View unanswered posts | View active topics It is currently Wed Aug 21, 2019 4:59 am
Reply to topic  [ 47 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Getting a Spare Key Made???
scooters and mods: 1990 Zuma II *SOLD* 2009 Zuma 125
Post Re: Getting a Spare Key Made???
cbolling wrote:
1st of all, to those that asked, I bought it used and only got 1 key.
2ndly, I was on my way to the dealer a few minutes ago to just buy the set of keys. $40 really is pretty cheap for the set and the cylinder. Then I realized that there was a problem. I stopped on the way and got some gas. :doh:
If I get a new set of keys, how will I open the gas cap? :confused:
The keys are already precut? they shouldnt be unless they come with a new ignition as well and not just the security cover.
"I'm your Huckleberry..........."
1990 CW50TA Zuma II Black and Yellow *SOLD*
2009 YW125B Zuma 125 Mine is Black SOLD
2009 YW125Y Zuma 125 Hers is Yellow*SOLD*
Tue Feb 22, 2011 6:55 pm
They'll be precut if you order them by the key tag code. I don't think that code is there just for the switch cover magnet.
Tue Feb 22, 2011 7:03 pm
K-Moe wrote:
I use a plastic putty knife to slide between the panels to release the plastic tabs without the risk of having my finger cut off :mmmhmm: .
I think theirs only a hand full of us that remember that thread. Ohhh the Drama........ :gonk:
Tue Feb 22, 2011 7:06 pm
. go get some hid's and make it worth while to take the front off
Might as well :cheers:
Tue Feb 22, 2011 7:08 pm
Thats what I was thinking. So if thats the case then opening the gas tank shouldnt be an issue because he would need to get the keys cut to his ignition/gas cap anyway right?
The only issue remaining would be magnet matching.
Tue Feb 22, 2011 10:11 pm
They new keys will have the correct magnet when they are made with the proper key code ( or vin# if it can be cross referenced.) If the vin# can't be crossed to the key code (since he doesn't have the key code) then he'll have to switch out the keys and all locks as a set.
Tue Feb 22, 2011 10:42 pm
Are you guys dissin' the FG ??
He's right here today ... maybe he'll pipe in about loosing his keys.
Dynamo55b wrote:
I think theres only a handful of us that remember that thread. Ohhh the Drama........ :gonk:
Wed Feb 23, 2011 12:28 am
scooters and mods: 2009 Zuma 125, 2001 Honda Shadow
Well I decided to go ahead and get the spare keys. They told me it was about $40 but when they rang it up it was only $24.97!
As you can see in the pictures it is just the faceplate. The actual cylinder stays put. Since I had my old key they just cut it the same as the old one so there won't be any problems with the ignition or the gas cap.
http://www.advrider.com/forums/showthread.php?t=661436
Tue Mar 22, 2011 3:37 pm
Cool :cheers:
That makes sense from the standpoint of shipping and stocking parts. It's probably much cheaper to have matched sets of blanks and bezels in the system than to have every combination of key blank and every bezel separately.
Tue Mar 22, 2011 6:13 pm
scooters and mods: 2009 Zuma 125-C3 Mirrors, GPS Ram-Mount, Stebel M80 Magnum low tone horn, KS/BTX Forward Pegs, Rear Rack w/ GIVI trunk
johnysmokes wrote:
My keys came with a little metal tag with one letter followed by three numbers. The owners's manual says that's to order replacement keys.
I would think a dealer would have a way to find that code with your vin. Image
Probably not. That would lead to too many stolen Zumas getting new keys supplied by Yamaha!
2009 Zuma 125 picked up 9/21/2010 with 9/10 of a mile on the odo
KS/BTX Forward Pegs, Rear Rack with GIVI trunk
Clocks4Bikes Handlebar Clock, Termoscud Lap Apron (seasonal)
VA Tag: 96 MPG
Rolling Thunder/Ride of the Patriots 2012
Rolling Thunder/Ride of the Patriots 2011
Member # 1807
http://www.facebook.com/steven.levine1?ref=name
Gone, but not forgotten:
2008 Zuma 50--FAREWELL PARTY-SEPTEMBER 30, 2010
Co-SOTM November 2009
Rolling Thunder/Ride of the Patriots 2010
Tue Mar 22, 2011 6:42 pm
I guess not, seeing what the OP went through. Hang onto your keys, guys!
Tue Mar 22, 2011 7:01 pm
Can I get the part number off the bag that it came in?
I want to order the exact same thing.
Wed Mar 23, 2011 11:47 pm
5S9-WH250-10-C0
Fri Mar 25, 2011 8:56 pm
The go to guy for keys (even the chiped ones) is, http://www.allmotorcyclekeys.com/products.php?cat=24
About 1/3rd the price of anywhere else an a great guy to deal with. My local locksmith tried to rip me off.
Blurgrass :cheers:
Tue Apr 05, 2011 7:33 am
scooters and mods: 2009 Zuma 125. Dual Headlight mod, LED Gauges, Yamaha Rack, Koso Tail lights. More to come....
If they gave you a manual with it there should be a key code in the manual for that bike. From what i undestand Yamaha dealers are required to do this. My dealer wrote the key number in the manual and gave me the numbered tab as well. You will need that number so you can give it to the dealer and they will order the exact key with magnetic code for your tank and switch and lock cover. if you can get a key that will open your switch it will open the tank as well however you will still need the code so it opens the lock and starts. It will not start without the key being programmed. THe "number" on the magnet of our zuma keys is only the magnet design to unlock the switch cover. the key "IS" programmed to function with the ignition. If you look on the side of your key you will see a black circle/dot thingy, this is where the chip is inserted to the key and the dealer is the only one that can do this and will need a vin to program it and thats where it gets pricey. With out that you will only be able to use it to open the gas tank, seat and switch, and if the magnet is the same the switch cover as well. According to my salesman, it will be about 100 bucks to program the key to the ignition. Hope this helps.
8000k's HID's, Dual Headlight mod, Blue LED Gauge lights, Koso L.E.D. Tailights, Yamaha Luggage rack, Yamaha Wind screen, Yamaha Fairing Basket, Yoshimura Exhaust, Taiwan-Yamaha OEM Aluminum skidplate, koso aluminum foot gaurds, Koso Tachometer
Fri Apr 22, 2011 8:43 am
Users browsing this forum: Marygat, ukrainegirlshat, ukrainegirlspfk and 3 guests
