View unanswered posts | View active topics It is currently Tue Jun 18, 2019 8:18 am
 17.5mm or 19mm for Buggeye sport cylinder
scooters and mods: 2005 Zuma, Athena alu. Sport 70cc, Giannelli Reverse pipe, NCY variator and clutch, UNI flat filter in 125cc airbox,
Post 17.5mm or 19mm for Buggeye sport cylinder
Forgive me for asking this as I'm sure it's been answered/explained somewhere on here but I just cannot seem to find the info by searching.
I am finally completely fed up with the stock carb and want to upgrade to either a 17.5mm or 19mm Delorto for my Athena 70cc sport (10mm) (aluminum) cylinder. What are the pro's and cons of both? I definitely want to keep my stock airbox but will I need to upgrade my intake and reeds/cage? Since I'm already running an aluminum sport cyl. and Gianelli reverse (high RPM pipe) would it be bad to try and tone it down (still running 10mm crank bearing) with a smaller carb like the 17.5 or would it be best suited to run the 19mm as to match the intent of the sport cyl. and pipe?
2005 Zuma 50, Athena Race BBK, Giannelli Reverse exhaust, NYC Transmission kit, Dual Headlight LED's, 125cc airbox & filter, carbon reeds in stock block, vented CVT cover, moto style kickstand, moto number plate stickers (+1/2HP)LOL,
Sat May 25, 2019 6:15 am
Post Re: 17.5mm or 19mm for Buggeye sport cylinder
Code good to see you back
here is a reference with dynos
http://www.pedparts.co.uk/blog/yamaha-a ... comparison
I am looking at a new carb it is on my christmas list so I am early in figuring this out .
I have a graph saved somewhere from a different scooter shop that 17.5 works for up to mid race cylinder and pipes after that a 19mm starts to work better .
A 19mm works for sports 70 up to race .
So for me I will take the one I get a better deal on because I will stay at a sport build .
This thread seems to lean toward the 17.5 or imply it also is good enough
viewtopic.php?f=23&t=23676&hilit=carb+selection+dellorto+carb&start=45
2004 Zuma Malossi sport 70 cc Technigas next r polini green springs stock clutch 2008 zuma torque driver polini high speed variator 5.5 grams sliders Stock Carb 82 main jet 46 pilot jet needle 1 clip rich stock athena 14/42 gears 11 to 1 final ratio 56 mph
Sat May 25, 2019 7:04 am
Based on the reports I've always heard in the past, a 19 mm may be a bit wasted. It's not bad, it's just not necessary. Main con weighing against a 19 mm is that many people report that they end up being difficult to get into tune. As for trying to "tone it down" I'm not entirely sure what you're implying. If you're thinking about rpms, then the carb won't have any bearing on that.
05 Zuma
Stock. Blank canvas. =D
Sat Jun 08, 2019 3:17 pm
