View unanswered posts | View active topics It is currently Sun Feb 17, 2019 4:12 pm
 86cc l/c Bidalot Zuma
Post 86cc l/c Bidalot Zuma
It's been awhile since I've posted here, but I figured I'd show how the bike looks and runs nowadays. My sig line is up to date for most part.
Sun Oct 02, 2016 2:55 pm
Post Re: 86cc l/c Bidalot Zuma
Pig, you using screen mesh in front of the radiator too?
2008 Zuma 50
2012 Zuma 50 (sold)
2003 Derbi Red Bullet
Sun Oct 02, 2016 4:47 pm
Man this bike is killer!! Its a looker and it runs like a raped ape!!
1990 Yamaha Jog CG50-CW50 swap
1992 Yamaha Jog CY50-stock
2000 Honda Elite SR50-72cc Corsa, Arrow, OKO24, Polini vari, 8.4:1
PocketChangeScooterClub
1995 Suzuki Intruder VS800
2014 Yamaha FZ-09
Wed Oct 12, 2016 3:17 pm
I recently painted my bugeye, here's how it looks now
Sun May 07, 2017 4:04 pm
