View unanswered posts | View active topics It is currently Thu Jun 27, 2019 1:49 am
Reply to topic  [ 1 post ]
 New Exhaust
scooters and mods: 2004 Zuma
Post New Exhaust
So currently I am running a Malossi MHR Liquid cooled cylinder and the issue that I'm running into is that My top speed is just not there. And this would most likely be due to the Yasuni R pipe I'm running. The cylinder wants to turn on when the exhaust wants to turn off. So, that's the issue that I am having.
I have my eye on purchasing the Yasuni as I feel that it will give me more power at mid to higher revs. my center stand has already broken off due to wear and tear over the years so no issue there. I want the cylinder to match the exhaust as best as possible as much as I love buying parts for this thing, right now I'm not really in a position to be buying anything for this thing to be totally honest. But I can't resist and must keep pushing forward towards that Perfectly tuned setup that I know will never happen. I know that I will never be satisfied. But at least I can have some hope and try to pretend like there is an end of the tunnel. (There is no such thing) Basically, I want to make sure that I get an exhaust that is going to be the best match for the current cylinder and even if I choose to upgrade to a stage 6 LC hyper race cylinder in the future, which I have already been thinking about as it is. it's up to the Yasuni C16 or even the C19 possibly. Looked a little into the sport level Roost 70cc Exhausts. (Badass) Where are the part matching Pros that can help me out on this one? Any feedback would be helpful.
2005 Yamaha Zuma
~ Malossi RHQ Crankshaft 10mm
~ LC Stage 6 MK2 Sport Pro
~ Roost SP1
~ Polini 24mm Carb | 124 Main Jet | 45 Pilot Jet
~ Polini Gear Set 13/44
~ Malossi Overrange Variator Kit LA Furia Rossa
~ Stage 6 Mk2 Clutch
~ Stage 6 R/T Clutch Bell
~ Naraku Intake
~ Stage6 V-Force3 Reed Valve
~ Polini Air Filter (open)
~ Shock Riser
~ NGK Hot Plug
~ NGK BPR9ES Spark
~ NYC Quick Throttle
~ Headlight Mod
~ Trail Tech Vapor RPM meter
~ Trail Tech Temp gauge
Wed Aug 29, 2018 1:29 pm
