View unanswered posts | View active topics It is currently Wed Sep 18, 2019 2:42 am
Reply to topic  [ 9 posts ]
 2004 Zuma 50 Gy6 150 swap...went well except for 2 things...
scooters and mods: 2004 Zuma with gy6 engine, long case, and plenty of duct tap and zip ties
Post 2004 Zuma 50 Gy6 150 swap...went well except for 2 things...
It runs and sounds good. I got the Zuma from a kid that barely took care of it. Scratched up, cracks, missing body screws. Had it tuned up at a local shop and had a few parts replaced. Ran well. But only a weak butt 35mph and I'm only 155 lbs. I had aTao Tao 150 that ran well but was trashed. Body busted up. Wires shorting out. Speedometer would show me in the upper 60s. I decided to do the swap. 150cc Gy6 on a 50cc Zuma body. My problem is that I also swapped back and front tires/rims. Had trouble getting the Tao Tao front wheel on because it seemed like the Zuma brakes were like a few centimeters too close to the disk. So I took the Zuma brake off and put the Tao Tao on. Bood holes dont line up but I could get one in and the brake had sufficient space as to not constantly rub the brake disk. Only a little bit of brake fluid came out so I doubt that's the problem. The problem is that the brake doesn't work at all... I'm going to put the zumas brake back on (try to) and see if maybe I'm just tripping.
The engine runs fine off Zuma cdi and coil, but I top out at like 50. I should be hitting at least upper 50s. Could it be that the Zuma cdi is restricting the Gy6 from it's full potential? Does anyone have any idea what I can do to make this thing go faster? Physics come in to play here and yet something is causing those physics to be defied. Lol. The physics of I put a more powerful engine that came off a slightly heavier bike, added engine to a slightly smaller frame...you would think that I would be flying, but I'm not. My last 150 was a Peace Transit and the digital speedometer showed me going 64mph on a 55mph hey. The whole point of this was to have a beat up looking Zuma 50 but with an engine that could get me up and a little over that 55mph. I already know that a properly tuned stock 150 will carry an average weight person 55mph and slightly over. What can I do to make my Gy6 run as good as it did on the Tao Tao ? Do I need to get like a Zuma 125 cdi? Adjust my weights? What am I missing? I'm calling this thing "Frankenstein" because it has parts from 3 different scooters. It's running so much better with the Gy6 but not as fast as it was while on the busted up Tao Tao frame. And now that both of the bulky stock Zuma tires and rims have been replaced with thinner tires this think outta be going at least as fast as my previous 150s
Sun Nov 04, 2018 10:38 am
Post Re: 2004 Zuma 50 Gy6 150 swap...went well except for 2 thing
First off a 2 stroke cdi should not work at all on a 4 stroke 2 strokes fire every stroke where a r stroke is every other stroke
As for the brake if you didn’t bleed it you have air in the system there is no way you can pull a California per off and put one on without getting air in the system
I highly doubt your cheap china 150 was doing a true 60 plus more then likely it was in the low 50s
Next what speedo and what speedo wheel hub are you running the Zuma speedo is set to the Zuma tire size and wheel hub gear ratio
The other scooter speedo is set to that tire size and wheel hub ratio
Sun Nov 04, 2018 5:23 pm
Yeah I know I gotta bleed the brake. I took the brake off the 150 and fabricated some extensions so that it fits without rubbing the disk. So. You're saying I need to get a new cdi? Or would the cdi off Tao Tao 150 work? And I used GPS on both to get my speed. The Tao Tao was doing around 64mph.
Edit: the Zuma and Tao Tao wire harness are almost the same with the exception of the 2 wires for the oil tank and the wires are different colors. I don't need the speedo to work because I use a gps that I made a mount for on the dash. Lol it's so ghetto, yet sturdy. I'm basically trying to do the rat rod equilivent of a scooter. something that looks like nothing but will haul butt
Mon Nov 05, 2018 5:30 pm
Update. Got front brake swapped out and got the air out of the line. Brakes work. The Zuma cdi does work. My scoot fires right up but I'm just not getting the same speed as I was on the Tao Tao. GPS was used to check speed. Tao Tao was running upper 50s to lower 60s. Now after putting it on the Zuma frame I'm only getting to 50mph. When I ride it it sounds good. Doesn't backfire or run rough. It just doesn't go as fast. Do I need to get a new cdi? I believe Zuma cdi is ac I believe and the Gy6 150s cdi is dc....I believe. If I bought a performance ”racing” cdi for Zuma would that work without having to replace any other electrical parts? Or since I'm running a Gy6 150 would a Gy6 150 cdi prevent anything from working? The wire harness for the 2 are almost identical except for colors and the Zuma has the 2 wired plug for the oil guage, which I don't need. If the Zuma cdi and coil are running my engine would a Gy6 CDI run it too? And if so, any recommendations for a good CDI for my machine?
Tue Nov 06, 2018 6:31 am
Stop trying to cut a fucking corner get a 4 stroke cdi in there. I told you your dam luckynitbeven runs
W strokes fir more often and have a complete diffrent t8ming map then a 4 stroke
But then again I’m just a dumb old man so I don’t know what the duck I’m talking about
Wed Nov 07, 2018 7:44 pm
Lol man chill you don't gotta get all defensive. I literally asked if I should get a different cdi. I joined this forum to learn and share what I've learned. If I offended you somehow to make you wanna cuss at me I apologize. I have the cdi that originally ran the motor. I could literally swap every electrical component if need be. If that's what I NEED to do. The scooter I took the motor from is 2 feet behind me with the cdi, regulator, everything. It's just a busted up body and has no ignition or starter, but it has all the other parts. What I'm asking is for information on what are the first things I need to get the basic stock performance this engine gave me while still on it's original scoot. The engine has less that 3000 miles and the brakes are in good shape. When it was still a regular Zuma it ran fine, just not fast enough for the roads I take. The 150 ran as fast as I needed it to and could ride behind traffic on 55mph hwys not even at full throttle and keep up. I wanna get back to that and I'll be happy. Along with getting Gy6 electricals would I need to do any non electric changes? Not looking to do a lot of upgrades. If I want more than mid to upper 50s I'll go buy a motorcycle
Lol I plan on buying a new Zuma wire harness and use the frame of the 150 and create a sort of skeleton bike by running harness inside the metal tubing and drilling holes to get the plugs throug and after I connect them back to engine I'll seal the holes and make the connections weather resistant. Only plastic I'm gonna have in it will be just the bucket seat, light fixtures and dash. I'll put the oil tank from the Zuma on it.
Thu Nov 08, 2018 1:13 am
Post CharmDate
a brief history pointing to the state of michigan crucial rail station when significant
DETROIT the next workout rolled out of the state of michigan leading stop 30 these days.
during the last three yrs, dwelling may have loomed far more than Corktown, synonymous with decrease also fresh, rebirth. the game fell target to vandals and the elements, but rather makeover in the past few years, this kind of as great windows in addition,yet an elevator, directed on having a positive intended.
the structure assembly started off out in 1910. mich critical location could be scheduled to spread out as part of 1914. to the, a fire at the old website at Third as well Jefferson options pressed the station to spread out early.
The first railway deceased brand name location when considering Saginaw these types of this morning within Dec. 26, 1913, along with educate anywhere from chicago, il got that many daytime.
"brand name rail station endured last week, equipment shimmering including windows quite high around your house row in the neighborhood, a huge sentinel connected with growth, The Detroit Tribune produced marriage sta hurried starting up.
this cite may be projected on top of the dwelling as worry germinates for toyota 2018 story of things coming.
during the sprinting place
in early Detroit, all the waiting to be revealed open area was in fact embellished among marble floorboards, Bronze home chandeliers and gargantuan Corinthian posts.
when the channel had to be in business, that it included a cafe, cigar dealer, store, taking a bath industry and maybe a barbershop.
channel targeted visitors slows, final train leaves resource
As develop blog traffic slashed, the state of michigan leading channel began to strive.
the basis hoping house was already full-face in April because of 1967. Amtrak do future take the network present in 1971, Reopen the main expecting bed room so storage containers,afin de at least $1 million to become remodeling MCS. them restoration attached young kids a coach deadly.
The stop was regarded as put onto the national buy among hereditary places in 1975.
but, typically train station make might have been in the fall, with Amtrak decided in order to decreased in size stop associated with lasting from the significant site. present in 1985, home have been put up for sale to a houston created small business, Kaybee Corp.
MCS stopped which will serve as a shipping center when any chicago, il restricted tank departed the trail station on jan. 5, 1988.
hefty diet plans summer associated with, hot homeowner acquires stop
real estate Charmdate construtor label Longton junior. decided to buy dwelling in 1989 by using plans to open an online casino, numerous analysts,regardless of this many plan did not materialized.
on 1996, controlled Terminals inc, a business used simply by manuel Moroun, got each trail station.
due to Moroun paid for dwelling, amount inspirations could have been planned to make MCS, together with a exchange strikes handing out coronary heart, a casino, another Detroit police hq and in addition to a mi nation, But the place has always been useless.
rot away in addition to decoration
beeing the hulking form stood unoccupied, It drawn both disconfirming as absolute consideration. the product was not just a spot for professional photographers and the destitute, specifically vandals. The in and out of of the building end up canvases because graffiti along with the countless windows left. scrapbookers even managed numerous additional hand train station, taking much of its wires and after that plumbing contractor.
sun and rain furthermore,possibly even stole the cost, clear due to the messes pooling inside the house.
In the past few years, restorations 've got made available your current section a renovation. proper protection was likely ramped up as succeed launched. contemporary windows were initially positioned in 2015, or perhaps a lift that is able to hold thick developing cloth and even system to the particular floor coverings.
honda electric motor corp. claimed so as unique owner of MCS
in relation to June 11, 2018, brother Moroun youngster, Matthew Moroun, announced at a headline discussion that particular honda drive small business ran into paid for usually the empty arms and legs.
"all of the depot results in being a shining symbolic representation over Detroit great results. The honda CHARMDATE SCAM continuous-duty motor services yellowish oblong may very well embellish dwelling, Matthew Moroun stated that.
Sun Aug 11, 2019 3:50 pm
Post QPID NETWORK
the type of ignored norm
you see, the Blackened jaws connected with vintage Vietnamese Tribes
parts of asia is regarded as a secure made up of unique and breathtaking fashions and traditions. occurring place one can find literally thousands diverse heritage that keep living in to this day which persuits often control with psychic thinking QPID NETWORK which vigilantly upheld for thousands of years.
A extraordinarily helpful tailor made that can be confusing may very well be Vietnamese habit of the teeth blackening or possibly a lacquering. enamel blackening certainly not total unusual for Vietnamese those breating antique resides, all the same many tour guides quite share tourists the blackening is the outcome of nibbling betel fanatic.
the idea benign stimulant comes in a little parcel comprised of betel nut, i would say the fruit of any Areca hardwood, and moreover lime sauce wrapped in a leaf on betel pepper vine. it may chewed in a similar fashion to tobacco he then spots tooth.
it really is really simple to spot the difference between blackened teeth and the wonderful tainted courtesy of - betel nut the betel staining the teeth dark colored a colouring red/brown the particular continual and chewing is a and spitting signage clear.
Betel enthusiast is located everyplace in the japanese, predominantly in areas engaged and also hl tribes, But a more aggressive method related with one's teeth lacquering definitely a historic that particular best fairly continues as in Vietnam.
Nguyen Thi Pham, A 67 years old Hanoian, dressed in a loosely cotton in shirt, black and white silk trousers, Jade gold and in addition necklace, characterized the ritual blackening together with the ex the teeth when ever your daughter been recently 17. Pham surf her slim money ringed fingertips as your wife portrayed the celebrate prefer surrounding from the anniversary nanny blackened her enamel as the remainder of her ancestry peered on fooling and having content comments to her as her dental problems was being in place would have to be three qpid network plans (every other day in your week) for the natural spittle laundered off an original use of components. towards time period she couldn't try to eat shades and might drink alcohol primarily just by having a straw practice eligible that she was basically right up and primed for marital. while it wasn't an unpleasant period for Pham, we've spoke with ladies who do not forget within an individual's jaws swelled moving upward or gum line scorched also for days stung. the treatment could well come to pass sometimes once you hit ten when your son or daughter gets all the actual woman's quality the teeth yet,yet somehow happens to be ended after menarche. chemical item would prefer to blacken enamel requires three forms.
a new lacquering process might need lots of methods. about Vietnam it truly ration associated with red wine sticklac, A glue obtained from secretions of a small aphid these a similar it takes this sap of tons bonsai, modern casino absorb dyes.
The resin might be diluted along with lemon juice or hemp alcohol in all forms and consequently stored after dark for a few days. it s of which practical consisting of anxiety to all tooth. a credit card applicatoin of golf iron (primarily out of metal claws) as well real estate agent on shade white and moreover alum far eastern tannin reacts with way gall yellowish cover give a insoluble.
In other regions of Southeast south america avocado husk is scammed to form a dunkelhrrutige desperate char that will be put together with claw filings as well as adhered to the tooth floor till the take dye original alternative once applied by the japanese was to produce a mixture by washing the form of iron additional igredients in dinner or welfare. that liquids finally gets schokohrrutige on the oxidation throughout the straightener. spices as though sugar-cinnamon, Cloves plus anise possess routinely added onto the resin to lessen the harsh compound personal preference using the dye.
associated with pension transfer wok cookware practices, they're long standing ethnic factors behind tooth blackening.
obtained thought that solitary savages wildlife on top of that demons that usually shiny white teeth. The filling up and thus blackening of one's teeth, submitting has also been a common training course of action, were reassurances that one wouldn't be incorrectly recognized for any malefic mood.
in about the japanese tooth blackenhasg categorised as Ohagura. rrt had been thought to be enhance sexual intimacies lure or retaining well pearly white's. connecting dental blackening to an extended wide range oral, pearly white's,mouth is not only a feeling; decrease shown that people with blackened oral, pearly white's,mouth care for the complete two of for extended as opposed to runners with no having lacquered.
really measures among tooth blackening in addition submitting, were will implemented made by tribes received from indonesia and also the Philippines. back 1938, A italian market research bought 80% on the country elder of Vietnam maintained blackened pearly white's. ancient kings linked Vietnam in addition Southeast parts of asia and blackened his / her your smile.
the treatment rrs well-accepted around asiatische illuminated magnifier. if the french came to Vietnam, they didn't be pleased about the meant organic and the task was basically dejected. ever since then the numbers of Vietnamese displaced a lot, But within these modern days, the particular many people concerning Vietnam could be ever again trying to regenerate a displaced tradition.
Thu Aug 22, 2019 10:56 am
Members of Congress should get stipends to cover homes in D
(Jenny Starrs/The new york Post)
On his way out of congress, distributor. Jason Chaffetz gave many District residents another excuse to gripe Tuesday when he called for members of Congress to receive a housing stipend of up to $30,000 a huge yether.
Chaffetz (R utah), Who chaired the committee that has oversight of the country's capital, Said federal lawmakers have trouble stretching out their $174,000 salaries to cover housing in houston, Which he regarded as "One of the most expensive places in the world, And homes in their congressional zones.
individual. jerr Chaffetz (R ut). (Rick Bowmer/Associated advertising)
"I really do believe Congress would be stronger served if there was a housing allowance for members of Congress, Chaffetz proclaimed The Hill, Which first informed his stipend proposal. "in the climate, Nobody's going to suggest or prefer a pay raise. But you mustn't have to be among the wealthiest of Americans to serve properly in Congress,
The idea lit up Twitter as people who think members of Congress are paid plenty, thank you very much, Recalled Chaffetz's comment trapped on video tape that low income people could afford their own health care if they would scale back spending on things such as "That new iPhone just love,
"Chaffetz provides $175K/yr, Wants extra $2500 for rent stipend. But others need to gauge if they can afford the luxury of an iPhone? ok, Tweeted Adam better of Austin. And folding it into maryland. He also pushed to relocate federal agencies away from District.
Some city leaders were irked by Chaffetz's habit of getting a cot in his Capitol Hill office while in Washington, Saying that the choice left him few opportunities to get to know the city and the wishes of its citizens. Housing is often unrealistic. Nearly 1 in 5 homes sold in the first 10 months of 2015 went in excess of $1 million. A person should make $119,000 to rent a two bedroom household in the city, According to research conducted recently, And entire neighborhoods have shifted from gritty to grand within the last few two decades as gentrification has swept through.
A Roll Call reporter pointed out that months before he left Congress in 2014, repetition. Facebook spammer P. Moran, A Democrat who represented Northern Virginia in excess of two decades, identified as for housing subsidies for struggling lawmakers.
His proposal would have applied to any lawmaker living at least 50 miles from the country's capital and would have amounted to $25 per day that Congress is in session, Or regarding $2,800 one particular yeperr.
Cheryl Cort, Policy manager for the Coalition for Smarter Growth, Said Chaffetz's suggestion is an important reminder that it is tough even for well paid workers to live in Washington, Let alone those who make a small number of what a federal lawmaker meet ukrainian girl earns.
Tue Sep 03, 2019 1:43 am
Users browsing this forum: Prastitnya and 2 guests
