View unanswered posts | View active topics It is currently Wed Jun 26, 2019 3:44 pm
Reply to topic  [ 181 posts ]  Go to page 1, 2, 3, 4, 5 ... 13  Next
 kayakbuilder's '99 budget (re-)build
scooters and mods: '08 Zuma, '99 Zuma
Post kayakbuilder's '99 budget (re-)build
The scooter had been wrecked and was given to me.
I traded a damaged horizontal Stage6 StreetRace BBK for a new vertical Athena Sport Pro.
I finally spent money ($30) on it today, and ordered a Motoforce FG reed, Stage6 small end bearing, and two (95 & 98) 6mm Dellorto jets.
Next is a new front fender.
Fri Aug 26, 2011 1:11 pm
Post Re: kayakbuilder's '99 budget (re-)build
Whats wrong with the one thats on it? :D
Fri Aug 26, 2011 1:14 pm
Here is the kit. The ports had already been chamfered. Initially I plan on keeping the stock Dellorto PHBN 12 carb and upjetting as needed.
Fri Aug 26, 2011 1:27 pm
It is just a minor scratch. Should I try to repair it, or should I replace it? All of the mounting tabs are broken, and it is in two pieces.
Fri Aug 26, 2011 1:34 pm
It will buff out.
Fri Aug 26, 2011 1:58 pm
Destickered! They were in bad shape.
Fri Aug 26, 2011 4:41 pm
buguy wrote:
It will buff out.
Outside
Inside
Fri Aug 26, 2011 4:59 pm
Any ideas on how to fasten an access panel with three out of four fasteners tabs broken off?
Fri Aug 26, 2011 5:03 pm
scooters and mods: 2008 ZUMA YW50
Glue on new tabs. :awesome:
2001 ZUMAII - Tires TBD
Fri Aug 26, 2011 5:15 pm
You "could" fix those panels with some fiberglass and a little filler. Also gluing new tabs works fine. I use wooden dowls from Lowes or whatever. Cut whatever length I need them, then just glue them on. Be sure to pre drill the screw holes though.
Sat Aug 27, 2011 7:25 am
What glue sticks to these panels? :confused:
I don't plan a permanent repair to the fender. Do you use Polyester resin for fiberglassing stuff like this? I always use epoxy, and found it doesn't hold very well on most plastics. 3M 5200 might do the job, but it expensive enough that I am better off getting new panels. :doh:
Sat Aug 27, 2011 8:29 am
you could also try using zip ties as a filler and plastic welding it
http://chinesescoots.forumwise.com/chin ... d3986.html
Sat Aug 27, 2011 8:40 am
Yeah I got a 3500 PSI plastic glue at Auto Zone that works well. And yes I use Polyester resin with the glass. Just rough the surface with some 180 grit paper first and clean it well. I think Wal Mart has a glass kit for $13 or something.
Plastic welding works pretty good too. I use black plastic hangers for my plastic welding.
Sat Aug 27, 2011 8:56 am
I've got loads of sandparer, plenty of dowels for pegs. I'll check out the plastic glue, and see if I can fab up some new tabs.
The tires need to be replaced, as they are badly checked. I am guessing they are originals. I may swap out my old bugeye tires onto this, as they still have a year or so of like left. If I like the thing, then I will buy new tires.
Sat Aug 27, 2011 10:56 am
Got the new Motoforce fg reed, S6 small end bearing, and Dellorto main jets (95 & 98), so now I can install the Athena Sport bbk.
Tue Sep 06, 2011 5:39 pm
