View unanswered posts | View active topics It is currently Wed Jun 26, 2019 3:41 pm
Reply to topic  [ 91 posts ]  Go to page 1, 2, 3, 4, 5 ... 7  Next
 Serenity
scooters and mods: Zuma 125
Post Serenity
And so begins the tale of my little project. Two years on, bit by bit.
First up: 155cc BBK, 10 hole injector, high lift cam, Simota air filter (thanks Chris) and fancy valve covers. Shiny!
I added this over winter break and am still running it in. As funds allow I'll add a bigger TB and manifold, Large valve head, higher gears (maybe) and fuel controller. I need a good power to MPG ratio to match how I ride. I plan on going on some longer trips in about the stupidest (and most fun) way possible.
One of the first things I did when I bought the Zuma was to change to a RGGS variator, KOSO clutch, and a 2 Bros. exhaust ($185 used :toot: )
The exhaust clamp didn't quit fit right, so I took 5 minutes and solved that problem.
Cut, overlap, weld.....
I also didn't like only having two mounting points. The can moves too much.
Make a bracket....
Bolt it all up....
And everything is solid :)
I wanted to clean up the back some, and Rushin had the answer ( I love buying used stuff).
I have something else in mind for the front signals, but that'll have to wait.
I almost forgot my pegs.....
The latest addition is to the front. In keeping with my theme, it's ugly but functional, just like Serenity.
I must have more room for my stuff.
Tack a bit of flat bar to the brushguard and proceed to hack away.
Make a platform.
Mon Jan 24, 2011 7:01 pm
Post Re: Serenity
Weld it all up, and see how it fits.
Not quite level, but it'll do.
Wait! Did I make it the right size?
Seems so. I'll make a bracket for the ammo can so it can be clamped into place, and bungee the gas can.
It's good to have options (and an extra 80 miles of gas).
Here it is all tarted up and ready to go out.
If I were going to make another I'd make four changes.
1. invest in a spool gun (see # 3)
2. Invest in a tubing bender
3. Make it out of aluminum instead of using the brushguard as a base. It was a PITA to get the cuts correct (see #4), and it weighs 3 pounds.
4. Make a jig so I can save myself about an hour of cursing.
5. ( I know that I said 4, but it's 5 :butt: ) Add a guard for the headlights. I would have done this, but it's already heavy enough, and I don't want to over-stress the subframe.
Paint and other assorted stuff ( It's not quite ready to go on yet Shawn) to come as time and budget allows. :cheers:
Post Re: Serenity
Ok now that's cool, sure beats the "basket" Florida guy was talking about. Its practical, maintains the US Zumas rugged look, and certainly individualizes the scoot. Its going to look great with matching paint :cheers:
http://www.zumaforums.net/phpBB3/viewtopic.php?f=54&t=14494&hilit=basket
Mon Jan 24, 2011 7:23 pm
Post Re: Serenity
Looks good...for those needing extra storage. I love making my own dookie...it takes time, as you said, but its cheap, fun, and satisfying. I love "one off" stuff made by owners.
Necessity is the mother of invention!
Mon Jan 24, 2011 7:47 pm
Post Re: Serenity
nice work on the rack kmoe. :cheers:
Mon Jan 24, 2011 9:06 pm
Post Re: Serenity
My 2 bros clamp was loose too, but I called them and they sent me a new one free that fit tight.
Ever see MSR fuel bottles, sold for camping fuel. I used to use those for my duel sport
Almost like those metal drinking bottles sold now, they have loops in the cap to string them together, but I figured they fit under the seat
I think the 22oz size bottles cost me like $10 each, so they are pricey but was a better option for me instead of the plastic cans
Mon Jan 24, 2011 9:12 pm
Post Re: Serenity
Good job K-Moe ...
If you get into 'production.mode' with the front rack ... I'll take one !!
But ...
I actually thought that this topic was spam when I saw the title ::
Thought that someone was selling SERENITY !!
It's a lithium orotate combination - intended to treat bi-polar, but over the counter ...
As presciption drugs go, its pretty dangerous
you have to go for regular tests to check for the level of the drug in the system
and overdoses of it are rather fatal ...
Tue Jan 25, 2011 5:19 am
Post Re: Serenity
Looks very unique in a good way! Now all you need is a gun rack that mounts to the rear frame rail(s) to go into combat!!! Image :jihad:
Tue Jan 25, 2011 9:25 am
Post Re: Serenity
Cool rack mod, K-Moe! Planning an adventure ride on the Zuma? Image
Tue Jan 25, 2011 2:25 pm
Post Re: Serenity
Thanks for all the positive comments.
Zumike: I'd have called 2 Bros, but I figured it would take longer to call than it would to fix the clamp. It was literally a 5 minute job.
I have considered using a fuel bottle, but they are a hassle to fill at the gas station. I still might go that route depending on the particular trip.
Bio: I totally forgot about that particular medication. Putting the rack into production is a possibility, but I'll need to ride the crap out of the first one and make some changes for it to be affordable. There is way too much fitting and welding time involved with the way I made this one, and I think that I can make it a better value with some changes.
JohnnyFYX: Fishing pole rack :waycool:
johnnysmokes: I plan on going on some fishing and photography trips this summer. 12 MPG is not sounding good for the budget this year, so the Zuma will be getting me there. HAHA Seinfeld, another show that I miss. At least it went off the air for a good reason.
Tue Jan 25, 2011 3:24 pm
scooters and mods: 2009 yamaha zuma 125 TBR M2 exhaust system,air intake,dual headlight conversion,xentec HID 6000k coversion kit,led red g
Post Re: Serenity
Make a bracket....
Bolt it all up....
Make a platform.
My TBR clamp didnt fit right as well so i got a thin piece of rubber and cut it to size and placed it under the clamp and it fits tight like a glove now. but ur idea was a great idea.
2009 yamaha zuma 125 TBR M2 exhaust system custom made 10 inch muffler,custom air intake,UNI air filter,Asian headlight comversion,15 led auxilary top light,HID 6000k xentec 35w lower light,iridium spark plug,synthetic oil,led red guages,Ruima racing cooling fan,yamaha logo fan cover,NCY super tranmission,13/39 gearing,BWS-x smoked turn signal lense amber 23w bulbs,Koso led taillights with intergrated turn signals,Koso diamond mirrors,chopped rear fender,black widow graphics, progrip jetblack rally grips
2009 Yamaha Zuma 125
2009 Yamaha C3 50
Thu Jan 27, 2011 7:56 pm
Post Re: Serenity
great job on the front rack!
http://www.rcscooters.com
Thu Jan 27, 2011 8:30 pm
Post Re: Serenity
Thanks Chris.
I decided that it would be a good idea to adjust the clutch to better suit the 155, so I went ahead and put in the Majesty gears that I have while I had the transmission open. I just got back from the first shakedown run with the front rack. I expected to hear a whistle or something above 45. I heard not a peep. Not even at an indicated 70. I was really happy to finally be able to hold a steady 60 MPH, even with a headwind. Hopefully I'll keep getting enough work to be able to afford the rest of what I need to finish, but I am happy for now.
Fri Jan 28, 2011 5:45 pm
Post Re: Serenity
The weather was decent today, and the 155 is nearly broken in, so I went for a quick ride.
Top speed, going up a 2% grade with a 17 MPH crosswind. :q:
Pay no attention to the fuel cost. It's from the last trip I made in my Durango.
Mon Feb 28, 2011 3:23 pm
Post Re: Serenity
So your scoot is now blessed by the mark of the devil, sweet
Mon Feb 28, 2011 8:36 pm
