View unanswered posts | View active topics It is currently Wed Jun 26, 2019 9:41 am
Reply to topic  [ 54 posts ]  Go to page 1, 2, 3, 4  Next
 YAMAHA ZUMA bugeye50, bws
scooters and mods: 2005 BWS YW50 stock. (Under Construction)
Post YAMAHA ZUMA bugeye50, bws
I have a 2005 BWS and have ordered a Stage6 Streetrace 70cc 10mm kit with a Stage6 Pro Replica pipe. I will be adding pictures as I go and ask for whatever helpful tips or tools I'll need to keep her reliable. Thanks :cheers:
CANADA, BC
Thu May 01, 2014 10:19 pm
Post Re: My 2005 BWS
Hello, post some pictures!
Fri May 02, 2014 9:49 am
scooters and mods: 2005 raven zuma, Stage 6 sport 70cc, LV ZX and Malossi Fly Clutch.
You will want to do a pressure test on the crankcase after installing the new kit.
Also spend a little time examining the new bore before installing and chamfer sharp edges on the ports.
Make sure you dont install your piston upside down, the arrow goes to the exhaust side.
Make sure you understand what your doing when tuning the fuel mixture.
These are mistakes ive made in the past so id reccomend them as "tips"
2005 Zuma 50, Under construction
Fri May 02, 2014 10:40 am
Thanks conez0! I'll take that all into consideration. Here are some pics. I have a new full windshield from yamaha that works fantastic. Stops the wind from breaking right into your chest.
File comment: 2005 BWS,large windshield,stock everything else.
CANADA, BC
Fri May 02, 2014 10:52 am
scooters and mods: 2002 |Yamha BWs, 2001 Yamaha Vino Classic
Another BC guy i see!
Just curious where you picked up the windshield, and how much?
Mon May 05, 2014 10:44 am
Windshield comes from Yamaha, (Daytona Motorsports.) They also have a short version if you want a sportier look. I think I paid somewhere around $100-$120 for mine, can't remember exactly.
2005 BWS "Garfield"
Wed May 07, 2014 11:32 am
It was from Kelowna Yamaha and it was $120. I just got my pipe and kit in.
Went out and got some 3.5g Athena 15x12 weights and some dr pully 8 gram weights
That way I can mix and match if needs be. I'm looking at a new belt and crank but may just do the crank baring and keep it under 10,000 rpm. I'm putting in a 1500 rpm contra spring and red clutch springs as well.
CANADA, BC
Wed May 07, 2014 12:17 pm
scooters and mods: 06,Top perf nardo stage 6 hpc,malossi clutch blue springs,motoforce 70cc spot,malossi vario 7 g roller,TNT belt,09 gears
That big windshield prob slows you down
2000 zuma, orange, dr evo 70 cc, 100 main jet leovince zx pipe for after break in period.
TNT bars/stem , custom gauge, TNT rear lights. Custom front lights
Wed May 07, 2014 12:23 pm
My 70 cc kit
File comment: Stage6 Pro Replica exhaust
File comment: Stage6 Streetrace 70cc 10mm
CANADA, BC
Wed May 07, 2014 12:31 pm
Nope it actually makes me go faster by 3-5 kms
Breaks the wind and is way more arrow dynamic than my chest.
CANADA, BC
Wed May 07, 2014 12:36 pm
Sweet, and thanks. Will drop by Daytona tomorrow and order one up.
Wed May 07, 2014 1:19 pm
I'm ordering some more parts to complete my build.
I believe I need a choke cable to and single throtle cable.
They are out of stock on the site I'm ordering from so I'll have to look around.
File comment: Cart list
CANADA, BC
Mon May 12, 2014 10:04 am
Stillvious
where you located?
the 19mm from scootertuning doesn't have the right atomizer.. just so you know
-joe
08 BWS 50, Stage6 Racing 70cc MKI (.8 squish), BR8HS spark plug, Yasuni City16, Dellorto 21mm, 45/90/W9/1 lean/30 slide, Stage6 race filter, Stage6 10mm crank, Athena 50/15 helical gears, Stage6 Racing Torque Control MKII 107mm, Red clutch springs, Malossi white contra, Stage6 vented clutch bell, 8000rpm engagement, Malossi Multivar variator with 4.0g sliders, Kiesler rear facing intake reed cage with CF reeds, Stage6 subframe, Michelin Boppers front back, dual headlight mod, C3 mirros, BWS-X gauge cluster, stage6 R/T front forks fully adjustable, stage6 front triple tree, stage6 R/T rear shock fully adjustable
09 Ruckus with YW50 swap, Polini 70cc, BPR8HS spark plug, Leo Vince ZX 70cc+, Dellorto 17.5mm 45/90/W7/1 Lean/30 Slide, Polini race filter, Stage6 10mm crank, Athena 50/15 helical gears, Red clutch springs, NCY 1000rpm contra, Stage6 vented clutch bell, 4500 engagement, Malossi Multivar variator with 6.75g rollers, Michelin Boppers front bac
Mon May 12, 2014 10:16 am
jtktam wrote:
Stillvious
where you located?
-joe
Thanks Joe! I'm from kelowna, BC Canada. What would be the most reliable carb for that 70cc streetrace stage6 kit? And what else will I need to install the right carb? Cheers.
CANADA, BC
Mon May 12, 2014 10:04 pm
i bought two carbs from them, same item
one came with the correct atomizer
one didn't
i ended up having to order the atomizer bits myself
-joe
Tue May 13, 2014 5:40 am
