View unanswered posts | View active topics It is currently Sun Jun 17, 2018 8:44 pm
 2009 Vino 125 Idle Issues
Post 2009 Vino 125 Idle Issues
Hello,
I have a new 2009 Vino 125 that was sitting since 2013, only 41 miles on the scooter. I am having idle issues, I believe due to fuel sitting in the carb for years. First I have replaced the gas, and the bike fires right up, but in order to keep it running I have to keep reeving the throttle. But as soon as I let go of the throttle it dies. I am assuming it it a clogged carb needle or float? Just wanted to ask before taking the carb apart.
Thanks JR
Sun Aug 13, 2017 1:18 pm
Post Re: 2009 Vino 125 Idle Issues
The secondary is probably plugged.
Tue Apr 24, 2018 11:37 am
2 options
1 over dose the tank with seafoam and see if you can get the carb to clear itself this normally does the trick with my elite 150 but the longest it has sat is 2 years
2 pull the carb take it apart and clean it
2008 stella olive custom ported 177 cc kit dechromed ford tear drop tail light alive and breathing and awaiting cosmtic surgery thanks to an donkey hind quater hole cager
Tue Apr 24, 2018 4:52 pm
I use quicksilver power tune. You stick it in the fuel line and give her a squirt. Works pretty well. Cleans out the bowl like new. On my 50 I had to actually take out the secondary jet and then stick it in and blow out whatever was plugging it. Let it sit for a minute and then did it again and brown nasty came out.
Wed Apr 25, 2018 5:04 pm
