View unanswered posts | View active topics It is currently Wed Jun 26, 2019 11:34 am
Reply to topic  [ 173 posts ]  Go to page Previous  1 ... 8, 9, 10, 11, 12  Next
 Here's a list of available Zuma 125 tires.
Post Re: Here's a list of available Zuma 125 tires.
I just replaced my OEM tires. They're sitting in my garage now collecting dust.
Thu Aug 07, 2014 7:45 am
scooters and mods: 2014 Zuma 125
RideOrDie wrote:
Any pics zman? How do they ride?
Pix below. I've been very busy lately so I only have about 20 miles on these new tires but they've been ok. At least nothing that I noticed differently versus the OEM dual purpose tires since I don't go offroad.
F - 100/60-12
R - 110/70-12
Mon Aug 25, 2014 4:41 pm
Post Re: Larger tires on my Zuma 125?
can i install a 130/70-12 up front and a 140/70-12 on my zuma 125? Are there any repercussions on performance and or handling? TIA
Fri Oct 24, 2014 11:36 am
Your turn in rate will be affected. Essentially with wider tires, you can either say initiating a turn will be slower or you'll have to exert more effort to make that same turn as you would with stock widths. Upswing is it will feel more planted or stable in mid corner thru exit.
Whats the reason you want to go wider?
Sat Oct 25, 2014 1:27 am
I thought that a wider tire would improve handling. I bought a 11' zuma 125 with 700 miles on it so the tires have been on there some three years and rarely used. I dont like the way the OE tires wanders a bit when rolled on there side. I'd iike a tire set up that, maybe combined with lowering the fork, could decrease or neutralize the scooters rearward weight bias and improve the scooters handling.
Sat Oct 25, 2014 10:25 am
too wide up front loose speed too
someone here had that happen
Sat Oct 25, 2014 1:25 pm
Depends on what you mean by improving handling. You will have to prefer one or another: quicker turn in or stability. Sounds like you want stability. Also to add on what mike said above, I've never heard of anyone going wider in the front. Rear only since this is where the power train is connected to. This is all coming from experience with track riding my R6. Things may be different now, but that's my $0.02.
Any rearward bias or balance settings can only be done with adjustable suspension (preload/rebound). Tires won't help that.
Sun Oct 26, 2014 1:23 pm
Ive been messing with tire pressures since the OE suspension lacks any kind of adjustability. Im running the front tire about 3 psi less than the rear in order to slow down the turn in up front. The results have been barely noticeable since the OE tires are shite. Having read this multi page thread i see what tires are popular but not too much about which work the best on the zuma. I had kenda "34s"? on a aprilia sr 50 and they were alright but i never really pushed um since going fast on the aprilia was sketchy. Sticking with the OE sizing i like the SL 23-25.
Wed Oct 29, 2014 9:02 am
soon to roll over 6000 miles on my first set of OEM's and am nearing bald on the rear (fronts got plenty of life left)
What seem to be the most popular tire? I tried browsing through the thread but didn't find a signle tire that stood out.
99% city riding with GOOD wet performance is what i'm after.
Tue Apr 14, 2015 10:14 am
I have had great success with the Pirelli GTS 23 / GTS 24 tires. Fantastic wet traction and water displacement.
Wed Apr 15, 2015 1:55 pm
over 6k miles on my rear with plenty of tread left. great tires.
Thu Jun 25, 2015 10:31 pm
scooters and mods: 09Zuma125,simota a/f,c3 mirrors,red instrmt LED,Koso tail,LV Exhaust,Dr. P var,11g sliders,12t u/g,Polini Bell,Piolt SCs
So I have enjoyed my Michelin Pilot sports for about 8000 miles and its time to replace them...except it looks like they've been discontinued! :doh:
I'm looking at the City Grip or maybe the Boppers...Anyone vouch for either of those?
thanks~ :cheers:
Mon Jul 20, 2015 7:33 pm
Got stock size boppers on the way...
Wed Jul 22, 2015 7:16 pm
Michelin Power Pure SC Tires en route for me, went with stock sizes (or as close to)
stock rear lasted 6k miles, fronts still got plenty of life left though, but i'll be swapping front and rear for the power pures
Mon Aug 17, 2015 8:25 am
Just got back from the local Yamaha dealer getting the tires mounted, but they don't have the ability to balance them.
Sat Aug 22, 2015 2:00 pm
