View unanswered posts | View active topics It is currently Mon Sep 23, 2019 4:46 am
Reply to topic  [ 70 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 My scoot
Post Re: My scoot
corrosion wrote:
I never felt the need. I barley use the front brake. From what I can see looking at the pics of things it is a mater of matching the caliper mount & rotor.
I did a custom front wheel and had to do the spacing to center the caliper. Then remount of the rotor. It was not that hard. I got the hardware & spacers from McMaster Carr. They have anything you could possible need in hardware. I would watch the hydraulic end of things. It gets a little harder there.
Summit Racing has a lot of the Hydraulic fittings.
I have heard that simply changing to SS brake hose improves the braking feel & response. I may do that.
Thanks for the info.... I'm wanting to do it more for the looks then anything. I found a wave brake disk made buy polini that I might pick up, then paint the caliper to match the bike.
dppdaddyyo wrote:
love tht speedo vvhere did u get dat
Scooter attack
Tue Mar 26, 2013 6:33 pm
Post Re: My scoot
When & if you pull off your Caliper. Fold up a stick of cardboard, roughly the same thickness as your rotor. I keeps the pads in there grooves. If they come out its not the end of the world, just a PIA with the anti rattle clips.
Post up a link of the rotor's you got me interested now!
Tue Mar 26, 2013 8:30 pm
Post Re: My scoot
http://www.adrenalin-pedstop.co.uk/p/Po ... -2996.aspx
Tue Mar 26, 2013 8:55 pm
Post Re: My scoot
What do you think? Should do the trick eh?
Tue Mar 26, 2013 9:08 pm
Post Re: My scoot
I have got parts from them guys. They have stuff no else has. That rotor they illustrated is a 4 bolt rotor. My Zuma is a 3?
Tue Mar 26, 2013 9:10 pm
Post Re: My scoot
http://www.adrenalin-pedstop.co.uk/p/Po ... -2998.aspx
It's out of stock here, but they have it at easyparts.nl. I've ordered a bunch of stuff from them, the stuff comes super fast and they generally have everything in stock.
I've never heard anyone talk about easyparts.nl before, but I'm tellin ya guys its a honey hole for good parts. Check it out
Tue Mar 26, 2013 9:36 pm
Post Re: My scoot
http://www.modcycles.com/mm5/merchant.m ... Brake_disc
Hey I can see my House..........
What you think of this one. I ordered 2
Sat Mar 30, 2013 7:21 am
Post Re: My scoot
Looks good to me, let me no how it works for you.
Sun Mar 31, 2013 10:33 am
Post Re: My scoot
just finished installing a S6 sport pro mkII kit. Went together super smooth cant wait to put some miles on it. The top trophy i replaced had 4000 kms on it and still looked new.
Sat Jul 06, 2013 7:49 am
Post Re: My scoot
I just realized I never got back at you about the Rotor,s. They sent the wrong ones twice. I am not paying the return shipping twice.
You will like the S-6 sport. One of my quickist streetable builds was a MK-I, Sport teamed to a C-16. They don't match, I know.. but work well with a medium contra and good weight choice.
Sat Jul 06, 2013 8:51 am
Post Re: My scoot
Shitty deal about the rotors. I just took it out for its maidan voyage. I haven't really got on it yet but from what little time I do have on it, it's way quicker then the trophy ever was. I just hope the crank makes the summer, it's getting pretty tough with my set up now to keep it under 10,000. I'm going to do the crank this winter, but I really should have done it with this new kit I put on :doh:
Sat Jul 06, 2013 9:20 am
Post Re: My scoot
What crank will you get, 10mm or 12mm.
I have a full circle 10mm crank. I got it for my sisters Vino 50. She told me it had 4,300 miles on it and wouldn't run. I bought up a bunch of parts., I had envisioned a complete overhaul after talking to her about it. I and went to pick it up. It had 430 OE miles on it. IT WAS LIKE NEW.... See wanted a Vespa. So it had to go.
Sat Jul 06, 2013 1:45 pm
Post Re: My scoot
What brand of crank is it? Do you have the bearings and seals? And how much $
Sat Jul 06, 2013 2:19 pm
Post Re: My scoot
Side stand installed with the corrosion mod (thanks again). Still can't believe the old lady lets me park this thing inside during the winter
Sun Jan 26, 2014 11:40 am
Post Re: My scoot
Put it on some cardboard, at least if some thing drips. It's on Cardboard. I got one in the kitchen, 2 in the living room, one under the breezeway. I need to sell one or two. My mistake is, I take them for a ride and talk myself right outa it...
You really did a nice job with your Zuma.
Sun Jan 26, 2014 12:22 pm
Users browsing this forum: Prastitnya, VincentWen and 2 guests
