View unanswered posts | View active topics It is currently Sun Aug 25, 2019 4:04 pm
Reply to topic  [ 60 posts ]  Go to page Previous  1, 2, 3, 4  Next
 YAMAHA ZUMA bugeye50, bws
scooters and mods: 2005 Bws Dual headlite mod1989 zuma with 70cc kit,up jetted carb,dopler air box custom exhaust made outta stock one.
Post Re: Storz 2005 Bws Build
Ohhh yeah Jets arrived and i can pick up my athena kit at the post office tomorrow :q: :q: :q:
2005 BWS (Blue Bandito)
- 70cc Athena bbk (Sport)
- stock carb,85Mj snorkel removed
- stock clutch
- ncy adjustable td.
- malossi white torque spring
- malossi yellow clutch springs
- michelin bopper tires
- dual headlight mod
- tun'R rear shock
1989 Zuma (Red Dragon)
- 70cc Hebo bbk
- Doppler air box stock carb
Tue Nov 29, 2016 4:36 pm
Sweet, the build gets closer and closer.
2008 Zuma 50
2012 Zuma 50 (sold)
2003 Derbi Red Bullet
Tue Nov 29, 2016 6:12 pm
Hey Spaz I've got a question for you....
So my stock 05 seems more sluggish then normal these days, i was thinking about it today and was thinking I've been running a stock 2008 bws exhaust for about 4years now and have never cleaned it (between 9-11,000kms).... Any symptoms for a plugged exhaust? my bike seems to take off ok unto about 40km then seems to really struggle from 40-60.... seems to have a hard time getting the revs up passed 40km. Any thoughts ? i recently did the belt/rollers/plug/air filter/gear oil I'm leaning towards the exhaust is plugged up maybe?
- stock clutch
- tun'R rear shock
- 70cc Hebo bbk
Mon Dec 05, 2016 3:14 pm
I've never had any exhaust for that long so I can't really say for sure, but cleaning out certainly can't hurt it.
You also mentioned that it has a problem from 40 to 60kmh, which always makes me think of the torque drive when dealing with an 05 and older.
Try cleaning out the pipe first though and see what happens.
2008 Zuma 50
2012 Zuma 50 (sold)
Mon Dec 05, 2016 5:27 pm
yeah that wouldn't surprise me since the scoot has 24,xxx k's on it now... :D How can i tell if my torque drive is pooched??
- stock clutch
- tun'R rear shock
- 70cc Hebo bbk
Mon Dec 05, 2016 6:10 pm
When it gets to a certain speed it like shifts and lugs. It's pretty obvious when it's doing it.
2008 Zuma 50
2012 Zuma 50 (sold)
Mon Dec 05, 2016 9:01 pm
Ok maybe ill pull it apart and clean and grease it all, i don't think I've ever taken it off in the 6+ years of driving it... will there be any signs to look for thats its worn out when i have it apart?
- stock clutch
- tun'R rear shock
- 70cc Hebo bbk
Tue Dec 06, 2016 8:43 am
You'll see once you get it apart if the grooves are damaged. It should be pretty noticeable.
Here is a way to get the clutch off the torque drive if you don't have an impact, or the right socket:
https://www.youtube.com/watch?v=QR5JSq2VdYU
Here is another video that Brent made showing the differences between the dual angle groove, which is similar to the 05 and older Zuma's and the straight groove of the newer Zuma's. It'll help you understand how they operate.
https://www.youtube.com/watch?v=FjVhtKaOH04
2008 Zuma 50
2012 Zuma 50 (sold)
Tue Dec 06, 2016 11:10 am
Those Videos were very helpful i understand it all a lot better now.. Thanks!!!
I'm gonna start looking for a 2008+ torque drive to run.. One more thing should i get a stock replacement wrist pin or aftermarket? any other parts i should replace when i have it apart?
Thanks for the help as always :cheers:
- stock clutch
- tun'R rear shock
- 70cc Hebo bbk
Sun Dec 11, 2016 10:57 am
A stock replacement pin is fine.
If you got new reeds, which you should have done, make sure that your gasket is still good, or get a new one. I would use gray or red permatex as well.
I'm so anal about doing a leak test on mine that I will do them even if it's because I've taken the intake off (to replace the reeds) and of course when splitting cases.
So, I would say make yourself a leak tester and do it. Here are several to look at and mine, which I think is the simplest, is at the bottom.
http://49ccscoot.proboards.com/thread/5 ... ester-ways
There's many video's on youtube on how to do a leak test on 2 strokes.
2008 Zuma 50
2012 Zuma 50 (sold)
Sun Dec 11, 2016 2:05 pm
ordered a new wrist pin and a reed block gasket(not sure if thats proper name) cost me a whopping 11$ Getting closer to build day :q:
- stock clutch
- tun'R rear shock
- 70cc Hebo bbk
Thu Dec 15, 2016 7:13 pm
Good luck. When I went through my search about 3 months ago, there were none to be found unless you want to buy a new one which is pretty pricey. I posted here and on two different FB Zuma forums and no one had one. Even tried eBay.
The general consensus was that it didn't make that big of a difference, so I just took mine apart to clean and lube everything.
2004 Zuma 70cc Malossi kit Leo Vince TT pipe Arreche 19mm carb Uni pod filter Malossi Variator and Delta Clutch Cylinder mildly ported and set up by http://www.WilsonPerformance.net
Fri Dec 16, 2016 4:55 am
yeah ill probably end up getting a Malossi Over Range kit for $239 sounds like the the best deal around
- stock clutch
- tun'R rear shock
- 70cc Hebo bbk
Fri Dec 16, 2016 8:52 am
Brian, I'm going to have to politely disagree with you and say that on modified Zuma's, they do make a difference.
I'd say use yours for now and save up for the Over Range, because there's no sense in buying just a quality torque driver when you can buy the entire setup for just a little more money.
2008 Zuma 50
2012 Zuma 50 (sold)
Fri Dec 16, 2016 3:24 pm
Yeah I'm sure my drive is worn out since my bike has 25,000kms on it, id rather just replace it while i have it all apart...
what clutch should i get with the overange kit ? Are the Flys decent enough? $68 and that comes with the bell also
- stock clutch
- tun'R rear shock
- 70cc Hebo bbk
Fri Dec 16, 2016 5:31 pm
