View unanswered posts | View active topics It is currently Mon Mar 19, 2018 11:12 pm
 2009 Vino 125 Upgrade install
Post 2009 Vino 125 Upgrade install
Hello everyone
First time to have Carburator scooter.
I want to upgrade my vino since all my friends have a vino but want mine to have alittle bit of power. Yes people might sayd just buy a bigget motor, but I already have a GTS250 and a SC250
Any suggestions what jettins I need? Also when I install the BBK and Cam, what should be the valve clearance and piston ring clearance
So far I bought this parts from jiangwayne
Adjustable throttle cable
Aluminum Intake Manifold
Racing Hi Flow 45deg air filter
Ruima High Angle Shaft
Big bore kit
Original size: ø51.5mm x60.0 (124cc, 2V)
Cylinder ID: ø55.0mm x60.0 (143cc, 2V)
Wrist Pin OD: ø13.0mm (Stock)
1. Cylinder x1
2. Piston x1
3. RIK Piston Ring x5
4. Ping x1
5. G-Ring x2
6. Gasket x2
Bought the Carb from Jetsrus
Keihin PE 28mm Japan Main Jet 125 Slow Jet 40 Jet Needle 46-JFN Float Height 19mm
NCY Perfomance exhaust.
Im thinking of buying this transmission setup after I break in my BBK. Any suggestions?
NCY Super Transmission Set; Yamaha 125,
Ultralight gold teflon coated overdrive variator
Ultralight outer drive face
Ultralight large shoe racing clutch
Ulltraight drilled & vented clutch bell
Dual range secondary slider
roller weights
Compression spring
Ball bearing compression spring seat
Thank you in advance
Thu Nov 13, 2014 10:37 am
Post Re: 2009 Vino 125 Upgrade install
light weight at the clutch will help acceleration but makes holding the top end harder
same with the flywheel
Sat Nov 15, 2014 6:03 am
Finally finished my upgrade except for the transmission. It fires right up and idles fine. Took it for a ride after I warmed it up. It started fine from 0 to about 1/4 to 1/2 throttle then it bog after that. I would WOT, the it will either go up to 30mph but it really struggles like it about to cut off. I would let go of throttle and it would die. Should I lower the jet from 125 to 110? Its a Keihein PE28mm Carb
Mon Jan 26, 2015 12:22 am
