View unanswered posts | View active topics It is currently Tue Sep 17, 2019 10:31 pm
Reply to topic  [ 32 posts ]  Go to page 1, 2, 3  Next
 Zuma 50F Polini Big Bore Kit + Mods
scooters and mods: 2013 Honda PCX 150 (RIP), 2015 Yamaha Zuma 50F, 2014 Honda Forza 300
Post Zuma 50F Polini Big Bore Kit + Mods
Hey everyone. I have a 2015 Yamaha Zuma 50F with a little over 5,000 miles on it. I noticed there’s not much info on the web about big bore kits and mods on the 4 Stroke version of the Zuma so here I’ll be letting you all know on my progress with the mods and how well the Zuma takes off after I’ve installed the kit as well as the top speed and other performance parts I’ve installed. This thread is just to let other Zuma 4 stroke owners know the results of a kit installed and the prices for the kit and parts.
I just purchased a Polini 60cc big bore kit (or 70cc cuz each site says a different cc amount for this same kit)
I also purchased a Malossi Racing belt, Malossi Up Gears which are 13/44, Polini Air Filter, and a Polini Variator. All these parts are specifically for the 4 Stroke Zuma whether it be the 50F or 50FX.
The Polini BBK - $249 (usually $359, I got a deal)
Polini Air Filter - $12
Polini Variator - $65
Malossi Racing Belt - $19
Malossi Up Gears - $70
I ordered the kit and all these parts yesterday so they haven’t arrived yet. Once they do I’ll let you guys know. As well as when I get them installed. Then the break in period. Then finally the top speed after full break in. So stay tuned for updates. This thread will probably go for 4-6 months of updates.
2015 Titan Grey Yamaha Zuma 50F w/ dual headlight mod, restrictor washer removed from variator, Michelin Bopper 130/90-10 front and rear tires, Polini 66cc BBK, Beast Mode Fuel Tuner, Polini Air Filter, Polini Variator, 6.25g Rollers, Malossi 13/44 Gears, Malossi White Contra Spring, Koso 1000 RPM Clutch Springs
2013 Red Honda PCX 150 - Stock (Crashed into a deer August 2018 :( RIP)
2014 Red Honda Forza 300 - Stock
Wed Mar 06, 2019 8:28 pm
Post Re: Zuma 50F Polini Big Bore Kit + Mods
Just finished installing everything except the malossi yellow 1500 contra spring. Was not working well with the new belt. Also didn’t use the 6.9 gram roller weights that the Polini variator came with. It’s cold and snowing right now and freezing out (awesome Springs in New England!) so I haven’t really driven it for more than a couple miles but will definitely be driving it more on warmer days to break in the engine. Gonna do about 150 miles before I go full throttle. I also might try Dr Pulley Sliders in the future. Not sure if I’m gonna do 5g or 6g. They’re expensive to experiment with.
Thanks for checking on my post and stay tuned for updates! :)
File comment: The Malossi Yellow contra spring kept slipping so I didn’t leave it in. Bought a white malossi spring and will install that in the future
Fri Mar 22, 2019 5:33 pm
Thanks for offering this. I've been curious about how these 4T versions might do if they're improved and tuned well. Will be keeping an eye on the progress.
Stock '05 Zuma - in the wild somewhere.
2015 Zuma - Stock. For now.
Sun Mar 24, 2019 8:58 am
So I took the Zuma for a 10 mile ride today. It was about 50 degrees so not the warmest. I’m pretty disappointed in the performance of the scooter after I installed all these parts. It feels like it has a slower take off and won’t go above 30 mph on flat at full throttle. I understand this is the break in period but it was only going 25 at half throttle so I wanted to see what it could do at full throttle. It also stalls out when I stop for a few seconds. It also doesn’t like to start up right away. I have to hold the start up button for 10 second when it used to be 1 second.
It’s performing worse than when it was stock. :gonk:
Not sure what to do right now. Either take out the Polini air filter or buy a fuel controller but they’re $200 and that’ll have to wait till next month to get. I’m assuming it’s not getting enough fuel and that’s why it can’t go above 30 on flat or it’s getting too much air from the new filter and Polini air snorkel. Ugh this is gonna be a stressful build. I’m hoping for tips but no one is on this forum anymore so it’s gonna be all trial and error.
Sun Mar 24, 2019 4:11 pm
I'm wondering if exhaust is your problem. If you're pushing more fuel into the cylinder, but the exhaust isn't able to escape fast enough after it's spent, you're bike isn't going to perform well. Don't know much about the 4T versions, but I imagine the stock exhaust isn't designed for strong ventilation. Especially seeing as one of the reasons Yamaha went 4T was because of the hyper restrictive emissions standards in places like California.
Mon Mar 25, 2019 10:48 am
I don’t think I’m pushing too much fuel I think I’m not pushing enough for the 66cc engine to need to perform correctly. I think it’s the new air filter that’s causing it to not perform correctly or not enough fuel is getting to the engine. I hope it’s just the air filter though. I don’t want to buy a fuel tuner for $200
Mon Mar 25, 2019 2:38 pm
So I now know why the scooter is running like crap. My mechanic didn’t put the fuel pressure regulator that the Polini kit came with into the scooter. So it’s been running with the stock fuel injector :doh: now it all makes sense. I found it with my original parts that came out of it. Gotta call him up and have him put it in. It’s gonna be 66 and sunny this Saturday so then I can finally break her in and I’m sure she’ll be running like a dream :awesome:
I’ll let you guys know how it goes
Tue Mar 26, 2019 10:03 pm
UPDATE:
Put the new fuel regulator in that cane with the Polini BBK and she is running great now. Way better acceleration compared to before and before stock as well. Climbs up steep hills at 30 mph and I was only a little over half throttle when before I had to be full throttle to go up a steep hill. I also GPS 45.3 mph on flat road but pulled off the throttle because I’m still breaking the new engine in. Should be able to do 50 on flat once it’s all broken in. I burried the speedo down a hill but let off the throttle again cuz a car pulled out in front of me. I was doing probably around 52-54 mph and still not hitting the rev limiter.
I’ll let you guys know how it is once she’s all broken in but for now I’m pretty happy with the results.
Thu Mar 28, 2019 3:40 pm
scooters and mods: Vino 125(dead) Riva 125(dead) Zuma 125(stolen) Derbi Atlantis(sold) Puch Maxi(restoring) Adly RT50(daily rider)
Thanks for sharing your experience! Likewise I've not read much about the newer 4T Zumas and I'm interested in adding more to the old knowledge bank.
Tue Apr 02, 2019 12:53 pm
UPDATE:
So as I was driving the Zuma today I was going up a hill and suddenly it lost all acceleration and just died on me. When I started it back up and gave it gas it died again. So I was like “oh great what’s wrong with it now” and called my mechanic to pick me up. 10 minutes later I read some posts online to see how other people got it to run again or what was wrong and a guy posted “did you check the gas to see if you’re out?” Doh! I’m an idiot! :doh: Didn’t even think to look cuz I put $2 in about 90 miles ago. I called my mechanic and let him know it could just be out of gas. There was a small puddle of gas in the tank when I checked but I guess that little amount doesn’t reach the fuel line. They brought me gas, low and behold she started right up. Boy did I feel stupid :awesome:
But anyway I’ve put about 120 miles on her since the new kit has been install. Gonna do about 30 more before I change the oil and then drive it like I stole it lol. Also will be adding 5.5g sliders and new 1000 contra spring as well and clutch springs
Sun Apr 07, 2019 6:47 pm
Here’s a video of my progress. Before and after the big bore kit:
https://youtu.be/6-RxK0B7cqQ
And here’s a shortened version of the same video with a side by side comparison of before and after:
https://youtu.be/ampa194MAls
Sun Apr 14, 2019 2:07 pm
Here’s a screenshot of my downhill speed. It was a pretty long hill but I never hit the Rev Limiter. Would be awesome if I could hit 55 on flat :awesome:
Sun Apr 14, 2019 5:53 pm
Dude that's so awesome! I have a 2015 Vino 50 and desperately want more speed out of it. I was hoping you had the Fuel injected model, and it turns out you do. You've given me hope that I too can enjoy a realistic speed to actually drive this thing on roads. So what is your top speed now that you've completely broken her in? I was looking at a $400 70cc kit that includes a fuel tuner. I don't think it comes with an injector. It sounds like your Polini kit is a good and much cheaper alternative.
Any idea how much worse your fuel economy is now?
Thu Apr 25, 2019 1:53 pm
I chose the Polini kit because it came with the fuel pressure regulator. I didn’t want to deal with a tuner and there’s a 75cc kit out there for $450 but it doesn’t come with a fuel tuner. There’s no 70cc kit yet, though. I only put about 250 miles on mine and not sure if it’s 100% broken in yet. I heard 600 miles for a break in period and it’s like 47 mph on flat but I have 6.9g rollers so I’m gonna try sliders and Michelin Bopper 130/90-10 tires next with it. My fuel is around 100 mpg when before the kit it was around 120 mpg so it’s not too bad. I want mine to hot 50 mph on flat road. So far I haven’t gone past 55 down hill but haven’t gone down many hills. Rev limiter with probably kick in around 58-60 mph
Fri Apr 26, 2019 12:58 pm
It’s been awhile since I made an updat but I figured it’s time now that I’m all done adding to this scooter. Just put on Michelin Booper 130/90-10 on front and rear, also adding the rollingwrenchdenver.com fuel controller as well as 6.5g rollers. I tried 5g sliders and they just didn’t feel good. There was this weird delay when I gave it throttle and I made sure to install them correctly. Next I tried 8g sliders and thought they felt better but my speed was slightly reduced on flat and considerably down hill. Before I could go 54.4 mph down hill with 6.9g rollers and now I went 52.9 and hit the rev limiter. I removed the 8g sliders and put 6.5g rollers in. I’m done with sliders lol waste of time and money. I’m still averaging 45-47 on flat with occasional 50 if it’s a flat that turns into a very gradual down grade (this is all gps speed as seen by using my cell phone) the scooter speedometer is 2 mph off.
Well anyhow I now can go almost 57 mph down hill! But that’s all. I hit the rev limiter at 56.9 MPH GPS confirmed.
I realize this thing will never go 50 on flat so my battle ends here. Time for me to get a Zuma125 and big bore that next :awesome:
Fri Jun 28, 2019 8:44 pm
Users browsing this forum: Andrewodory, VincentWen and 2 guests
