View unanswered posts | View active topics It is currently Sun Apr 22, 2018 12:55 pm
Reply to topic  [ 25 posts ]  Go to page 1, 2  Next
 Electrical Guru Needed Code 42~!
Post Electrical Guru Needed Code 42~!
So can someone figure out how to bypass the wheel sensor code 42. I want to eliminate my cluster and rock a different front wheel. How are the BWS guys in taiwan able to rock a different wheel. No code 42 for asian models?
Thu Dec 02, 2010 12:55 pm
Post Re: Electrical Guru Needed Code 42~!
Define "bypass" please. What is a wheel code 42? More info please. I may be able to help.
:confused:
It is better to travel well than to arrive.
The Buddha
Thu Dec 02, 2010 12:58 pm
mechanical wheel sensor from cluster. detects mechanical wheel sensor and lets ecu know your bike is actually running and not stationary.
Thu Dec 02, 2010 1:03 pm
Contact chris from raceconcept i believe he runs a zuma 125 with the same front tire on his BWS
2009 yamaha zuma 125 TBR M2 exhaust system custom made 10 inch muffler,custom air intake,UNI air filter,Asian headlight comversion,15 led auxilary top light,HID 6000k xentec 35w lower light,iridium spark plug,synthetic oil,led red guages,Ruima racing cooling fan,yamaha logo fan cover,NCY super tranmission,13/39 gearing,BWS-x smoked turn signal lense amber 23w bulbs,Koso led taillights with intergrated turn signals,Koso diamond mirrors,chopped rear fender,black widow graphics, progrip jetblack rally grips
2009 Yamaha Zuma 125
2009 Yamaha C3 50
Thu Dec 02, 2010 2:24 pm
the one in the picture looks like it still has the mechanical speedo going to the wheel?
can't remember who's thread it was in but i think they just took apart their speedo and left everything hidden in the front panel. technically not really bypassing it though.
We need better pics of that trick swingarm. Looks pretty cool from what i can see.
Thu Dec 02, 2010 5:29 pm
Looks like the pg one that Chris sells.
Thu Dec 02, 2010 6:55 pm
Remove the odometer from the speedo and hide it behind the front panel. There are different front wheels that will work with the speedo as-is.
Thu Dec 02, 2010 7:00 pm
that spoke front wheel setup is made for the z125 and still uses the speedo cable.
how to bypass code 42 i would have to ask around. i want to know also since i won't use the stock speedo and rock a GPS unit.
here are some pics of the PG swingarm kit. btw the black swingarm is the current one (version 2), has been revised.
http://www.rcscooters.com
Thu Dec 02, 2010 8:16 pm
Chris,
how much is that PG Swingarm kit????
Thu Dec 02, 2010 10:05 pm
dougs1219 wrote:
Chris,
viewtopic.php?f=58&t=14263
Thu Dec 02, 2010 11:24 pm
This is not a swingarm promotion topic. Please keep posts on topic or they will be deleted.
Fri Dec 03, 2010 6:50 am
i was never known to stay on topic but yah sure i will try to remember that next time i post. happy Hanukkah :cheers:
Fri Dec 03, 2010 7:20 am
Thanks.
Fri Dec 03, 2010 7:37 am
You are not a moderator, let them decide what will be deleted.
Fri Dec 03, 2010 10:05 am
Users browsing this forum: No registered users and 8 guests
