View unanswered posts | View active topics It is currently Mon Jun 25, 2018 1:11 am
Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
 Need help asap. Vino only goes up to 40 mph.!!!!!
Post Re: Need help asap. Vino only goes up to 40 mph.!!!!!
Yes, tire pressure can effect this greatly. But only going 40mph? You'd have to be rolling on some flat arse rubbers.
1K in you'll not be having clutch issues so that's out too.
What's you're elevation?
Quote:
So after a 45 ride with my friend, on the way back home my Vino 125 tops out at 40 mph.
45 mile ride or 45 mph ride? How fast did it go before this issue?
Compression could be an issue, possibly, but most likely not.
Check the oil level?
Notice anything round about the time that it started running slower?
Zuma 125: Malossi Vari, 8g rollers, 1500rpm torque spring, NCY adjustable clutch, BTX air intake, Group Racing gas shocks, Yoshimura CF exhaust, Vertical headlights, Corbin seat, Stretch kit.
Fri Oct 15, 2010 11:12 pm
It could be as simple as a throttle ajustment. Lose cable?
Wed Sep 14, 2011 11:24 pm
Check the throttle cable adjustment, maybe it's lose.
Wed Sep 14, 2011 11:36 pm
Oil change and air filter. U are oil is breaking down. After that open the cvt and check if belt is too thin or loose. Most likely it s stool oil, switch to mobil1 synthetic v-twin. You get all your performance back.
09 z125 "Black draggin" stretched, slammed & screaming
156cc takegawa bbk, koso tb &intake manifold, RC high flow head & cam, TBR exhaust & JBpro, ncy di coil, SRP injector, 2.5+crank w/ double H rod. PG swingarm, Platinum air suspension, composimo stretch, Brembo 4pot with 260mm rotor. RC TsT CVT. 13t upgear Alligator side body panel and python wrap frame. odessy battery.
Sat Sep 17, 2011 4:04 pm
mrcrx28 wrote:
yea, I also posted this on scootertime and provo as well Mobilier design. Imma look over all the things that was discussed and hopefully it shouldn't be anything big or serious. Well, the Vino was purchased used from private seller so I dont think warranty still exist. :doh:
But you can also see the sellers of spare parts if you find one....
Wed Jun 28, 2017 4:53 am
mrcrx28 wrote:
So after a 45 ride with my friend, on the way back home my Vino 125 tops out at 40 mph. I didn't hit any potholes or other objects on the road. I also noticed my pick up is slower than usual. I'm new to scooters and any help is greatly appreciated. Vino only has about 1,000 miles if that. What are some of the things I should check that could cause this problem??
Check your RPM, if your RPM is high but the speed is too slow. That's where the problem is. You should ask your mechanics to check the wirings.
Web Designer at Petstreetmall
"We are your pet supplies expert"
Sun Aug 06, 2017 10:12 pm
