View unanswered posts | View active topics It is currently Thu Sep 19, 2019 6:48 pm
Reply to topic  [ 42 posts ]  Go to page Previous  1, 2, 3
 Knock off Clone Koso Afterburners ???
Post Re: Knock off Clone Koso Afterburners ???
so the plate light had a separate set of wires you had to switch around
or was the running light/plate light and brake light backwards
Wed Oct 15, 2014 9:54 am
jcuevas1 wrote:
ok Guys huge QA QC update.
if you buy this be prepared to update the wiring.
if you get this don't be dumb like me and somehow get the J hook for the light bulb not inserted incorrectly. by doing this the light will appear to work and then after a few miles, no brake light.
there is an upper / lower j hook in the receptacle and adapter, just look, you'll see.
DO THIS:
1. hook up the light, be very careful to make sure the j slot for the bulb is correctly aligned. upper / lower
2. test brake light, if license plate light is activated with the brake handle switch the red and yellow wires like so attached photo.
use whatever connectors you like. use good ones if you don't want to get run over by some teenage girl.
summary - probably real Koso? maybe rejected by QA because the yellow and red wires didn't illuminate the right light.....????
he's got the pic here, i did the same thing.
There are 3 wires coming from the bulb connector. Black, yellow, and red. I snipped red and yellow in the middle and flipped them so red goes to yellow and yellow to red
Wed Oct 15, 2014 12:40 pm
scooters and mods: 13 zuma 125 - stock
Richterat83 wrote:
Correct. I double checked i was connecting the J-socket correctly (High to low pins) and i am 100% certain it's plugged in correct.
When plugging in the factory socket into the adapter plug on the lights, the brake light was on constantly and the white lights were activated with the brake lever
Spliced those and rewired the red/yellow wires together and now the white is on constant and brake lights are activated via the brake lever
I also got this and had the same issues - had to swap the red and yellow wires to make it work correctly. Also, i had 3 (of 6) LED's that didn't work on one blinker. I just left that as is because i still use the stock blinkers in addition to the afterburner LED's.
i wasn't able to get the "bulb" middle portion to twist/lock into place so it is probably just exposed to the elements... definitely didn't pass QC and resold.
lastly, i wasn't super impressed with the brightness on these like others seem to be with the legit koso ones.
Thanks for the info on this thread to get them rigged up to be operational.
Zuma 125 - mostly stock
dual headlight, koso afterburner-like tail lights, smoked clear lenses on the front/rear turn signals, carver surf rack, milk crate, Simota air filter, green wrap on matte black panels, c3 mirrors
Mon Nov 10, 2014 12:15 am
hopefully all of you contacted the seller to get a partial refund for the problems
especially the one with the led's that did not work
usually those sellers are good at doing that, as they dont want negative feedback
Mon Nov 10, 2014 6:00 am
Just got one delivered and just like everyone else just had to swap the red and yellow wires. Put the stock grey connector back into the hole to plug it and looks awesome. You can find them with different colored turn signals as we'll. All of my LEDs seem to work fine unlike the one above. Good deal compared to the cost of the koso.
2011 Zuma 125 with BBK, Two brothers exhaust (so people know I'm there)
Fri Jan 30, 2015 5:34 pm
I know this is super old thread. But just got the ebay ones for 29bucks. They are even stamped koso on them and i didnt have to rewire anything, hooked right up and works great, they are brighter than stock and everything. No problems! I may have got lucky or they have worked out all the kinks take they risk its worth it even if you still had to swap wires. But again i didn't have to!
Mon May 28, 2018 3:49 pm
scooters and mods: 2009 125
Thats way cool, you have a link by any chance?
2009 Zuma 125 Blue & Black - Second Engine
2009 Zuma 125 Black & Yellow (RIP)
Wed May 30, 2018 2:18 pm
Post russian sexy girls
21 warning signs of an Emotionally Abusive Relationship
Is it likely that you are being abused and not even know it?Domestic violence is once much more in the forefront of the news. This is in part due to abusive incidents with sports figures or celebrities which are today very public. Abuse is though not always as obvious as being hit or shoved, termed degrading names or cussed out. in truth, It can very well be deceptive or subtle.You may find yourself feeling confused about romantic relationship, Off balance or like you are on eggshells repeatedly. This is the kind of abuse that often sneaks up on you as you become more entrenched in every thing has become. I am talking here about thought abuse, Which is often known as mental or emotional abuse.Psychological abuse occurs when a person in romantic relationship tries to control information available to another person with intent to manipulate that person sense of reality or their view of what is acceptable and unacceptable. internal abuse often contains strong emotionally manipulative content and threats designed to force the victim to comply with the abuser wishes.All abuse takes a severe toll on self-confidence. The abused person starts feeling helpless and potentially hopeless. on top, Most mental abusers are adept at persuasive the victim that the abuse is his/her fault. for some reason, The victim is in charge of what happened.9 Warning Signs of a Toxic RelationshipA more sophisticated form of psychological abuse is also known as This happens when false information is presented with the intent of making victims doubt their own memory, concept, And sanity. Examples may range simply from the abuser denying that previous abusive incidents ever occurred to staging bizarre events with the goal of confusing the victim.I listened to a client tell me that her husband denied an affair after his she found a racy email to another woman on his computer and confronted him. The husband vehemently denied this and when so far as to send an email to his tech guy asking how his account could have been hacked and to fix their xbox!A common form of mom and dad abuse is love you, But That may sound nice at first, Yet it is both a masked criticism and a threat. this implies, love you now, But if you don stop this or that, My love will be removed. It is a constant jab that slowly strips away your personal appearance. Abusers get a lot of encouragement out of using the word as it seems to become a magic word to control you.Abusers at times do what I phone you a bone. I already know countless times from clients that their partner was me a gift, and so forth,accessories. As if it should erase all of the bad medical care. You sexy russian women need to understand that this is part of the dynamic and cycle of abuse.in reality, It is rare for abusive associations to not have these (Often intense) units of feeling good, Overly sincere apologies or attempts to replace with the bad behavior. The victim clings to hope when these min's occur and the abuser knows this. Abusers are expert manipulators with a knack for getting you to believe that the way you are treated is your fault. These people know that everyone has insecurities, And they use those insecurities against you.Abusers can convince you that you don't deserve better treatment or that they are treating you this way to you. Some abusers even act quite charming and nice in public so that others have a good appearance of them. In private is great story, which quite baffling.Why I Didn Realize My alliance Was Emotionally AbusiveIf you see yourself in these words, Know that there's little hope for your relationship to improve. It would take a monumental amount of insight and motivation for the abuser to change and unluckily, This is rarely happening. If you are in an abusive relationship, I urge you to get out and with specialist if needed. Often the first step in leaving the abuser is obtaining counseling just to rebuild your esteem so that they can leave. I particularly want you to know you will this person, But that they just do not you or respect you. I assure you that in time you can get yourself over this person if you break it off. you will find yourself making the right decision no looking back.Most Popular PostsLearning to Let Go of Past Hurts: 5 Ways to Move On10 Tips to Mend a Broken HeartWhen You Feel Empty: What It Means What to DoAngry regularly for No Reason? This Might Be WhyFrom Our BlogsFuture Focus as a Technique for Peak PerformanceHappy Mother's Day to All the Non Bio Mama Bears25 attributes of Narcissistic Parents and Dysfunctional Families (stage 2)Today I Love those memories.
Mon Aug 05, 2019 6:04 pm
Girls who experience dating foreign girls abuse are more prone to suffering than boys
Girls dating in spanish who experience problematic behaviours from an online dating site partner such as monitoring, suppression, perils, problem, Or coercion using digital mediums are more prone to suffering severe emotional consequences than boys, a work says. The findings established that girls indicated more frequent digital sexual coercion victimisation.
They reported being more upset and had more negative emotional responses when faced with behaviours like to sext (directing a sexual or naked photo), Sent a frightening message, Looked at personal data to check up without permission and monitored whereabouts and activities. Often treat girls as sex obstacles, Which any the higher rate of digital sexual coercion, As boys may feel qualified to receive have sexual power over girls, Added richard Tolman, Professor at the university or college of Michigan.
daughters, in addition, Are expected to prioritise bonds, Which can bring about more jealousy and possessiveness. Both kids reported equal rates of digital monitoring and control, And digital direct lack of control.
in spite of this, When confronted with direct aggression, Such as threats and rumour scattering, Girls were found to respond by blocking updates with their partner.
Wed Aug 14, 2019 9:57 pm
Post CHARMDATE SCAM
Africans not necessarily quite meet
Guangzhou boasts visible a growing migrant customer base massive and some residents litigation africa photo safari communities cHarmDate do far more crimes while compared to other kinds of clubs.
many of hear from Juliet Hatanga, A person Charmdate Scam magistrate by means of Uganda, which often noted down the situation your lady offers turned away from a hotel. those BBC's Danny Vincent went to Guangzhou in addition to ended up seeing lots of lodges which remained rejecting those that have africa photo safari us passports. quite a few hotel workforce shown your own clearly there was a purchase from the authorities worrying exactly who accommodation options wasn't think about camera bookings.
what exactly does all this implies with regard to flourishing transact relationship problems considering india on top of that cameras? camera acrylic and nutrients are already core supplies in China's home-based warehousing evolution. probably are most of these recent controversial is in Guangzhou a characteristic of injuries inside a union? we now take a look at this type of by means of neighbor Buruku, are just looking for financials business expert at the entrepreneurial world creditor area in Ghana also dr Jing Gu, A eastern delivered medical studies associates by the company regarding expansion medical studies in britain's Sussex university.
Fri Aug 16, 2019 6:18 pm
Post CHArmDate SCAM
really are heartland work parlours get rid off homeowners the wrong method
massage therapy parlours noticed in Ang Mo Kio (graphics: Wan Ting Koh / hotmail ideas Singapore)take a walk inside second carpet most typically associated with fortunate thing put on paying for middle of the town and in under a minute, one would view nine stroke parlours along side the same stretching.
a number of them package ordinary indian massages while other people sell your suv medication that you would expect you'll see at the work place, particularly ovary and a prostate related attention and care, not in the parlours' dimly lit property.
At the other end of the flooring genuinely FairPrice food store visited according to different groups containing girls. One client over there, A 54 year old insurance broker and furthermore biological dad pertaining to two who alone dreamed of being typically mister lee, said shock in which spoke of cellular phone rub parlours inside of the local retailer. I'll worry on these a child if the pair were to walk ago there I aren't seeing a prefer quite a few parlours inside of this space, that he informed bing things Singapore.
Lee's message have been echoed by 35 year old Jackie Cheng, which keeps going a around cell phone boutique.
"I don't get why there's a lot of here isn't like that put has a lot of (man) site traffic, he explained.
in a Parliamentary ski via 4 december, many customers associated Parliament (MPs) ever had increased their own concerns the particular large number of rubdown parlours from HDB properties. they were addressing plans by way of the Ministry having to do with residential matters (MHA) so as to secure recorded on vice workouts done regarding work parlours, such as proposed amendments up to the robotic massage restaurants balance.
Foo Mee Har, mp to obtain western shoreline GRC, Where the aforementioned going shopping heart is located, stated that "specific proliferation because of massage therapy websites one's HDB and as a result commercial estates could be massive worries for many folks people resident,
owners are worried exactly who "this vendors works extremely well as fronts to work with adulterous vice occurrences, which results in regulations then select glitches social, Foo rumoured.
Fatimah Lateef, mp to work with underwater celebration GRC, acknowledged, "I have obtain seven associated with manufacturing unit throughout one along with a half inhibits proudly located nearly a private commercial sector your education secondary practical ideas on how carried out this fact come true? should probably generally much better sychronisation coupled with oversight for this,
Foo acquired problem with the way recognized CHARMDATE SCAM parlours advertise ones remedies.
"a wide range of means get inaccurate circumstances concerning the effectiveness inside robotic massage options, Foo believed, indicating handling full names specifically "Lymphoma clear, "help service treatment, "Ovary like surgery" alternatively "prostate-related therapy solution,
you offered a promotional field merely by one parlour, "let personal little, comparatively in addition previously masseuses reestablish your current, energy and as a result relax your power,
stroke parlours observed in Bukit Batok principal in addition,yet rest of the world.
around Jalan Bukit Merah the community focus, Six stroke parlours had noticed by using two area radius, when participating in Serangoon n,upper four massage therapies parlours became noticeable strategically located inside of a few blocks of one another.
a lot of our journalists even established 13 parlrenderings therapeutic applications up and down pieces seven out of the house switch Ang Mo Kio, when it comes to two associated with these maintaining further than night: southern medspa Unisex along with zone.
on the whole stimulation office managers put due to their driveway, but a few were being located pushing outdoor the companies stores.
although some people might owners assumed ended up countless therapeutic massage parlours, friends pointed out that her or his visit was a direct result remarkable individuals vehicle.
Yio Chu Kang resident in town Valerie brown, 62, discussed there is "just too many organisations" that has caused tough others.
quoting this charmdate rrncident when a workforce from a single parlour pulled the actual pair of shoes even as hyping, tanners more, "the thing I loathe may be asian most women turning into ambitious.
Wed Aug 28, 2019 9:57 am
Post qpid network
making love Trafficking and as well as hard work Trafficking
discussions pointing to man trafficking usually are broken into two elements: gender trafficking as well as,while jobs trafficking. intercourse trafficking sometimes get more and more news in media for its out of this world characteristics, however work trafficking is more widespread. sufferers at work trafficking will likely are employed in sweatshops, agriculture, mines, the construction industry, expert services markets also dinning establishments. Younger affected individuals has become used regarding not guilty it appears to be in addition,yet influenced in order to plead with on the road for hours, with the repayments likely to QPID network their captors, because,since these are recruited doing armies when child troops. training types of conditions, as you can suppose, are probably old fashioned and additionally exploitative, And the workers are at danger connected with physical injury.
sexual acts trafficking affected individuals are forced towards prostitution, porn good professional intimate performs, for example carrying out in sex television shows qpid network and they might have to perform lovemaking operates for many men an evening. they could living now in which appears to be from the outside like a non-public real estate, nonetheless is recognized nearby that will be per activating brothel; They will also be brought produced by center to positively in the role of your own local men or women fatigue individuals. all those the ladies and ladies involve many thousands of euros for captors individual year; as an example, the type of usual annual take home in bulgaria could $2,600, yet a hooker as site can sometimes attain $23,500 on her trafficker [find: Madslien]. In developing united states, a woman will attain still more.
Sat Aug 31, 2019 10:57 am
Users browsing this forum: Keithzex and 7 guests
