View unanswered posts | View active topics It is currently Mon Jun 17, 2019 8:24 am
Reply to topic  [ 48 posts ]  Go to page Previous  1, 2, 3, 4
 YAMAHA ZUMA bugeye50, bws
scooters and mods: 2005 Bws Dual headlite mod1989 zuma with 70cc kit,up jetted carb,dopler air box custom exhaust made outta stock one.
Post Re: Firehawk989's '05 BWS Build
Hey, Hows old Garfield running?
2005 BWS (Blue Bandito)
- 70cc Athena bbk (Sport)
- stock carb,85Mj snorkel removed
- stock clutch
- ncy adjustable td.
- malossi white torque spring
- malossi yellow clutch springs
- michelin bopper tires
- dual headlight mod
- tun'R rear shock
1989 Zuma (Red Dragon)
- 70cc Hebo bbk
- Doppler air box stock carb
Sat Feb 11, 2017 10:02 am
Well i bit the bullet and just ordered the same NYC adjustable torque driver. seemed like the right thing to do for $25 :q:
My 2005 td has almost 25,000 ks and has major flat spots in the acceleration.
- stock clutch
- tun'R rear shock
- 70cc Hebo bbk
Mon Mar 06, 2017 9:20 am
scooters and mods: 2005 BWS
Been a long time since I was last here, probably cause the scoot has been running great the whole time!
It's at 35,000km now, and I just recently changed the cyl. Not because it was worn out, but because it had an exhaust bolt broken off in the flange that I didn't want to deal with, and I already had a new black trophy kit sitting around from when I thought I had blown the old one. (Was actually stripped spark plug threads causing no compression, so just changed the head and it was all good again.)
Anyway, I also recently changed the belt and noticed that I'm not quite getting my full ~85km/h top speed anymore, so I suspect it's finally time to change the sliders. I'm going to go with 4g sliders this time since I've noticed the revs stay below the powerband until around 50-60km/h.
2005 BWS "Garfield"
Tue Aug 29, 2017 9:55 am
