View unanswered posts | View active topics It is currently Wed Sep 18, 2019 2:41 am
Reply to topic  [ 69 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Couch scoot build, come on in
Post Re: Couch scoot build, come on in
well im an idiot because after further review it looks like thats how it supposed to be. I assume then there would be no additional gasket to put in there since the flanges dont sit flush.
Still trying to get answers on this.
I ordered the gasket along with some carbon fiber reeds so im waiting on those to come in. In the meantime i posted something in the parts review area and have never got an answer. Can someone help me out here.
I searched and could not really find a comparison of variators. I see them from $62 for athena to $99 for polini to $134 dr pulley. Can someone shed a little light on what makes one better or different than another
$62 http://www.motorcycle-superstore.com/5/ ... toComplete
$99 http://www.drowsports.com/product/143/T ... Horizontal
$134 http://enviromoto.ecrater.com/p/1418339 ... tor-yamaha
2003 zuma 50:
Top Performances trophy70cc
stock carb 46pj 90mj
Stock airbox with snorkle
leo vince zx-r
carbon fiber reeds
ncy107mm clutch
ncy107mm clutch bell
Tue Dec 04, 2012 8:36 am
scooters and mods: 2005 Zuma
I know a lot of folks like the Malossi vario and the Stage 6's. I run the S6 and it helps with smooth operation. I've heard mixed reviews about the Athena but I would guess it better than the stock unit. I don’t have a Polini for a Zuma but I do have one for another scoot and it works well and is a quality part. Can't give any advice on the DR. P though. Are you going to 70cc now or are you waiting a while? If you're waiting, I put the vario lower on the list of parts until you have the BBK.
Top Trophy 12mm Piston / Polini Head -- Stage 6 12mm HPC Crank
Blk Del 19mm PHBG / 88main, 45pilot, W9 1st clip, Vented Airbox
Moto Tassinari VForce3 Reed Block -- MotoForce Intake -- TNT Adj Oil Pump Y-Plate
Leo ZX -- Stage 6 Sport Pro Vario -- S6 MKII Clutch & CNC Bell -- 15/50 gears
STR8 Oversize Fan -- Dual Headlight / Slim Tail Light -- Flush Front Signals
Sidestand -- SL26's 130/90/10 Front & Rear
Tue Dec 04, 2012 1:17 pm
I don't have the same Polini variator you linked to. But I love the operation of the one I have. And I have a feeling that the 9 weight one is even smoother, not to mention more fine tunable.
And I'll add another note. The Drow Sports guys are awesome to deal with. I decided to call in my order to make sure they had it (I had a big run in a few days) And he talked with me for almost an hour about the things he had sitting there. A couple days later I had my parts and was able to make my run. :) He even e-mailed me the minute it was in the box and left his hands for the UPS guy's hands (Or was it USPS?.... doesn't matter.)
I'll also second the Malossi. I hear good things about the Malossi one (Drow was out of them at the time)
_______________________________________
The Rumrunner:
'09 Zuma 50.
Top Performance Trophy 70cc, Stage6 small end bearing, 2005 carb needle raised one notch, Malossi carbon reeds, 84 main jet from Yamaha, Throttle mod, LeoVince TT, Polini Speed Contol variator (#241-301), Hoca Racing drive face, 7g adige sliders, Malossi yellow torque spring, dual headlight mod, triple brake light mod with LEDs, LED plate light, less bulbous turn signals, 12v power port, Air horn, RAM GPS mount, 15W fork oil, Shinko SR 426 4 ply Dual Sport tires, Ducted trans cooling with a fan up under the cowling so I can still ride through mud.
Build thread: viewtopic.php?f=50&t=19720
Tue Dec 04, 2012 7:12 pm
Thank you for the reviews on I the brands. I guess I should have been more clear. I was wondering more on how the aftermarket ones are better over the stock parts.
On a different note I'm integrating the blinkers into the brake light. Anyone see a problem with the bulb socket in there? I'm thinking since its just a blinker it won't get to how and melt the plastic?
2003 zuma 50:
leo vince zx-r
carbon fiber reeds
ncy107mm clutch
Sat Dec 08, 2012 12:15 am
no problems. was the first mod i did to my 2005....and the only mod i did before i started my mess.
the 2002-2005, i believe, have reflectors there. swap out the reflectors for lenses so that other vehicles notice them better.
STOCK ZUMA 50CC PARTS FOR SALE
buguy wrote:
A tool??!! We ride scooters...we all look like tools dude!
cathy_liebchen wrote:
Fast, Cheap, Reliable = Choose any 2. Can't have all 3
Sat Dec 08, 2012 2:25 am
Put some bar end mirrors on tonight. I got them at cycle gear. Seems to be ok quality.
2003 zuma 50:
leo vince zx-r
carbon fiber reeds
ncy107mm clutch
Wed Dec 19, 2012 10:26 pm
I ordered some carbon fiber reeds for the stock reed cage which will be here soon. My question is with the zx-r pipe and the new reeds would that warrant needing to make any changes to the carb(ie rasing the needle or rejetting) My elevation is anywhere between 100-200ft above sea level
2003 zuma 50:
leo vince zx-r
carbon fiber reeds
ncy107mm clutch
Fri Dec 21, 2012 11:06 am
Wasn't really planning on it but it looks like my is making brackets for a stretch kit for me. He does quite a bit of his own fabrication including his own 1014 whp 2jz swapped 300zx.
2003 zuma 50:
leo vince zx-r
carbon fiber reeds
ncy107mm clutch
Wed Dec 26, 2012 7:11 pm
scooters and mods: modded 05 zuma and 06 R6
Awesome :cheers:
viewtopic.php?f=50&t=5614&start=300
Sat Dec 29, 2012 6:28 pm
Mocked up a bracket last night to get an idea. So since we bolted it to the existing subframe we now have a pivot point in the front and back of the bracket. It doesn't seem right to me but that's what the kiesler one is like. Thoughts please
2003 zuma 50:
leo vince zx-r
carbon fiber reeds
ncy107mm clutch
Thu Jan 03, 2013 9:17 am
What are these kind of bolts called? I'm trying to source a little longer one. This is the one that goes through the subframe to keep it from pivoting that's why it has square shaft
2003 zuma 50:
leo vince zx-r
carbon fiber reeds
ncy107mm clutch
Thu Jan 03, 2013 11:40 pm
scooters and mods: 2009 Zuma 125
SICK 300ZX DUDE!!! :whip:
Ruima Race fan, TBR black series exhaust, custom intake w/ modified stock air box, Oil regeneration elimination, Race Torque Driver, NCY Spring bearing, Dr. Pulley clutch, KOSO clutch bell, TST Hyperbolic variator, 1000RPM contra spring, Daytona Japan Kevlar belt, blue LED gauge lights, NCY orange cam breather, flush mount signals, KOSO afterburner taillight, rear fender chop, BWS headlight conversion w/ custom projector and top light w/ LED panels( with Halos), RC155 w/ camshaft, cam gear, ported head with larger valves, aluminum/ nikasil cylinder, matched fuel injector, 13/39 gears, dolphin valve cover heat sinks, TNT braced low bars, GJMS orange brake levers, MOS orange ignition cover, MOS orange speedo cable holder, MOS orange oil dipstick, MOS rear grab handles, orange transmission bolt
High Speed-Low Drag
~CHRIS~
Fri Jan 04, 2013 9:55 am
He's getting ready to stick in a new 75mm. Notice it sitting next to the drill to give you an idea of how big it is
2003 zuma 50:
leo vince zx-r
carbon fiber reeds
ncy107mm clutch
Fri Jan 04, 2013 10:15 am
Have you checked Fastenal yet ?
http://www.fastenal.com
Fri Jan 04, 2013 3:13 pm
I went by there at lunch today they gave me the same blank look as the 2 bolt companies did here. I have been told a couple of times that this is probably custom to the zuma. I did however randomly see that the kiesler stretch kit looks like it has the bolts i need. That would require me to buy the $80 for 2 bolts, so i wont be doing that.
2003 zuma 50:
leo vince zx-r
carbon fiber reeds
ncy107mm clutch
Fri Jan 04, 2013 3:38 pm
Users browsing this forum: Prastitnya and 2 guests
