View unanswered posts | View active topics It is currently Mon Sep 23, 2019 4:43 am
Reply to topic  [ 69 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Couch scoot build, come on in
scooters and mods: 2005 Zuma
Post Re: Couch scoot build, come on in
He's talking about when you install the bbk. If your keeping the stock carb, you'll need to buy a couple of jets for the tk carb.
I run 130/90/10's front and back and I may have lost a mph not really sure though. I don't really notice the speed decrease but the handling and ride definitely outweighs the loss a tiny bit of speed.
Top Trophy 12mm Piston / Polini Head -- Stage 6 12mm HPC Crank
Blk Del 19mm PHBG / 88main, 45pilot, W9 1st clip, Vented Airbox
Moto Tassinari VForce3 Reed Block -- MotoForce Intake -- TNT Adj Oil Pump Y-Plate
Leo ZX -- Stage 6 Sport Pro Vario -- S6 MKII Clutch & CNC Bell -- 15/50 gears
STR8 Oversize Fan -- Dual Headlight / Slim Tail Light -- Flush Front Signals
Sidestand -- SL26's 130/90/10 Front & Rear
Mon Nov 19, 2012 10:31 am
Good to know on the front tire, thank you. I planned on changing the carb when i get the bbk. Until i get everything delivered to me i will keep it stock. Right now im just stocking up parts
2003 zuma 50:
Top Performances trophy70cc
stock carb 46pj 90mj
Stock airbox with snorkle
leo vince zx-r
carbon fiber reeds
ncy107mm clutch
ncy107mm clutch bell
Mon Nov 19, 2012 11:10 am
That's the way to do it. Just ride stock until you're ready and read as much as you can while you stockpile parts. If you run into any issues and need parts for your trophy, let me know I've spare parts I never used when I ran the trophy.
Mon Nov 19, 2012 12:01 pm
Great thank you. Right now im still looking for
Carb
Variator
Clutch
2003 zuma 50:
leo vince zx-r
carbon fiber reeds
ncy107mm clutch
Tue Nov 20, 2012 5:22 pm
got the exhaust and rear brake shoes today. The exhaust seems to have 4-5 "dents" in random spots. I think i remember heard this was normal. I had ordered the "ZX" but they shipped the "zxr". I wanted the zx because of the shorter muffler. As far as i read here I should be able to put the pipe rollers and springs on without jetting since its still 50cc and stock otherwise correct.
2003 zuma 50:
leo vince zx-r
carbon fiber reeds
ncy107mm clutch
Wed Nov 21, 2012 12:11 pm
The dents are supposed to be there. I didn’t have to do any rejetting when I ran the ZX on my stock motor. Just take your time with the install and make sure there aren’t any leaks. I like to thread the two bracket bolts in the case just enough to hold it and then tighten down your flange studs/bolts. After you've torque your flange bolts, tighten down the brackets and get tuning!
Wed Nov 21, 2012 1:03 pm
scooters and mods: '08 zuma 50 & '06 vino 125
the 130 front tire will really kill your top speed on a 50 but with the bbk its not as noticeable. it feels better on pot holes, it levels out the seat, and it gives you more rake in the front end stabilizing the scooter a bit at faster speeds.
'06 vino125 55mph 85mpg
'08 zuma50 53mph 65mpg
Wed Nov 21, 2012 3:35 pm
Tearing into it more and it just gets more and more dirty
2003 zuma 50:
leo vince zx-r
carbon fiber reeds
ncy107mm clutch
Wed Nov 21, 2012 10:48 pm
I got it cleaned up a bit more. When I took the reed cage the gasket ripped. Since the cage is hard plastic I assume I need to put another one? I asked at the local Yamaha dealer and they said they don't just sell the gasket alone. Thoughts?
2003 zuma 50:
leo vince zx-r
carbon fiber reeds
ncy107mm clutch
Fri Nov 23, 2012 11:34 pm
I usually pick s few up with my orders from larger vendors scooter attack etc. Most aftermarket vendors sell them for a couple bucks each. You could make one out of gasket paper thats close to the same thickness. Just be sure to put a thin film of Yamabond or similar to be sure you don't have leaks. If I don't use a skim coat I always come up with leaks at the reedBlock.
Sat Nov 24, 2012 2:00 pm
yamaha dealers are so full of dookie most of the time
4SC-E3621-00-00
Yamaha
GASKET, VALVE SEAT
$2.03
this is the part you need and the price from cheapcycleparts.com
Sat Nov 24, 2012 4:35 pm
You could also make that gasket out of gasket paper or whatever it's called (not that I've ever done that). And while you're at it - if you're going to put in a big bore, anyway - replace the reeds with carbon fiber ones.
In general you want to be careful when removing parts that have gaskets, because they're fragile. That includes the gear cover, crankcase cover, and other things.
Quote:
the oil tank likes to leak on all the zumas I've seen
The typical reason is that the oil sensor gets forced out when you overfill it just a little. I need to wedge mine back in properly too. :)
Sat Nov 24, 2012 7:52 pm
I ordered the gasket along with some carbon fiber reeds so im waiting on those to come in. In the meantime i posted something in the parts review area and have never got an answer. Can someone help me out here.
I searched and could not really find a comparison of variators. I see them from $62 for athena to $99 for polini to $134 dr pulley. Can someone shed a little light on what makes one better or different than another
$62 http://www.motorcycle-superstore.com/5/ ... toComplete
$99 http://www.drowsports.com/product/143/T ... Horizontal
$134 http://enviromoto.ecrater.com/p/1418339 ... tor-yamaha
2003 zuma 50:
leo vince zx-r
carbon fiber reeds
ncy107mm clutch
Thu Nov 29, 2012 8:34 am
When people say to mix the variator a weight is this what they mean? Also I pulled the plug which I think is the wrong one. It at least doesn't look lean.
2003 zuma 50:
leo vince zx-r
carbon fiber reeds
ncy107mm clutch
Thu Nov 29, 2012 11:41 pm
Last night I ran into a little snag. The new exhaust flange doesn't not sit flat like the stock one. Any thoughts?
2003 zuma 50:
leo vince zx-r
carbon fiber reeds
ncy107mm clutch
Mon Dec 03, 2012 11:40 pm
Users browsing this forum: Google Adsense [Bot], VincentWen and 2 guests
