View unanswered posts | View active topics It is currently Thu Dec 13, 2018 4:45 am
 Installing a Roketa Sicily rear section on a Vino bolt on?
Post Installing a Roketa Sicily rear section on a Vino bolt on?
The more I look at these the more I think the plastics are interchangeable with the vino 125's. ...
Their rear section is much cleaner than the vino... agree?
I wonder if it's a bolt on dealio.
Look how close to a vino 125 it looks! The screw holes appear to be in the same spots.
but they have a sweet tailight setup :D
Sat Nov 12, 2011 4:08 pm
scooters and mods: '08 zuma 50 & '06 vino 125
Post Re: Installing a Roketa Sicily rear section on a Vino bolt o
you can buy that tail light and turn signals from scooterwest.com. they use them on the vinos in japan.
'06 vino125 55mph 85mpg
'08 zuma50 53mph 65mpg
Sat Nov 12, 2011 10:01 pm
Users browsing this forum: Google [Bot] and 0 guests
