View unanswered posts | View active topics It is currently Sat Sep 21, 2019 11:17 pm
Reply to topic  [ 50 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Getting a Spare Key Made???
scooters and mods: Zuma 125
Post Re: Getting a Spare Key Made???
zuma_scoot wrote:
It will not start without the key being programmed. the key "IS" programmed to function with the ignition. If you look on the side of your key you will see a black circle/dot thingy, this is where the chip is inserted to the key and the dealer is the only one that can do this and will need a vin to program it and thats where it gets pricey. With out that you will only be able to use it to open the gas tank, seat and switch.
There is no chip in a Zuma 125 key. The little circle you are referring to is a detent for the sprung ball bearing that lets the end of the key swivel and stay at 90º to the main part of the key.
Fri Apr 22, 2011 1:43 pm
zuma_scoot wrote:
According to my salesman, it will be about 100 bucks to program the key to the ignition.
Yea... I think your salesman is pulling your leg. :raise:
Fri Apr 22, 2011 2:23 pm
ask your dealer how much crack he's been smokin' :2bong:
Fri Apr 22, 2011 3:54 pm
scooters and mods: 2009 Zuma 125. Dual Headlight mod, LED Gauges, Yamaha Rack, Koso Tail lights. More to come....
who knows man.... im just stating what he told me... i was trying to get another key aside from the spare for my g/f to have and i decided not to until he told me that... and i wasnt talking about the metal circle on the key swivel... theres is a black one obove that.... i saw it on my key. Personally i dont know if the scoot will start or not with out being programmed.... only one way to find out and thats to try it out...
8000k's HID's, Dual Headlight mod, Blue LED Gauge lights, Koso L.E.D. Tailights, Yamaha Luggage rack, Yamaha Wind screen, Yamaha Fairing Basket, Yoshimura Exhaust, Taiwan-Yamaha OEM Aluminum skidplate, koso aluminum foot gaurds, Koso Tachometer
Sat Apr 23, 2011 4:32 pm
http://www.motorcyclekeys.com/
Sat Apr 23, 2011 9:26 pm
cbolling wrote:
Anybody gotten a spare key made for their Zuma?
Mine only came with 1 and I would like to have a spare. The local Yamaha Dealer ordered one and it took over a month before they could get it.
Well it came in and it is the whole key set, by this I mean 2 keys and the round silver part that the key goes in. $40 for the whole thing which is actually less than I would think this cost for all that but I don't want all that. All I want is a spare made.
Is the little part on the back that moves the lock cover different for each bike or will 1 zuma key open the lock cover on all Zumas. They looked the same at the dealer.
I just need a spare key made. Any suggestions?
Yes, I just purchased a 2005 49cc Zuma that had only one key, I took the key to ACE HARDWARE and had two extra keys made for $1.99/each and they both work fine; start-up, open seat & shut off.
Tue Aug 02, 2011 4:15 am
I just got two spares keys made for my 2005 Zuma 49cc at Ace Hardware for $1.99/each using my original Zuma key to copy from.... they work fine....
Thu Aug 04, 2011 4:12 am
scooters and mods: 2012 Zuma 125
In case anyone is going to order a cover & key set, apparently the keys come in right and left versions, with 2 different part numbers. Here is what 2wheelpros says:
"Looking at the existing key with the plastic on the bottom and the metal on top, if the groove is on the right side of the key then use 5S9-WH250-10-C0 if on left use 5S9-WH250-10-A0"
Thu May 05, 2016 10:11 am
scooters and mods: 13 zuma 125 - stock
Is it just me or is that description impossible? Here is my key, I'm assuming the groove is circled in red but if you flip it over its on the other side... Not sure if the blue side is correct or the yellow side is correct to decipher this... I've never had an issue with this key being upside down like a house key. Am I crazy/stupid? (Entirely possible scenario)
PS thanks for the part numbers - super helpful and i'll definitely be ordering one when I figure this out... i've found my (1 set) of keys on the beach miraculously a few times and I probably shouldn't rely on that type of luck
Zuma 125 - mostly stock
dual headlight, koso afterburner-like tail lights, smoked clear lenses on the front/rear turn signals, carver surf rack, milk crate, Simota air filter, green wrap on matte black panels, c3 mirrors
Tue May 10, 2016 11:10 pm
I'm pretty sure they're not talking about the little notch you have circled, they're talking about the 1-1/4" long groove. Yours is on the left side (unless your photo is reversed). Look at the photos on page 2 of this thread, those are on the right side.
Wed May 11, 2016 8:59 pm
Great... thanks for clarifying - i see it now
Wed May 11, 2016 10:00 pm
This is what I got when I ordered WH250-10-C0. Apparantly, the part number changed to 5S9-WH250-11-C0
Note the last character in the part number is zero, not the letter O
Tue May 17, 2016 12:07 pm
scooters and mods: I'm still a complete noob. I upgraded from a 2004 Zuma 50cc to a 2013 Zuma 125. There's a lot for me to learn.
I know that this is an old string, but a lot has happened since the last post that I would like to add to it. I too bought my 2013 Zuma 125 used and it came with two keys, but only one of them has the little magnetic Key Bow and there is no key identification number tag on the key ring.
When I talked with the folks at Yamaha, they told me that they can’t identify and copy the key using the vin number. It needs the key identification number to make a match. The only solution would be to purchase a whole new set of keys as well as a new key hole set up like the photo above in raygromer’s post. Oh, you would also need the gas cap lock as well as the ignition. The cost of this is over US$100, not counting any installation costs.
— Rick Rudge
2013 Yamaha Zuma 125 • Dual ZumaLight harness • Mos plastic cubby/pocket • Michelin City Grip tires • Malossi Multivar •
http://www.zumaforums.net/Gallery/v/rudge/
http://rickrudge.angelfire.com/
Mon Sep 24, 2018 11:03 pm
I know it is not the best solution, but it is a quick/cheap solution... I had an issue where the tiny magnets (located in the ignition locking mechanism would not respond well when using my key to unlock the ignition. I tried both keys and it was the same result. I removed the ignition lock assembly and took it apart. (Make sure you do this in an area that is clean and easy to spot tiny springs and magnets when they fly out.) On my ignition lock assembly I noticed that the springs where worn out and did not provide equal support to each of the tiny magnets. If even one magnet does not rise to the correct position, then the lock will not unlock. I ended up just removing all the magnets and springs from behind the metal plate where the key goes to unlock it. I cleaned and lubricated everything with dry teflon spray lube and re-assembled everything. Now it will unlock with the key or any other object that you can use in its place. It is obviously not as secure as it once was when the magnets/springs worked... but at least it functions well enough. The ignition lock was never meant to provide great security... it is only a minor theft deterrant. Anyone with a truck/trailer and some help can take your bike. The ignition assembly can be accessed and replaced without ever having to unlock the cover plate.
Sat Nov 10, 2018 2:21 pm
Post russian girls
Actoughaltext you
DiamondJoeQuimby80 1 point recorded 3 days ago
make your RAST test done. Get a fix test done. Cross examine both out comes, Remove offenders. remove them permanently and don give up if reversal doesn happen quickly. If you can afford either of those tests, Repeat food molesters are: alcohol addiction beverages, whole milk, Gluten, Nightshade, hammer toe, egg cell, crazy, revamped sugary trash. It actually possible to remove all those from a diet and still eat balanced (we do).
use probiotics. launch more vitamin D. many more water (2 3 ltrs a day). Bed recently 10pm (Sleep during the hours of 10pm 2am releases huge anti inflammatory hormones). A LOT of cardio to keep lymphatic system system moving.
As far as topical treatments, make an effort Protopic/Tacrolimus. Stay away from steroids whenever possible. Avoid exposure to wind chill.
Vanshnookenraggen 14 points registered 1 month ago
It not a technical reason but rather an amazing one. The M as you may know it was born as the Myrtle Ave El which ran from the Brooklyn Bridge to Wyckoff Ave. The reason it wasn extended further is obvious once you it's similar to: Brooklyn and Queens weren yet portion of the same city. The Brooklyn Rapid Transit Co didn have the rights to form lines in places that weren Brooklyn and Wyckoff is the border. At Wyckoff Av there seems to be a trolley that continued northeast to the major cemeteries in Middle Village.
Cemeteries in the late 19th Century were imagined more as parks than they are today. You would take your family out of the city and walk-through the quiet, landscaped cemetery to spend the afternoon. It wasn hard to find to see families having picnics there, Maybe next to the grave of a past valentine. in most cases, If you needed to get lots of individuals to a funeral and you didn have private automobiles then a train would be the next best option.
So in 1898 the city combined, Brooklyn and Queens were now part of very NYC. Queens at the moment was still mostly farmland with some major towns spread about, The largest were LIC including Astoria, filtering, as well as Jamaica. Part ukraine wife of the reason for consolidation was so services like transit could be spread all through the city. Once the first subway proved popular the city and companies began planning extensions. Queens saw some brand new lines in Astoria and to Corona but this also gave the BRT the capability to extend their Brooklyn lines. So that train line to the cemetery was elevated and became the end of the M train.
But why didn it go any more? Because there wasn any reason to give it. Central Queens took years to create the way it is now; Even into the 1950s there were undeveloped farm lands in central Queens. Because pre enriched areas like Astoria, purging yourself of and Jamaica already had demand they saw service first. Keep in mind these lines were build by private companies scheming to make money. You can build a line into a corn field and hope it will be developed or you can build a line to where people already are and start getting cashfrom or.
There was once a plan to plug each end of the M. But just not when imagining it. In 1929 the IND Second System proposed miles of new lines and one was a very serpentine route through Maspeth and Middle Village from Roosevelt Ave to Central Av. 2 express tracks might run to Manhattan along East Broadway and Worth St to 8th Ave, 2 local tracks could have continued to downtown Brooklyn via the Crosstown Line. In Glendale this central Queens branch will have joined up and as a trunk can have run out to Ozone Park and the Rockaways. At Roosevelt Ave there is an abandoned upper level terminal that was built for this line but the line was never pursued and dropped a decade later.
Maspeth and Middle community are stuck, okay, at the heart. given that never had a subway to connect them to Manhattan they never developed the density to one. Until 20 years ago lots of subway riders were trying to get into Manhattan but with technology the way we work has changed. Now you see a growth in non ny based commuting. In this sense a major reason why the M was never associated with itself was that there wasn demand for it until recently.
Tue Aug 06, 2019 4:05 am
