.? :awesome:
2001 ZUMAII - Tires TBD
Thu Dec 22, 2011 6:11 pm
i got no tach but for sure i'm running 14K to 14500 rpm, i have a fully ported MHR Team 6T 70cc kit with 198ex 132trans 124bst port timings, this used to be my drag engine so it's tuned for peak power. running 15g total weight in an SS9 evo vario & 128mm polini rear pulley, malossi red big spring with torsion controller.
Overrev Tuning
Yamaha Aerox R
Fri Dec 23, 2011 2:01 am
did I just read that z125 wheels will fit the front of a zuma front end?
Thu Jan 05, 2012 2:18 am
yes it can with a little ingenuity & probably the rear wheel too.
Overrev Tuning
Yamaha Aerox R
Tue Jan 10, 2012 2:13 am
scooters and mods: '08 Zuma 70, Old scooters.... SR50 stock and an SR70 Heavily modded.
I use to have the same problem on the track until I switched to VL16. They are lasting longer than my old VF3's
Wed Jan 11, 2012 10:43 am
Snugg are you running a Piaggio engine? Do these need to have the case/intake worked over to fit in a Minarelli?
Sun Jan 15, 2012 9:18 am
replaced the engine with new piston & ring, she pulls a bit harder & got back some bottom end power, ended up with 15.3g total & it's running out of gear way before the finish line, problem of blowing out the exhaust gasket came back to haunt me on the last few sessions so i need to get better gaskets for the exhaust port.
my friend's first time out on his Aerox (Evo1 kit, crank, ss9 vario, malossi or rear pulley, mk pr2 pipe, pwk28, vf3 reedcage, kitaco inner rotor)
my boys from the far north, travelled hundreds of kms just to do a trackday, it's a Beta Ark with S6 sport pro & other malossi stuff.
his buddy also running a Beta Ark with Sport Pro kit
passing a friend on the outside
turn 2
Overrev Tuning
Yamaha Aerox R
Mon Jan 16, 2012 6:42 am
WOT entering turn 4
extreme lean angle, tranny cover & lower rad only centimeters from scraping the asphalt, these tires rock
commercial break
Overrev Tuning
Yamaha Aerox R
Mon Jan 16, 2012 6:52 am
Is that a scoop on the bottom of the plastics?
Mon Jan 16, 2012 7:42 am
