View unanswered posts | View active topics It is currently Sun Sep 15, 2019 9:35 pm
Reply to topic  [ 75 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Another SICK RUCKUS....
Post Re: Another SICK RUCKUS....
the keisler is that little stretch thats just some metal plates and bolts correct
im pretty sure I remember it mentioned a carb adapter is needed
found it here http://www.sip-scootershop.com/en/products/subframe+kiesler+_ks100019
this is what made me think the carb needs to move
To guarantee problem free installation of your manifold spacer, we recommend using a subframe. The subframe enables you to mount the carburetor directly above the rear tire.
picture of the carb facing rearwards
Thu Mar 06, 2014 9:35 pm
might be this part
http://www.sip-scootershop.com/en/products/spacer+manifold+kiesler+21_ks100008
Thu Mar 06, 2014 9:36 pm
Hmm, you may be right zumike. :doh: That's cool since I'd rather have the carb facing that way. Spending more money that I really don't have but I guess that's the way it goes.
2008 Zuma 50
2012 Zuma 50 (sold)
2003 Derbi Red Bullet
Sat Mar 08, 2014 8:37 pm
the problem is you cant use the stock air box right
if your using stock carb you will need to find something as restrictive as the stock air box to get it to run properly then
Sat Mar 08, 2014 8:46 pm
No, I'm using the 19mm Dellorto and a Uni filter. Specalk confirmed that I do need to reverse the carb so I'm trying to get the Intake from him.
2008 Zuma 50
2012 Zuma 50 (sold)
Sun Mar 09, 2014 8:45 pm
scooters and mods: Yamaha BWS 100cc + Lots of VAT......
The streched look is so wicked!!
@Spaz - why not run the carb facing forward? would look BOSS!
LOUD pipes save LIVES!
Chicks Dig me Because im FLUFFY!!
Mon Mar 10, 2014 2:27 am
QUESTION ::
Is low ... ever too low ?? ??
Mon Mar 10, 2014 12:59 pm
thats my friends
he said they took out the shock for the picture
its not done yet, note no exhaust hanger either
Mon Mar 10, 2014 1:02 pm
I just figured that they LIKED seeing the SPARK FLY !!
I used to see that all the time around NC ... not on scoots.
that's my friends. he said they took out the shock for the picture
it's not done yet, note no exhaust hanger either
Mon Mar 10, 2014 1:09 pm
Yeah, I love the look too, It's just costing me so much money to put this bike together and if I could have put this part off for a while, I would have. Now I have to get it or no riding :(
2008 Zuma 50
2012 Zuma 50 (sold)
Mon Mar 10, 2014 5:38 pm
Well, I've seen a ruckus or two lose a header pipe or crack it cause they're too low.....low LOOKS cool, but not all that practical (I like low, just not LOW) lol! :cheers:
Mon Mar 10, 2014 7:25 pm
every gy6 ruck ive seen has cracked a header, broke the studs or exhaust hanger
its totally normal for them to do that, which sucks
you really need to keep on top of PM with those bikes
and even better if you could safety wire alot of bolts and nuts
the main problem is the mounts that to hold up are like stock, large and ugly
everyone wants mounts you dont see so they always break
if I ever did a gy6 ruckus I would use stock muffler and whatever clamps and hangers they come with
but probably make it a shorty
may be ugly but probably hold up just fine
Mon Mar 10, 2014 7:46 pm
i feel you man.... ca$h is LOW!! lower than the Ruckus in the pics!
there is a guy her in SA that makes forward facing manifolds.. will try get hold of one, or a picture of one! maybe Fabricate your own!
Tue Mar 11, 2014 12:13 am
scooters and mods: '09 Zuma, '05 Pipe, Malossi cast iron BBK, Stage6 V-Force reed block w/ CF, BCD Stem, BGM Drag bars, Koso LCD Speedo
a little self promotion but...
no love for the zuma 50s stretched?
Untitled by BLanigan747, on Flickr
http://www.zumaforums.net/phpBB3/viewtopic.php?f=9&t=22001
Tue Mar 11, 2014 6:17 pm
Stretch looks good
But looks way too low
Tue Mar 11, 2014 7:23 pm
Users browsing this forum: VincentWen and 2 guests
