View unanswered posts | View active topics It is currently Sat Sep 21, 2019 11:20 pm
Reply to topic  [ 8 posts ]
 YAMAHA ZUMA PREBUG / mbk booster build
Post YAMAHA ZUMA PREBUG / mbk booster build
Hey everyone.
My scooter rides a lot better upgrading to a 70cc street kit. It can go 50mph with a 220lb person but with someone lighter it can possibly go faster. It's a good bike to have for daily rides around town. I couldn't really stop with the stock front brakes so I decided to upgrade to a RRGS front setup. The RRGs front setup brakes a lot better and looks way better than the stock forks. I had to get rid of the stock handlebar because it was to high and put BTX Drag Bars. Thanks to Drew at Drowsports for all the help and parts! I appreciated everything.
Here are parts I have on my scooter:
-BCD Engineering RX Handlebar Stem 22.2mm
-BTX Drag Bars
-Brembo Brake Master Cylinder
-CRG Hindsight LS Mirror (Black)
-Dellorto PHBG 19mm Racing Carburetor
-Doppler S3R Shock Black 275mm
-LeoVince ZX-R Exhaust (Vertical)
-Malossi Variator Multivar
-Malossi MHR Replica Yamaha Zuma
-RPM 9 Spoke Front Wheel
-DROWsports Ruckus RRGS Front Disk Brake Kit (Low Down)
(Got my triple tree bored out to get the forks to fit, Thanks to Drew for getting it done)
-Goodridge Stainless Steel Brake Line Kit 34in
-Goodridge Brake Line Banjo Bolt Chrome 10mm
-RRGS Axle Puller
-R6 Clear LED Tail Light Kit
-Perelli SL 26 [Front tire- 100/90-10 and Rear- 130/90-10]
More pictures of my Pre-bug will soon be posted.
Here's a preview.
More to come!
Thanks to Drew from Drowsports for all the parts again!
1999 Pre-Bug [-]RRGS Front Disc Brake setup [-]70cc Malossi MHR Replica Cylinder Kit(Vertical) [-]BCD RX Stem [-]BTX Drag Bar [-]Brembo Master Cylinder [-]R6 Tail light [-]RPM 9 Spoke Front Wheel [-]Doppler S3R Shock [-]CRG Mirrors [-]LeoVince ZX-R Exhaust [-]Drowsports T-Shirt
Tue Feb 21, 2012 11:25 am
Post Re: Pre-bug build thread
more pics of the prebug bro, nobody cares about stock photos, lets see pics installed!
Wed Feb 22, 2012 12:25 am
Agreed! Id like to see some more pics. Also there is an area for build threads here. Maybe a mod could move it over there with the rest of them for you?
Wed Feb 22, 2012 6:42 am
i remember riding this scooter when you just bought it and i thought there's no way i would ever ride it on the street. the brakes were just plain horrible..... squeezed the life out of the brake lever and could barely stop. hows the new suspension??? does it bottom out like how it did when it was still stock? man, i gotta ride that pre bug again with all the mods
Malossi MHR Replica 70cc
C16 (dented on the bottom thanks to our beautiful potholes/speed bump combinations)
Del Lorto 19mm
Stg6 O/R & Torque Boost / 5g rollers / Malossi Yellow Contra Spring
soon to be installed.....
Stg6 Racing Cyl Kit
Malossi Crank
Polini Upgears
Stg6 PWK21/rear facing manifold/reed cage
Fri Feb 24, 2012 12:38 am
Did those forks fit the stock tree?
Thu Sep 28, 2017 6:00 pm
Post dating a russian girl
bpd Symptoms
Bipolar disorder symptoms are seen as a cycling of mood swings between feelings of great energy and activity (better-known as manic or hypomania) And sounds of sadness, Hopelessness, And staying blue (Known as clinical depression). Bipolar implications come in cycles, Which tend to range from days to months at a time.The defining symptom of bipolar disorder (Also known as depression is the use of severe mood swings episodes between feeling great highs to feeling great lows, Including misery (American psychiatric Association, 2013). much more the highs, A person with bipolar symptoms may feel like "On top on the planet, Able to complete anything they set their mind to, With the desire to do a dozen things at the same time (Finishing not one of them). Sometimes this high appears as greater depression in the person, alternate to an elevated mood.continuing, The symptoms of bipolar disorder may masquerade as a problem other than mental illness. as an example, It may first appear as alcohol or substance abuse, Or poor functioning at school or work. Bipolar symptoms generally don't come and go quickly they are persistent and good deal impair the person's life (Caponigro shelter, 2012). effortlessly is sometimes prone to being misdiagnosed as depression, Because the person reviews hypomanic, rather than manic, episodes. (Hypomania can be mistaken for normal, Goal directed activity if not carefully assessed by a mental medical expert.)bipolar disorder in children is different, With a different set of symptoms. in youngsters, bipolar disorder is known as disruptive mood dysregulation disorder.based on the National Institute of Mental Health (2018), If not treated, Bipolar symptoms can worsen, And the person can on occasion experience full fledged manic episodes and depressive episodes. Treatment usually consists of blend psychiatric medications and psychotherapy, And some form of treatment is usually needed throughout most of a person adult life (Fink Kraynak, 2015).connected: what are the differences Between Bipolar (Manic panic attack) And dejection?This condition is treated with a mix medication and psychotherapy.Types Symptoms of BipolarThis condition is diagnosed based on the criteria listed in the diagnostic reference manual published by the American Psychiatric Association (2013):Bipolar I DisorderThe essential feature of Bipolar I is the fact that person experiences one fullmanic episode (Though themanic episode appeared to be preceded by and may be followed by hypomanic or major depressive episodes). in addition,, there's never been a full manic episode.Modifiers for a bipolar disorder DiagnosisThere are a number of modifiers to the diagnosis that can help a clinician communicate the exact type of bipolar disorder a person is experiencing.You can review the info on these DSM 5 specifiers for bipolar disorder. Cyclothymic disorder is comparable to bipolar II disorder, Except for a long time (2 times).People with effortlessly may either be rapid cycling through the different mood phases, Or slow riding a bike. In slow riding a bicycle, The person may spend weeks or months suffering from one type of mood before cycling to the other. In rapid swimming, A person may experience mood changes in a few days or weeks. Effective treatment helps reduce or stop the cycling most of the time (Fink Kraynak, 2015).DSM 5 codes: 296.89 (F31.81)Quick List of During a manic or hypomanic phase, Bipolar consist of:Feelings of sadness or hopelessnessloss Charmdate scam reviews of interest in pleasing or usual activitiesdifficulty sleeping; Early morning awakeningloss of energy and constant lethargysense of guilt or low self esteemdifficulty concentratingnegative opinion of the futureweight gain or weight losstalk of suicide or deathThe main method used to diagnose bipolar is a thorough clinical interview with a psychiatrist, psychologist, Or other mental medical adviser (Fink Kraynak, 2015). however are written methods for documenting the severity and number of symptoms, Those tests only enhance a complete interview. They do not replacement for a face to face evaluation by a professional. Like all mental complications, There are not yet any blood tests or other biological tests which can be used to diagnose bipolar disorder.An early bipolar symptom may be hypomania an emotional state wherein the person shows a high level of energy, Excessive moodiness or being easily annoyed, And impulsive or reckless behavior for four or five (4) sequential days. The symptoms related to hypomania tend to feel good, And so many times the person seeks to minimize the symptoms to others. Even when acquaintances learn to recognize the mood swings, anyone may deny or may not even realize that anything is wrong.One of the usual differential diagnoses for comfortably be managed is that the bipolar symptoms are not better accounted for by schizoaffective disorder and is not superimposed on schizophrenia, Schizophreniform syndrome, Delusional dilemma, Or other psychotic spectrum problems.And as with nearly all mental disorder diagnoses, The warning signs of manic depression must cause clinically significant distress or impairment in social, occupational, Or other important areas of carrying out work.This post has undergone an update for DSM 5criteria.to read more:Bipolar Screening TestBipolar QuizWhat is bipolar gloominess?therapy of Bipolar DisorderDSM 5 Codes for Bipolar DisorderReferencesAmerican Psychiatric Association. (2013). Diagnostic and statistical manual of mental disorders (5th ed.).
Fri Aug 02, 2019 12:41 am
Post Re: YAMAHA ZUMA PREBUG / mbk booster build
depart on a date
They're now courting in the age of technology, Where a man asks a woman out by texting her and inviting her to meet up with him at a bar or a cafe'. Some of his friends extremely there. or not. She should surface about nine or ten. whenever. anything at all.
One woman Williams interviewed said the word "a relationship" Should be removed from the dictionary, Since it's unlikely that dating will go back to what it was once. For generations, It involved a telephone call, Two women and men, A call, And a chance to get to know each other. Daters clothed, cleared up, Spent time with one another, Then decided if they wanted to do it all again the next weekend.
Speed dating hadn't been invented yet. Neither had online dating sites. aiming back on courtship, it seems as though everything flowed in slow motion, just how in which it always does in the river of memory. some of us swim in that river a lot. An old college friend just asked if I remember "The dating parlor,
affirmative, me. The dating parlor was the room where college men came to assemble their dates on Friday and Saturday nights. Even bad "parlor" Seems as quaint as the horse and carriage, But that maybe what the front room of the dorm or sorority house was called.
Here's how it performed. A student receptionist sat at a desk girl in spanish each night short shifts during the week and long shifts on the weekend. Her job was to announce on a phone speaker when each man arrived. The dorms at the college or university of Alabama were cavernous, And the receptionist's voice boomed out cover the floors, Declaring the woman and the fact that her date was there to pick her up.
Five a matter of minutes before, We appears to be wearing a helmet of pink, Plastic paint rollers or a tee shirt and pajama bottoms. But with that headline, There was a switch. We took our rollers off and dispersed our perfume on, Scents as thick and heavy as mosquito resilient. faves were "rainforest Gardenia" and also "ambush, Cloying smells that lasted all night.
We fixed ourselves up, Then came downstairs to the parlor wearing exactly the same flipped up hair, the identical Peter Pan collars, And the same circle pins as other girls. We wore pound loafers, Plaid pleated dresses, And jumper sets.
previous to we left on our date, We fixed out in the "court book, a major, Black notebook that kept an eye on our comings and goings. We using our date to go to a pizza parlor, A fraternity fly, Or see a movie, Then raced oh no - the dorm or sorority house where we signed in, Got kept in, Or got revealed up for "Late a few minutes" If we arrived in past curfew.
If we accrued enough late moments, we had to pay a fine or, worse still, Lose the opportunity of dating the next weekend. It was the University's equivalent of putting us in "day out, And we attemptedto avoid it. Who wanted to watch old movies on television with the sorority housemother when the band was playing just across the road and the dancing had commenced?
It is obvious why a co ed occasionally broke free, staying out thirty minutes past lock up. circumstances she was caught climbing into a window, Like some kind of cat burglar, And sometimes she set off the alarm by brazenly walking in the gate of the sorority house, Like she was a grown spouse.
Then there would be the "Judiciary an opinion, An earnest team of girls that gave out warnings, Like driving to fast tickets. So many warnings and you had to face the outcomes. If you came in past night time, You might just turn into a pumpkin, Like in the story book. Only long time later, When curfews were dropped and women were allowed to have their own hours, Did the dating site scene change.
these days, many years later, We've gone from one extreme to one more, inside lock up to the hook up.
The dating parlor's closed with great, But there's online dating and speed dating and group dating. an ancient student of mine likes the no frills, No pressure way people her age date lately. nevertheless, states, on occasion, Roses may be nice.
Sat Aug 10, 2019 3:18 pm
Post CHARMDATE SCAM
focused with regard to Dublin housing recorded
Dublin, 14 july 1918 a big newest homes charmdate scam motivation, which will cost as well as transport any minimum of 16,500 other sorts of houses for many construction personnel, must be integrated in the location of Dublin. Cowan, Chief anthropological Inspector with the town aboard and then listed in the chief secretary, edward cullen Shortt, goes in jan such year and also bed sets out the following the way accessories:
14,000 another self contained people's homes of the the necessary level to allow a split up genders, that includes scullery and as well,as well as the WC flat for a common use of each and every relative
in all of, mr Cowan nations that there is a need to allow enjoyable hygienic residences for 27,000 family members; the item weight CHARMDATE was being trendy because of a departmental panel just about four these days. after that 936 tenement listings, the place 3,989 young families seemed to be housed, was first cancelled by this provider. In a matching four year period, except 327 modern lets were definitily engineered.
Selfridge declines Dublin whispers
various other Dublin possessions media reports, Gordon Selfridge, who owns the Selfridge shopping district on the united kingdom Oxford block delivers rejected whispers which he had gained premises in Dublin obtaining find to opening organization in the city. are very few case inside policy he shared with a press reporter during the time questioned at the puppy's Oxford freeway practice.
[manager please note: it is deemed an article produced by Century ireland in europe, A fortnightly online journal, released ones belief for the surgeon 100 common, for data documents of the time.].
Fri Aug 23, 2019 6:12 am
