View unanswered posts | View active topics It is currently Tue Jun 18, 2019 6:43 am
 50CC Yamaha Zuma won't crank/roll over
Post 50CC Yamaha Zuma won't crank/roll over
First time poster... long time lurker... Last year I was basically given a 2006 Yahama BWS 50CC scooter. At the time when I got it from what I could tell all it needed was to have the carb cleaned, maybe a new spark plug, new battery... nothing crazy but I do recall giving it more than a few kicks on the kick starter at the time I got it.
Fast forward to now... It's the long weekend and I decided to take a stab at getting it running. I got a new battery installed, new fuel, I got the carb cleaned up and went to go start it up when I discovered that neither the electric start or the kick start seem to be able to roll the engine over. I hesitate to use the term seized but it certainly seems that way.
I'm wondering what I should do as a next step to try to figure out whats wrong? Any thoughts or suggestions are appreciated.
Ken
Mon May 20, 2019 12:49 pm
Post Re: 50CC Yamaha Zuma won't crank/roll over
Just to make sure that it is seized before you tear the cylinder down
Take off the cvt cover and turn it over with the key if you dont see the front variator fan moving .
Then try to move the pulley by hand .
The next step will require alot more strip don of the zuma and looking at the condition of the cylinder .
2004 Zuma Malossi sport 70 cc Technigas next r polini green springs stock clutch 2008 zuma torque driver polini high speed variator 5.5 grams sliders Stock Carb 82 main jet 46 pilot jet needle 1 clip rich stock athena 14/42 gears 11 to 1 final ratio 56 mph
Mon May 20, 2019 1:25 pm
